Reweld Cut Rear Crossmember to Tundra Frame
Discussion in 'Suspension' started by Tundra Enthusiast 5.7L V8, Mar 21, 2022.
  1. Mar 21, 2022 at 12:06 PM
    Tundra Enthusiast 5.7L V8 [OP] New Member
    Jeffrey
    2019 Tundra Limited 4x4, 2016 Tundra 1794
    Hello, I have a 2017 Tundra that I put a 6 inch Pro Comp lift a year ago and now I removed the lift because I could not get used to it and missed the factory ride and saved the piece that I cut out. How hard would it be to be to reweld it? I have the piece with me to weld but would need a shop to reweld since I do not know how to weld it.
    Here are some pics.
  2. Mar 21, 2022 at 1:11 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I think it would be very difficult because you can't weld some sections of it, like the top part. You'd have to remove the engine to get to it.
    @snivilous might have better input since he actually knows how to weld.
    landphil and snivilous like this.
  3. Mar 21, 2022 at 1:17 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    295k Supercharged 2008
    Hahahahaha, I didn't know what I was in for being tagged; "snivilous can weld, ask him". Awesome :rofl: I'm honored that I was the one referenced out of I'm sure thousands who can weld on the forum lol
    OP that would be an easy couple hours. The shop should bevel the frame side, bevel the part you have, throw a weld on it and you're good to go. If it was me I would add some overlays (often called fish plates, like diamond shaped pieces that go over the weld and are welded on, just so you have more than a butt weld holding the metal together). There's nothing that needs very exacting tolerances since it's just the cross member, and with how clean it looks like you cut it it'll be a walk in the park. I forget if anything mounts to that (like skids?), if anything does bring those pieces so they can be used as guide parts when tacking.
    If you brought that to me... I'd probably estimate like $400 with the MIG (figure $100hr x 4 hours?) that seems reasonable. Grinding, sanding, acetone, tack/fitment, weld, plasma cut overlays, weld those. Without crawling under my truck and based on your pictures I don't see anything overly bitchy to reach.
    Cruzer[QUOTED] likes this.
  4. Mar 21, 2022 at 1:26 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    That's the crossmember where the front diff rear mount bolts to.
    snivilous[QUOTED] likes this.
  5. Mar 21, 2022 at 1:27 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
  6. Mar 21, 2022 at 1:28 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    :rofl:he gave me the BDS drop brackets that he used to have on his truck :yes:
  7. Mar 21, 2022 at 1:32 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Nice. I have the zone off-road 5” lift(same as BDS) and at one point I was going to take it off and he was gonna do the work. He knows his stuff.
  8. Mar 21, 2022 at 1:32 PM
    snivilous
    SW UT
    Ah. My response still stands. 4 hours on the high end.
  9. Mar 21, 2022 at 1:34 PM
    Jeffrey
    Where are you located?
  10. Mar 21, 2022 at 1:44 PM
    snivilous
    SW UT
    Near St George Utah, but I don't usually do fabrication work, I just happen to have the toys and play with them :D for real any halfway competent shop should be able to do this easily. Look around for any offroad or UTV shops, or get on a local car page, ask any local mechanics who they know that does welding, guys who build railings and stairs and gates, etc. Try and get some pictures and reviews of the work they do, a lot of fabrication (even big name shops) can suck at their job, so just vet them appropriately. You don't need someone who builds racecars, just a guy who can lay a good bead and is willing to reach the top side even though you can't see it very well.
  11. Mar 21, 2022 at 2:41 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    Reg Cab Gang
    Piece of cake. Butt weld it with a couple plates and be done with it.
    Hbjeff likes this.
  12. Mar 21, 2022 at 3:03 PM
    Jeffrey
    Is it also possible to weld custom weld plates and run it through without using my old cut piece?
  13. Mar 21, 2022 at 5:24 PM
    Half Assed
    Heartland Florida
    Reg Cab Gang
    Sure, but welding the old piece back in would probably be easier.
  14. Mar 21, 2022 at 5:51 PM
    Jeffrey
    Just went to one of the best welders in my town and he said the front diff and the exhaust manifold would have to be removed for him to do the work and is charging $800 for it to be complete
  15. Mar 21, 2022 at 5:58 PM
    Half Assed
    Heartland Florida
    Reg Cab Gang
  16. Mar 21, 2022 at 6:15 PM
    Jeffrey
    El Paso, TX
  17. Mar 21, 2022 at 6:19 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The front diff is going to be removed anyways when un installing the lift kit….the challenge is where the work will be done. Any custom jeep builders or something like that?
  18. Mar 21, 2022 at 7:40 PM
    Jeffrey
    Truck drives fine without that cut piece on but I want to put it just in case of an accident or something because the frame can bend with impact and is now weaker
  19. Mar 21, 2022 at 8:34 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Oh the lift is already off. Yeah you definitely need to get that thing patched up. Its very doable. Shop around
  20. Mar 21, 2022 at 8:39 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    That's a $1000 job. There, I said it.
    Hbjeff likes this.
  21. Mar 21, 2022 at 9:03 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    $800 doesn’t sound bad at all if he is removing and re installing the diff. Thats a few hours of work on top of the welding
    alb1k likes this.
  22. Mar 21, 2022 at 9:14 PM
    Jeffrey
    I'm going to weld the cut piece back in 2 weeks, guy said it will 2 to 3 days because he has to remove front diff and exhaust manifold so he can have enough room to weld it back.
  23. May 15, 2022 at 6:46 PM
    Jeffrey
    Will be taking truck tomorrow to get the cut piece welded. Took longer as I was busy. Cut piece fit perfectly fine. Frame did not bend at all. Any suggestions as to where the welder should put the fish plates?
  24. May 17, 2022 at 9:39 AM
    Jeffrey
    Cut piece is now welded back on. Will go back next week for them to put a steel plate underneath and on the sides where the cam bolts are
    Kiddnapped Tundra and snivilous like this.
  25. May 17, 2022 at 9:45 AM
    snivilous
    SW UT
    Hopefully they'll clean the steel when they weld the fish plates on.
  26. May 17, 2022 at 9:54 AM
    Jeffrey
    I’ll let them know next week
  27. May 17, 2022 at 10:06 AM
    snivilous
    SW UT
    I'm sure (hope) they'll do that. Maybe my expectation of fab shops is too high. It'll hold either way.
  28. May 17, 2022 at 3:28 PM
    Jeffrey
    Will it also hold perfectly fine even without fish plates on considering that the weld is super thick?
  29. May 17, 2022 at 4:35 PM
    Half Assed
    Heartland Florida
    Reg Cab Gang
    If it was me i probably wouldnt even bother putting fish plates on, but your truck still has a lot of life left it compared to my junk.
    Why does it look butt welded in 4 spots? Was the crossmember cut out in 3 pieces? In that case I would plate it
  30. May 17, 2022 at 6:10 PM
    snivilous
    SW UT
    I think it'll hold, if it was me I would do the overlays just to be safe and sexy about it. Considering how half assed their job looks I would do the overlays since who knows how good the penetration is considering they couldn't be bothered to clean the metal.
    TheBeast likes this.
