Rinse less/Waterless wash thread
Discussion in 'Detailing' started by SouthBoundSteve, Sep 22, 2016.
  1. Sep 22, 2016 at 12:18 PM
    SouthBoundSteve
    SouthBoundSteve [OP] New and Improved Ron is Right!
    Where the skies are so blue!
    2015 White Tundra Crew Max SR5/Off Road
    Bilstein 6112's and 5100's, Husky floor liners, etc..
    Hi all,
    I figured this would come up sooner or later so, over a couple postings, I'll go into what these techniques are.
    So to start out, we'll take a look at some definitions, as used from the Auto Detailing Guide at Detailed Image...http://www.detailedimage.com/Auto-Detailing-Guide/Dictionary/#letter-U
    Washing- The cleaning of the vehicle's exterior in order to prep it for the following steps, usually the decontamination step.
    Waterless Wash- A product with a high concentration of polymers designed to quickly emulsify and encapsulate dirt and grime for safe removal with minimal water usage.
    Now they didn't have a definition for a Rinseless Wash, which is sometimes interchanged with Waterless Wash, but this method uses 1 -2 buckets, microfiber towels for washing, drying towels, a solution, and water for your buckets. No water is needed for rinsing.
    There are some great benefits to doing this type of wash some of those being,
    1. Very little water needed
    2. For those living in apartments, townhouse, and condos
    3. Those living in communities where using a traditional wash of soap and water are not allowed.
    4. Drought restrictions
    5. Cold weather where using a hose is not feasible.
    6. Better for the environment, little to no runoff.
    7. Saves time
    8. Whatever else you can think of...:D
    Waterless Wash can be done with a spray bottle of premixed water solution and it is directly sprayed on to the vehicle and a good quality microfiber towel to absorb/clean/buff the surface. For those who use quick retailers this will remind you of that but, so I have read, the waterless wash will give you more lubricating capabilities. Some products offer an additional agent that will actually provide some protection, like a wax like or sealant. Some do not but will leave the surface slick regardless.
    Here is one of my favorite products to use...
    The Ultimate line is now going to offer a second product, the one on your right, that now has an acrylic agent in it to add some protection.
    Now the great debate, when is my vehicle TOO dirty for this type of wash? This is where common sense come in. What I can tell you is that in the winter months here in N.J., I will go to my local self serve car wash bay and utilize the pressure washer and water only. This removes the heavy stuff and then I can go back to my warm garage and begin the process. If at all in doubt, then don't do it. Improper wash techniques can and will induce swirls and scratches.
    In my next post, I'll go into the process of a Rinseless wash, products, steps, and so forth.
    Fishman57, rons23, 1UPPER and 6 others like this.
  2. Sep 22, 2016 at 5:36 PM
    SouthBoundSteve
    Ok, so for actually doing the Rinseless Wash. I had received a free test sample of Ultima'sWaterless wash with Acrylic added in. For this post, I had completed my Tundra and had the thought afterwards to do this so I did the next vehicle up. This is our 2000 Honda CRV with 220,000 miles on it. It was about due for another layer of sealant so I figured I would kill 2 birds with one stone.
    I then set up my one bucket and 4 Everest Microfiber towels. The directions call for 2 ounces of UWWA to 3 gallons of water. A quick swirl and then dump the towels right into the solution and allow to soak for a few minutes.
    Some folks will use 1 towel and either resoak it in the solution or have a second bucket of just water to rinse it. I have found this way better so as to reduce the chances of introducing debris that could swirl and scratch your paint.
    While the towels are soaking, I'll make a spray bottle of solution. As per directions, add 1 ounce of solution to 22 ounces of water. Another method would simply be take the solution water from the bucket and add it to the spray bottle.
    Next, while the vehicle is cool I spray some solution from the bottle onto the vehicle. I then grab a towel out of the bucket, fold it into fours, and then wipe down the surface. I initially didn't think the hood was as dirty as it was but...
    I then flip the towel, unfold and resold using a clean side, and redid the hood. I then followed up by using a waffle weave drying m.f. towel to dry the section I just cleaned.
    I'll conclude in my next post.
  3. Sep 22, 2016 at 6:07 PM
    SouthBoundSteve
    After competing the hood, I moved to the roof, windows, sides,and finally the wheels. Keep in mind as you move on to a section, you want to expose a clean side of the solution soaked towel. By folding the towel into fours, you will have plenty to work with. One the towel is completely used, I place the towel into a bucket with some All Purpose Cleaner and water.
    After cleaning each section, follow up with a drying towel before moving on to the next section. Also when doing your wheels, have towels dedicated to the wheels only. Repeat the section if needed.
    When I was completed here is what I had...
    My truck after doing a Rinseless wash...
    So to wrap up, as you research this and watch videos, you will see different people use wash mitts, 1 towel, 1 bucket, 2 buckets, etc... I have found this way to be my favorite. I like using multiple towels and 1 bucket. Once a side is used, I don't use again.
    There will be times when a good old fashion soap was is needed over this method but this method is fast and easy.
    There are a different companies that offer their brand of solution so find the one that meets your needs. I have tried a few different ones and I have found Ultima to be my favorite.
    Thanks for looking!
  4. Sep 22, 2016 at 6:18 PM
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    i think you just saved my life... I HAAAAATE washing this truck, haha, there is so much to it and after washing and drying (i wash a panel, rinse it and my mit, continue. usually using two or three buckets to get debris out. Then drying that big mofo). I would do this once or twice a week just to maintain cleanliness since its not as difficult to dry and wash. Just so happens i washed it this morning, i wanna go to the auto parts store and get some of those dusters to clean the inside of my dog's hair (a never ending job), if they have this stuff there im buying it and starting this next week.
    Also, awesome write up, very detailed :thumbsup::thumbsup:
    SouthBoundSteve [OP] likes this.
  5. Sep 22, 2016 at 6:22 PM
    SouthBoundSteve
    Btw, I tried getting the leaves off the driveway but it's that time of year. I was fighting a loosing battle...lol
  6. Sep 23, 2016 at 1:10 AM
    driverdog
    driverdog New Member
    Virginia Beach
    2015 Inferno pro
    Nerf step bars spray in bed liners window tint integrated brake controller
    Steve,
    I always wondered about these products and how to apply them. Nice write up!
    Vehicles look great!
    Thanks,
  7. Apr 15, 2018 at 2:03 PM
    Cuzin Eddie
    Cuzin Eddie New Member
    Shane
    2014 CM Black Platinum 4X4
    TRD Supercharged * BDS 4.5 level with Fox Shocks * AMP running Boards * Bed Rug, Spyder Headlights with HID Conversion * 46 Gal TransferFlow Fuel Tank * Fuel 2 Piece Hostage Wheels * 35" Toyo RT's * Backflip Bed Cover * Pioneer Avic NEX8200 with Amp, Speakers & Subs * Trailer Tow Mirrors * N-Fab Bumper Bar with 30" Vision LED Light Bar *
    I use Optimum no wash products. I love them and my black Tundra looks really good being that it is 4 yrs old and sits out in the 110-115* weather in Southern Utah.
  8. Apr 15, 2018 at 2:22 PM
    Voyagermike
    Voyagermike New Member
    California
    2017 TRD PRO
  9. Apr 16, 2018 at 7:19 AM
    War Machine
    War Machine Premium Elite Member
    Houston, Texas
    2017 Black Crewmax SR5 Blaaaack
    I alternate between Optimum No Rinse and Carpro Ech20. Both products work very well. I give a slight edge to Ech20, as it seems to leave a little better shine and coating.
  10. Apr 16, 2018 at 8:53 AM
    smslavin
    smslavin On a plane...
    Denver, CO
    2016 Tundra CrewMax SR5
    i've been really happy with adam's waterless wash for quick cleanups and the rinseless wash when things are a bit dirtier. after using either of those, i always follow up with some detail spray. i've been super impressed with both and haven't done a full wash in months. full spring detail will be coming in the next couple of weeks.
  11. Apr 16, 2018 at 9:46 AM
    ToyotaTundraMike
    2015 Tundra
    Gonna have to give the waterless wash a try. Always getting dirty water marks a few days after washing from it always raining here. Would love something quick and easy to touch it up 2-3 days after the real wash to keep it from getting bad. Thanks for the review Steve!
  12. Apr 16, 2018 at 10:16 AM
    Nike21
    Nike21 New Member
    2018 SR5 CrewMax TSS 4X4 Black Beast
  13. Apr 16, 2018 at 10:18 AM
    SouthBoundSteve
    I currently use Echo2 from Car Pro. Before that Ultima Waterless Wash was my go to and wouldn’t hesitate to use it again.
    I’ve used both ONR and ONR plus and they are fine too.
    Nike21 likes this.
  14. Apr 16, 2018 at 10:19 AM
    SouthBoundSteve
    It’s great for quick cleanups when you don’t need to drag out the arsenal. Also, for our friends in Cali, you maybe ina community where you can’t wash old school.
