rock chip on hood ?
Discussion in 'Detailing' started by 2010bigdog, May 25, 2018.
  1. May 25, 2018 at 4:11 PM
    2010bigdog
    2010bigdog [OP] New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    i have a rock chip on the center of my hood and was wondering if any of you have used the touch up paint from the dealer and if it came out ok? It's MGM color
    Thanks!
  2. May 25, 2018 at 4:14 PM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    It’s always going to be noticeable. It’ll help, but it’s like using a sharpie to fix an imperfection in black.
    15whtrd likes this.
  3. May 26, 2018 at 5:52 AM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    anyone else ?
  4. May 26, 2018 at 5:58 AM
    Won't be perfect but use some MGM touch up paint. Should be good enough to make you forget about it until one of us sees your truck and says," Hey, that's where you touched up that rock chip." Haha.
    RLHULK likes this.
  5. May 26, 2018 at 6:00 AM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Your killing me lol !!
  6. May 26, 2018 at 6:02 AM
    Seriously, we have some very good detailing guys here that may have a better fix short of repainting the whole hood.!
  7. May 26, 2018 at 6:03 AM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    That’s what I’m hoping for
  8. May 26, 2018 at 6:24 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Best bet is touch up paint. Build up the paint in layers (leave plenty of drying time between coats) to get it thick as the other paint. It'll look good. Also you may be able to get clear coat touch up to finish it off
    15whtrd and Black Wolf like this.
  9. May 26, 2018 at 7:41 AM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    The dealership will sell you the base color (mgm) and then the top coat which is the clear coat. It's decent stuff out of all the touch up paint I've used it's one of my favorite bottles to use. I've got a black truck and some of the spots I've touched up are hardly noticeable, except the 2 on my hood everyone asks what happened there lol.
  10. May 26, 2018 at 7:45 AM
    15whtrd
    15whtrd Mr. Blonde
    I got pretty lucky with touch up paint on my last vehicle. It had a pretty good chip on the top of the hood. I filled it with a few layers of paint. Then built up more layers of clear coat, then wet sanded it flat. It was noticeable but looked really well done for what it was. From certain angles you couldn’t even see it.
    Pudge[QUOTED] likes this.
  11. May 27, 2018 at 7:07 AM
    Riskyguy
    Riskyguy New Member
    Stewart
    2018 Tundra SR5 Crewcab
    What grit sandpaper did you use for the wet sanding?
  12. May 27, 2018 at 1:17 PM
    Neilvice
    Neilvice New Member
    Neil
    2018 crewmax limited
    I do touchup and mobile paint repair for a living. The first thing I always tell my clients is "touchup fixes color, not texture". It's best described as putting flesh colored peroxide on a wound. It's simple to put paint in a rock chip. Trying to match the depth of ? coats of primer, ? coats of paint, and ? coats of clear and level it out is the hard part. Unless you treat it as a paint repair by sanding and painting it, you will notice it. IMO Touchup will always max out as "better than nothing". It is certainly cheaper than re-spraying the panel.
  13. May 27, 2018 at 1:31 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    I have a couple spots on my truck that I touched up with paint from my dealer. I did not wet sand, just applied a couple layers until it filled in, cant notice it unless you look for it.
  14. May 27, 2018 at 1:38 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Get a sticker for your hood, maybe some "racing stripes" :)
    jewsNbrews likes this.
  15. May 27, 2018 at 5:38 PM
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
    Firstly, DO NOT color sand after touching up; it’s too easy to burn through the clear coat. I found a product a few years ago (body and paint forum) that is safe to use, and the results are fantastic. That product is Langka Blob Eliminator https://www.amazon.com/Langka-LANGK...467005&sr=8-1&keywords=langka+blob+eliminator
    First fill the chip area with factory touch up; may take several coats. Don’t worry about the buildup, or blob. Follow the instructions provided with the Langka product, and you will watch the blob flatten just as though you are sanding. You can literally level and smooth the touch up without causing any damage to your base coat or clear coat. I’ve used this on white pearl tri coat paint and you cannot see the chip areas. Great product. It only works with OEM (factory) touch up paint.
