Reverse pin/plug not working
Discussion in 'Towing & Hauling' started by Mcb ZX225, Jun 24, 2019.
  1. Jun 24, 2019 at 7:29 AM
    Mcb ZX225
    Mcb ZX225 [OP] New Member
    Mark
    2019 TRD Limited
    Wanted to post what I have going on to see if anyone else has had the same experience. My 19 Tundra is not getting the reverse signal from I believe the plug from the truck. The reverse solenoid is not unlocking when the truck is put in reverse and my reverse lights on my trailer don't work as well. Everything else works perfect. I'm not sure if it is going to be the reverse wire lose or not hooked up or a bad plug on the truck side. Will be taking it to the dealer this week just wanted to see if anyone had seen this. This for any info. Thanks
  2. Jun 28, 2019 at 6:30 AM
    Mcb ZX225
    Mark
    2019 TRD Limited
    Ok, update. I feel a little silly reporting but...the dealer popped the fuse box in the engine compartment and found that the reverse/backup fuse was missing? I'm way glad it was an easy fix but didn't really expect a fuse to be missing on a brand new truck. Glad it is fixed.
  3. Jun 28, 2019 at 6:54 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Always check fuses first that’s my motto
    Watt maker likes this.
