Rotors at 20K, 2017?
Discussion in '2.5 Gen Tundras (2014-2021)' started by PhillyPro, Jan 7, 2020.
  1. Jan 7, 2020 at 12:30 PM
    PhillyPro
    PhillyPro [OP] New Member
    2017 TRD Pro Cement
    TBD
    I have been told that I need new pads and the rotors are "OK but need resurfacing". I understand the pads but the brakes make no noise and find it hard to believe (this coming from dealership) concerning the rotors. 20K miles on TRD Pro 2017.
    I'm having UCA put on Thursday by an off-road shop I think very highly of. What do you think?
  2. Jan 7, 2020 at 12:32 PM
    sundance
    sundance New Member
    They're probably lying to you. Mine lied to me about the same time for brakes. I ended up going 70,000 before I needed either. There are few good people left that do honest work anymore.
  3. Jan 7, 2020 at 12:33 PM
    TheBeast The Beach
    aren't the rotors covered by 36K warranty ? seems kinda low mileage for new ones
  4. Jan 7, 2020 at 12:33 PM
    sundance
    sundance New Member
    Not if they're wore out. Wear items aren't covered when they wear out.
  5. Jan 7, 2020 at 12:36 PM
    xJuice
    xJuice This guy...
    Josh
    DFW, TX
    '19 MGM DC SR5 4.6 TSS
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill, Remote Start, One-touch Auto Windows
    Assuming you have actually worn through your pads already; yes a resurfacing of the rotors would be best practice. A new set of pads will work best on a true and flat set of rotors.
    HUTCHJ likes this.
  6. Jan 7, 2020 at 12:39 PM
    Broncobroke
    Broncobroke Super White Power
    Charlie
    Piedmont, NC
    2017 White Tundra 1794
    Have your shop look at them. I have 113,000 on my 2017 still original pads.
    AZBoatHauler and sundance like this.
  7. Jan 7, 2020 at 12:40 PM
    sundance
    sundance New Member
    Unless you're in constant stop and go traffic and are very serious abuser of brakes... I don't possible see how it could happen myself. I mean there is so much brake material on the pad its is very hard for me to believe. Like I said, my dealer lied to me. All of them lie from what I can tell.
    Trooper2 and Broncobroke like this.
  8. Jan 7, 2020 at 12:41 PM
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    Pads should last at least 50k under terrible conditions. How much pad is left?
    Broncobroke likes this.
  9. Jan 7, 2020 at 12:53 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Did you ask them to show you the inspection report so it's in writing? They usually have those red/yellow/green boxes they'll check off. Or give you mm measurements.
    sundance likes this.
  10. Jan 7, 2020 at 1:15 PM
    PhillyPro
    2017 TRD Pro Cement
    TBD
    So I was told there was 1mm left by the dealership. I just heard back from the off-road shop and said it sounds odd and that they typically do the rotors every other time they do the pads. They said they would look and they will call me if they need to be done. Tires are coming off to do the UCAs, so I would rather have them do the brakes as well. The UCAs are another story. Put 35's Ko2 and hit the body mount by around 1 cm. I'm hoping the SPCs give me just enough to clear the mount.
    PS went with 17"+25 Icon six speeds with CB pro kit and thought I would make without UTC and/or a chop. The same exact set up, year, model, tire, pro kit and even color... made it with Methods +25. I don't know. Go figure.
    Mcoop likes this.
  11. Jan 7, 2020 at 1:45 PM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Regardless I wouldn't have them machined, just replace.
    AZBoatHauler and Aerindel like this.
  12. Jan 7, 2020 at 2:13 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I always go over 100,000 even towing. I am a light braker and lots of hwy. Ex could not make it to 30. I use to tell her there is a 3rd pedal between the gas and the brake
  13. Jan 7, 2020 at 2:35 PM
    Brandisher
    Brandisher Member
    UT
    2018 MGM Limited CM
    Have you looked at the pads yourself to do an assessment on whether you need new pads?
  14. Jan 7, 2020 at 2:45 PM
    HUTCHJ
    HUTCHJ I can ride my bike with no handlebars
    J
    Not impossible. Especially if you (or someone who drives the truck) rides the hell out of the brakes.
    Is there any wobble while braking? If so, turn them.
  15. Jan 7, 2020 at 2:52 PM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    I warned you about letting my wife drive your truck:rofl:
  16. Jan 7, 2020 at 3:57 PM
    Doylfish
    Doylfish New Member
    2016 Tundra 1794 Crewmax
    i cant remember exact mileage, but it was around 30k for me on my 2016 when i was getting a lot of wheel wobble / shake on braking. dealer at first wanted to take it for a test ride, but i guess when they took the wheel off they said they could see enough turn in the rotor that they got them machined right then and there. this was front rotors only. at my most recent oil change 50k they came out to me and said pads were 3-4mm all four corners and in the 'yellow / red' area on that color chart and i needed all four corners rotors and pads with rears of utmost importance
    JimboSlice413 likes this.
  17. Jan 7, 2020 at 4:01 PM
    AZBoatHauler
    So.Arizona
    I'm a little over 40k miles tow through mountain grades frequently and have over 50% left on the original pads. Either they are trying to cheat you or there is another issue causing such drastic and premature wear.
  18. Jan 7, 2020 at 4:34 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    THIS right here. ^^^^
    I'm at 58,500 miles (I bought it new from the dealer) and have 3/4's of the pads left on the front.
    I've never (I've had 7 new Toyotas) experience brake pad wear like what's being described. I've always (trucks, Celica, Sequoia, Avalons) been 100,000 miles before I needed to keep more careful track of the wear.
    HulkSmurf14 likes this.
  19. Jan 7, 2020 at 5:25 PM
    Doylfish
    Doylfish New Member
    In my case I’ve checked myself. I saw their millimeter measurements, but that’s why when the service writer was like so what can we get done today I was like uhhh nothing. You can finish the oil change and I’ll check it out later. Having no issues with shaking / wobbling or stopping for that matter. They also said my battery was about to die since I had 585 CCA when they tested and I should change that out. We’ve been sub 35 for weeks and I’ve had no trouble turning over the truck
  20. Jan 8, 2020 at 10:43 AM
    PhillyPro
    2017 TRD Pro Cement
    TBD
    I will let you know if the dealership took me for a ride or not tomorrow. I will have her on a lift by noon. I appreciate the input gentlemen. Thank you.
  21. Jan 8, 2020 at 11:05 AM
    I would think you would be squealing like crazy if you were down to 1mm.
  22. Jan 8, 2020 at 12:40 PM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    My pads lasted until 76k before I needed new pads.
    However, I had to have the front rotors turned at 17k and 35k. Then I replaced them at 76k and turned the rears.
    I also think I am a hard on brakes. Sometimes I drive it like I did my Z06 on track days. Probably doesn't help.
  23. Jan 8, 2020 at 3:40 PM
    Doylfish
    Doylfish New Member
    This sounds a lot like my experiences so far and driving habits .. I’ve made the truck full circle started driving with a 2000s Silverado long bed, graduated to a WRX, then V8 S4, then TDI Q5 and when I got t-boned in that had just become a homeowner so to the Tundra it was .. I think I picked up some sporty driving habits in the middle of things
  24. Jan 8, 2020 at 3:43 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Tundra Limited, 2003 Sequoia SR5, 2006 Tundra Base
    There was a thread* about this. A lot of other owners, including myself, had to replace their rotors around the 30k mark.
  25. Jan 8, 2020 at 4:16 PM
    Doylfish
    Doylfish New Member
    I’m not sure when I started hanging on tundras.com in regards to mileage .. I had signed up on tundratalk first .. I will say I’ve spent a lot more money since I’ve become more active here lol .. and I’m at 52k miles now
