Routing RCA's through the dash
Discussion in 'Audio & Video' started by Beerdude77, May 19, 2018.
  1. May 19, 2018 at 7:26 AM
    Beerdude77
    Beerdude77 [OP] New Member
    2018 Silver Sky Tundra Limited TRD CM
    Linex bed, "Toyota" Console Safe
    Can anyone tell me how they got their RCA's routed through the dash down towards the console?
  2. May 19, 2018 at 7:34 AM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    I used a wire coat hanger from the back of the radio on the right side, brings it out at passenger side by the bottom of the console
  3. May 19, 2018 at 7:35 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    This might help
  4. May 19, 2018 at 7:39 AM
    Beerdude77
    I have the old unit out, I'm guessing I need to remove the console completely (I only removed the cover like the video thus far and there isnt a way to get around the where the console meet the bottom of the dash that I can see). Will the silver surround that has the vents just pop out? If I remove the console completely and then the silver part I think I can fish them through that way. What do yall think?
  5. May 19, 2018 at 7:42 AM
    Berdine
    Binghamton, NY
    I think to get that part off you have to dismantle the dash more. Find something sturdy that you can fish down through the dash, it'll make it easier. I did that with mine
  6. May 19, 2018 at 7:55 AM
    Danimal86
    Daniel
    Sacramento, CA
    You could also route the rca's behind the glove box, down through the kick panel and along the door channel, and up through the carpet. This is the route i usually go, and it may save you from dismantling your dash completely.
  7. May 19, 2018 at 8:56 AM
    Beerdude77
    Alright an hour later and finally got the first rca fished, what a PIA!!! Had I bought longer than 6' cables I would've def done it a different way! Thankfully taking the console completely apart was all I needed to dismantle...for now...
  8. May 19, 2018 at 9:35 AM
    Beerdude77
    OK, figured out the sweet spot, you gotta go up and over that clearish plastic "hump" in the back that is protecting all those factory wires. The last 2 fished through really easily, hopefully my fails make someone else's install easier...
    BLONGTX likes this.
