Ride Rite airbags installed.
Discussion in 'Suspension' started by BTBAKER, Mar 30, 2019.
  1. Mar 30, 2019 at 2:57 PM
    BTBAKER
    BTBAKER [OP] DIFFERENT NAME. SAME JUNK.
    Brad
    Castle Rock
    2023 Ram Rebel
    Some what of a pain on the drivers side. Took me roughly 4 hours taking my time. Lifted the rear with 7 psi about a half inch.
    Shredded a couple knuckles. Looking forward to towing the boat with them.
  2. Mar 30, 2019 at 5:49 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I really like mine. Didn’t think they were to bad to install, but it is the third time installing on a tundra.
    BTBAKER[OP] likes this.
  3. Mar 30, 2019 at 6:28 PM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    I fought the left side for a little bit. The plate needs to be right. I had to flip it once. Moving the fuel module was somewhat of a pain. Your right though, not terrible and I feel like it helps make the rear more stable. I think I would knock it out a lot quicker next time.
    Black Wolf and Omohundro[QUOTED] like this.
  4. Mar 31, 2019 at 7:42 AM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    I didn’t saw off the bumps stops. I loosened the U bolts and pulled them off. I’m not sure why they say saw them vs remove.
    monaco730 likes this.
  5. Mar 31, 2019 at 8:15 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Here it comes!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    :worthless:
    BTBAKER[QUOTED][OP] likes this.
  6. Mar 31, 2019 at 9:27 AM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    Look at those beauties!
  7. Mar 31, 2019 at 7:54 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    I've got a set and love them, so much better when towing. None of that white knuckle shit.
    Watt maker and BTBAKER[OP] like this.
  8. Apr 1, 2019 at 2:14 PM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Am i to assume that these will not work if you already use a WDH w/4pt sway control?
  9. Apr 1, 2019 at 2:27 PM
    15whtrd
    15whtrd Mr. Blonde
    I don’t see why it wouldn't still work. But I would want to set up the weight distribution hitch and sway control before airing up the bags. Try to get it properly leveled first as much as you can.
    OP, do you do much off-road? The reason I ask is, I have heard the bags can get messed up with a lot of off road articulation. Many here suggest going with some Daystar cradles that help keep the lower part of your bags located.
    GNTundra likes this.
  10. Apr 1, 2019 at 2:46 PM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    2018 White Tundra Limited DC 4x4 TRD
    BFG KO2s, TRD Rear Sway Bar, Firestone RideRite Air Bags, B&W Gooseneck Hitch, Trail Ridge Extendable Towing Mirrors
    I installed Firestone RideRite air bags and removed the bump stops instead of sawing off too. Not sure how a cradle would protect the bag. I thought cradles are used when one end of the bag isn't attached. Mine are attached to the truck and the rear end. Did you guys tee the airlines or run separate lines?
  11. Apr 1, 2019 at 2:49 PM
    15whtrd
    15whtrd Mr. Blonde
    OK then I think it’s to keep the bag from tearing and it lets them separate instead of tearing.
    BTBAKER[OP] and KMG[QUOTED] like this.
  12. Apr 1, 2019 at 4:19 PM
    Omohundro
    Jody
    McMinnville TN
    Agree, I would like to have the cradles and I don’t off road at all.
    KMG and 15whtrd like this.
  13. Apr 1, 2019 at 7:42 PM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    I don’t, Sean. Sadly, my Tundra stays on pavement most of the time and some dirt roads. I would defiantly not recommend the bags if you’re off-roading.
    Black Wolf and 15whtrd[QUOTED] like this.
  14. Apr 1, 2019 at 8:19 PM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    I ran them separate. I considered the T but these things hold so little air to get the pressure I didn’t think it would be a big deal. I popped them out on the lower plastic of the bumper below the sensors on back. I’m not sure I gave that enough thought but I can live with it.
  15. Apr 5, 2019 at 6:49 PM
    Shelbie67
    Shelbie67 New Member
    Blake
    NorCal
    2018 tundra crewmax platinum
    RADFLO 2.5 suspension, apex rock sliders, BFG KO2, exhaust delete, Full Active Stereo
    Running together gets ride of your sway control...
    I’m gonna keep mine that way due to the roads I tow on
    Where did you buy from and $?
  16. Apr 5, 2019 at 6:53 PM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    Are you saying it’s better to run separate? Amazon. 303 bucks shipped
  17. Apr 5, 2019 at 6:59 PM
    Shelbie67
    Blake
    NorCal
    Correct, individual air bag control is better for “sway” reasons....
    It prevents the air from transferring from one bag to another when cornering
    Thanks for the price!
    TomC843 and BTBAKER[QUOTED][OP] like this.
  18. Apr 5, 2019 at 7:02 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Cradles protect the bag because they take the place of the bolts that attach them to the axle, so the suspension can fully droop and the bags wont rip or prevent full droop
    I would run separate lines, if the load shifts then the air in the bags could shift in the opposite direction. So if the load in the bed shifts to the right side of the truck when making a left turn, the air would shift from that right bag to the left where there is less load, causing a more uneven load, and increase the chance of rolling over.
  19. Apr 5, 2019 at 7:46 PM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    Good info. Glad I ran them separate. Thanks
  20. Apr 9, 2019 at 5:00 PM
    bslice17
    bslice17 New Member
    Not to highjack your post, BUT.
    I don't offroad super intensely, but I do enjoy exploring basic jeep trails and dirt roads to get to secluded spots. My tundra is still my daily so I want to be able to drive it home and not stress the truck. Is it still a bad idea to get airbags? I am simply looking for a more comfortable ride and adjustable rebound for both on and offroad. Does anyone have any insight as to why I shouldn't get airbags?
  21. Apr 9, 2019 at 5:16 PM
    Pudge
    CT
    You really only need them for leveling a loaded bed or trailer, or back seat passengers in a Tacoma lol. Those leaf springs sucked on my taco, 2 people in back and I'd be on the bump stops over small bumps. They shouldn't be used for a lift. And if you offroad you should get cradles
  22. Apr 9, 2019 at 5:17 PM
    Creatures 1982
    Creatures 1982 New Member
    2017 SR5
    Anyone that run air bags should really consider cradles. They keep the stress off the bags when the truck is lifted off the ground for oil changes etc or off road articulation.
    17 imho all trucks that are used as a truck should have air bags. They really help with a load in the bed or pulling any trailer to be level. I have run them for 10 years on Tacoma and Tundra .
    OP you will love them
  23. Apr 9, 2019 at 5:57 PM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    Thanks! I’ll look into cradles.
  24. Apr 12, 2019 at 10:24 AM
    dumbassdave
    dumbassdave Member
    Dave
    2016 Crewmax Limited
    For those that have installed cradles, is it as simple as undoing the bolt holding the bag on the bottom and screwing in the cradle down? Would I have to take everything off?
  25. Apr 12, 2019 at 7:20 PM
    Creatures 1982
    2017 SR5
    Take the screw out of the bottom of the bag
    Screw cradles to lower bracket
    Your done bag just sits in cradle
    Maybe 1/2 job very easy
  26. Apr 12, 2019 at 10:09 PM
    TSAV14
    TSAV14 New Member
    2018 Toyota Tundra Crewmax 4x4
    I am installing my airbags/cradles tomorrow. With my +3 Coachbuilder shackles the overall height between frame and top of leafsprings is 1" larger than the airbag assembly. I was hoping that adding the cradles and putting air in the bags would solve the problem. Is it possible to use a spacer and the cradles? The only time it seems it might be an issue is when I have no weight in the bed, which is extremely rare for me.
  27. Apr 12, 2019 at 10:22 PM
    fishing guy
    fishing guy New Member
    Billy
    2017 White Platinum 4x4 Tundra
    N/A
    what is the benefit of using airbags? (I tow a boat as well but dont know the benefits of airbag)
  28. Apr 12, 2019 at 10:28 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    Dang! Heavy hitter! LOL
    Pudge[QUOTED] likes this.
  29. Apr 12, 2019 at 10:30 PM
    Aerindel
    Aerindel New Member
    Montana
    FYI, Airlift brand bags specifically say that its okay to lift the truck by the frame and let the axle hang from the bags. Thats why I choose them over Firestone.
  30. Apr 16, 2019 at 5:06 AM
    Zero One Actual
    Dear baggers, I just posted another thread about my suspension newbie question and have received no feedback.
    I have a 2019 crewmax 4x4. I have a decked storage system and a leitner designs rack. Empty these both are a combined added weight of about 300lbs in the bed. I have 6112 at 1.9 and 5160 rear. My question is for added weight in the rear. Do I bag it or do a leaf spring or is there another option? I am using my truck in the south east. So no mountains or articulation. Dirt and gravel roads for hunting and fishing and daily driver. Thanks for any advice or sarcastic comments.
    P-Factor and BTBAKER[OP] like this.
