Rough idle
Discussion in '1st Gen Tundras (2000-2006)' started by jggeere, Apr 9, 2021.
  1. Apr 9, 2021 at 4:11 PM
    jggeere
    jggeere [OP] New Member
    jared
    2002 toyota tundra 4.7 4x4
    So I’ve been dealing with this rough idle for a while now and I can’t seem to find the issue. I’ve cleaned the MAF, throttle bottle, replaced spark plugs, and a few other things but the rough idle is still sticking around. What else must I try? Timing belt, water pump, and fuel pump have been changed in the last 3 months. Any suggestions would be great. Thanks in advance.
  2. Apr 9, 2021 at 4:36 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    A new air filter helped smooth out my rough idle, but it was in pretty bad shape.
  3. Apr 9, 2021 at 4:42 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    you burning any oil? Losing coolant?
  4. Apr 9, 2021 at 4:45 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    vacuum hoses in good shape ?
    Does it ever die and/or set any codes ?
    Did you clean TB or someone else ?
  5. Apr 10, 2021 at 10:02 AM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    Have you checked your ignition coils? Check for cracks.
  6. Apr 10, 2021 at 4:17 PM
    jggeere
    jared
    I figured it out. There were a few broken blades on the radiator fan( it was throwing everything off evidently) Anyone know how that could happen? Went to a junkyard to find a new one because apparently you can’t get them anywhere. Runs silky smooth again. Thanks for the suggestions!
    FrenchToasty likes this.
