Rough country lightbar issue.
Discussion in 'Lighting' started by poheller, Oct 1, 2018.
  1. Oct 1, 2018 at 8:55 AM
    poheller
    poheller [OP] 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    Anyone else have a rough country light bar in the lower grill with this issue of moisture inside the light bar? I sent pictures to rough country and they want me to loosen the screws turn a light bar on for 30 minutes to dry it out. That makes no sense to me as it should be a sealed unit and no moisture.
  2. Oct 1, 2018 at 10:43 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I have 2 pairs of LEDs on boat trailer that are hooked up to reverse light circuit. One set is marine rated for underwater and totally sealed the other one has a 67 rating and is good to 1 meter for 30 minutes. Guess which one has moisture in it.
  3. Oct 1, 2018 at 11:03 AM
    JoshuaA
    JoshuaA GenX 2.5
    Ontario
    Blacked 2015 going strong!
    Is it under warranty? How old? I’ve heard people add caulk to theirs, before that happens so dry it out first, if they won’t replace it.
    My clone’s still dry, knock on wood.
  4. Oct 1, 2018 at 1:42 PM
    poheller
    Scot
    2018 platinum
    A month old
    JoshuaA[QUOTED] likes this.
  5. Oct 1, 2018 at 1:48 PM
    JoshuaA
    JoshuaA GenX 2.5
    Ontario
    Damn, no way I’d settle for that within the year.
  6. Oct 2, 2018 at 2:50 PM
    poheller
    Scot
    2018 platinum
    Well here is what I am being told now, never heard of a light bar that is designed to suck in moisture! Anyone else ever hear of it.
  7. Oct 2, 2018 at 3:10 PM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    Sounds like bs to me.
  8. Oct 2, 2018 at 6:24 PM
    Have two pairs of RC l.b.'s, dbl row n single just above license plate, not water issues at all
  9. Oct 2, 2018 at 6:27 PM
    poheller
    Scot
    2018 platinum
    I am trying, they keep gas lighting me..
    NewImprovedRon likes this.
  10. Oct 3, 2018 at 9:20 AM
    PMG
    PMG New Member
    I have one and have had no issues thus far. I believe there is a vent screw of sorts on the side of the bar and is easy to miss. I believe they are asking you to unscrew this a bit. I personally would like a replacement.
  11. Oct 3, 2018 at 11:53 AM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    Yep, that was me that had on replaced by warranty. They told me to do the same thing, it didn't work and they sent me a new one, along with a return label for the bad one.
    poheller[OP] and NewImprovedRon like this.
  12. Oct 3, 2018 at 12:06 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Damn, guess I can scratch that off my list.
  13. Oct 3, 2018 at 1:09 PM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    That sounds crazy that a light bar would suck in moisture???
