Retrofits...
Discussion in 'Lighting' started by cbarne5, Apr 17, 2016.
  1. Apr 17, 2016 at 8:33 PM
    cbarne5
    cbarne5 [OP] New Member
    2014 White 1794 CrewMax 4x4
    I'm currently having retrofits made for my truck. Question is can I tap the halo into my LED DRL? If so which wires are which on the DRL?
  2. May 3, 2016 at 1:44 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Yes. Not sure off hand of which wires.
  3. May 3, 2016 at 5:44 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I don't have LED DRL's BC I have an SR5, but I used an add a fuse in the fuse box. While I was in there I saw a fuse for the LED DRL's, obviously mine was empty. That may be you cleanest option. I posted a DIY which shows how I used the add-a-fuse, pretty straightforward though...
    My DIY link is in my Sig, if you are viewing this from your mobile device, turn it sideways to view Sig's.
