Right Rear Brake Light not working when brakes applied.
Discussion in 'Lighting' started by WettrockCo., Aug 20, 2019.
  1. Aug 20, 2019 at 6:17 AM
    WettrockCo.
    WettrockCo. [OP] New Member
    Kevin
    2016 Super White Tundra TRD Double Cab
    2016 Tundra right rear brake light does not activate when brakes are applied. All lights in the tail light are working when the lights are on, but does not light when breaks are applied. The bulbs have been replaced and still no light when brakes are applied.
    Thanks
    Wettrock
  2. Aug 26, 2019 at 11:45 AM
    Shephard_Of_The_Tundra
    Shephard_Of_The_Tundra DIY try guy
    Corpus Christi, TX
    2016 Black Tundra SR5 4.6 DC 2WD
    Morimoto 2 stroke H4 LED Headlight Bulb VLEDs 3157ck Amber Triton V6 TurnSignal Auxito LED reverse bulbs OEM Toyota LED smoked fog lights Auxito LED T10 license plate bulbs Auxito LED T10 Side marker headlights LASFIT LED T10 3rd brake light Xenon Depot T10 LED Bed/Brake Lights TRD Off-Road Black/Chrome Wheels Bridgestone Duellers 255/70/R18 Front & Rear TRD Sway bars MBRP Dual side exhaust exits Drop-in K&N air filter TRD air flow accelerator Toyota Rubber floor liners OEM Rear under seat storage box Kenwood DMX7706S head unit TRD Shifter knob Center console organizer tray Dual USB fast chargers center stack
    Have you checked your fuses?
  3. Aug 26, 2019 at 1:13 PM
    WettrockCo.
    Kevin
    Yes fuse was good, found the issue two bad bulbs in a row on the brake filament.
    Thanks
    Wettrock
