Rubbing is NOT racing
Discussion in '2.5 Gen Tundras (2014-2021)' started by JRPro, May 15, 2018.
  1. May 15, 2018 at 12:52 PM
    JRPro
    JRPro [OP] Snappin’ necks & cashin’ checks
    Rich
    Austin, TX
    17 TRD Pro CM Cement
    I've got some pretty heavy rubbing on my front bumper now from recently adding much bigger meats. What are some ways you guys have counteracted this? I don't know that I want to totally destroy the inner fender so looking for those awesome and creative ways you guys have modded the plastic. Thanks in advance!
    Jsena likes this.
  2. May 15, 2018 at 12:59 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Days of Thunder
    I went under and cut the the metal that was hitting mine.. drilled a new hole for the screws moved it up 2 inches.. no more rubbing .. easy and simple.. a few pics of it on my build page
  3. May 15, 2018 at 1:03 PM
    Black Wolf Where's my popcorn salt? Damnit
    Aurora CO
    2014 Blaaaaack, 5.7L DC Limited TRD 4X4
    Zone UCA's, Fat Bob's Vated, Pro Form Fab shackles, Patagonia M/T's, Ranch Hand Grill Guard, RC steps, SDHQ AIP relocation kit, RetraxONE MX, Jomax ABS armor
    DITTO^^^^^^^push fender liner foward.
    geno0506 likes this.
  4. May 15, 2018 at 1:07 PM
    JRPro
    Rich
    Austin, TX
    So, you guys are saying unbolt the liner, push it forward and make new holes for it? Mine has some pretty solid bolts holding it to the fender it seems, not just rinky dink screws. I have a pro, so not sure if they are different in this area but seems like I would have to relocate whatever is backing up that bolt as well.
    Jsena likes this.
  5. May 15, 2018 at 1:14 PM
    Aurora CO
    I remember pushing mine forward a couple inches near the bottom. Some guys use a heat gun to do it. I don't remember taking off a screw.
  6. May 15, 2018 at 1:19 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Yup, undo liner, see where that screw is up front.. I cut if right off, drilled hole for new bolt and it gave me a few more inches.. I have 37’s with Zero rubbing now... full lock and all
    rocky_mtn_trd and Black Wolf like this.
  7. May 15, 2018 at 1:21 PM
    JRPro
    Rich
    Austin, TX
    Alrighty then! Sounds like it's going to make my butthole pucker up cutting on it like that, but guess that's the breaks when you have to have bigger tires. Appreciate the info
    Jsena likes this.
  8. May 15, 2018 at 1:22 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    It’s sumple dude.. look at the pics on my build and it will show you how I did it.. and I’m horrible with shit like that.
    rocky_mtn_trd likes this.
  9. May 15, 2018 at 1:30 PM
    JRPro
    Rich
    Austin, TX
    I see @1UPPER went for the 1 up on your build page for this mod....
    1UPPER and Jsena like this.
  10. May 15, 2018 at 1:31 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
  11. May 15, 2018 at 1:31 PM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    blue16 and JRPro [OP] like this.
  12. May 15, 2018 at 1:32 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack Third Genie
    OP, if you remove the bottom bolts you can see that the liner can be pushed forward. I used a heat gun and baseball bat to mold the plastic so it would sit there without pushing. Drilled new holes and bolted it back in.
    At full lock on reverse I was also rubbing the mudflap, gone.
  13. May 15, 2018 at 1:32 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    His truck is BA
    1UPPER and JRPro [OP] like this.
  14. May 15, 2018 at 1:36 PM
    JRPro
    Rich
    Austin, TX
    Interesting! I'll give this a shot before I start chopping on stuff. Getting real tired of having to Austin Powers all of my reverse turning.
  15. May 15, 2018 at 1:41 PM
    lionix
    What offset wheels?
    Jsena likes this.
  16. May 15, 2018 at 1:43 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    My wheels are -25
  17. May 15, 2018 at 1:59 PM
    15whtrd
    15whtrd Mr. Blonde
    Are you sure you don’t mean +25. -25 would be sticking way the F out there.
    rocky_mtn_trd and Jsena like this.
  18. May 15, 2018 at 2:00 PM
    15whtrd
    15whtrd Mr. Blonde
    I looked at your truck on your avatar and I’m sure you mean +25.
  19. May 15, 2018 at 2:08 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    No, I’m -25 bro, no fender flares either.. maybe you’re looking at a different truck
  20. May 15, 2018 at 2:12 PM
    15whtrd
    15whtrd Mr. Blonde
    Well I’ve been pretty retarded lately so maybe I have it ass backwards LOL.
    rocky_mtn_trd, gosolo and Jsena like this.
  21. May 15, 2018 at 2:13 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    :yes:Lol
    lionix, 1UPPER and 15whtrd like this.
  22. May 15, 2018 at 2:20 PM
    JRPro
    Rich
    Austin, TX
    You may have been quoting @Jsena and looking at my avatar (OP) and mine are +12. 325/65 tire
    Jsena and 15whtrd like this.
  23. May 15, 2018 at 2:23 PM
    15whtrd
    15whtrd Mr. Blonde
    I was looking at the OP’s truck LOL. For some reason I thought he said he had +25. My reading comprehension is lacking lately.
  24. May 15, 2018 at 2:24 PM
    15whtrd
    15whtrd Mr. Blonde
    That’s exactly what I was doing. There is no way your rims are -25. I’m still on my stock rims which are +60. But I’ve read a lot of rim threads so I thought I had a good feeling for what looks like what.
    Jsena likes this.
  25. May 15, 2018 at 2:26 PM
    JRPro
    Rich
    Austin, TX
    You weren't too far off, just 13mm. Lucky 13
    15whtrd likes this.
  26. May 15, 2018 at 2:33 PM
    TheBeast The Beach
    cut, drill, zip ties :)..get that meat in there..
    Jsena and JRPro [OP] like this.
  27. May 15, 2018 at 5:30 PM
    lionix
    You didn't have to do a BMC?
    Jsena likes this.
  28. May 15, 2018 at 5:32 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Yea did that too but was still
    Rubbing up front.. So had to do this next Step
