Restoring Headlight Kit & Looking For Parts
Discussion in 'Lighting' started by LegitRubio, Aug 16, 2018.
  1. Aug 16, 2018 at 11:29 AM
    LegitRubio
    LegitRubio [OP] New Member
    Jeremy
    2008 Slate Metallic Tundra SR5
    So I've been looking at the forums, and I saw pros and cons to the Sylvania Waxes & Treatments Headlight Restoration Kit. Was wondering if it actually worked. My headlights aren't the worst but they definitely need to be restored. I was also wondering where I could get a replacement front bumper as well as a short "stubby" antenna.
  2. Aug 16, 2018 at 11:44 AM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    I used the 3M headlight restoration once. It actually worked quite well, just gotta keep up them with waxing after to treat them.
    Not sure on the front bumper part but check out AntennaX. They have several antenna options. But you also risk possibly losing some service. If you live in/by a big city you probably wouldn’t notice an issue.
  3. Aug 16, 2018 at 12:26 PM
    LegitRubio
    Jeremy
    Not worried about the reception as I do live in the city and prefer to play music off of my phone, but thanks! And do you know if clear coating would make them last longer?
  4. Aug 16, 2018 at 12:38 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Black Wolf likes this.
  5. Aug 16, 2018 at 1:45 PM
    bvia
    bvia New Member
    2013 Texas Edition Tundra 2WD 4.6 DblCab
    None
    Sylvania headlight restoration kit. Hands down the best DIY kit, IMHO. Brought wife's '05 Mazda headlights back to day-one condition. Then I used the WeatherTech headlight covers so no need to continue re-polishing and reapplying the UV clear coat. There's a reason it's rated #! by Consumer Reports...consumers believe it is the best.
    hth,
    B
  6. Aug 21, 2018 at 1:06 PM
    Noel
    Noel New Member
    Noel
    2008 Tundra Crew Max
    Thanks, Trooper2. I bought the Meguiar's product this past weekend...glad you liked the results.
    I read the instructions...seemed easy enough. Any additional instructions you can offer?
  7. Aug 21, 2018 at 1:09 PM
    hillbillypharmacist
    hillbillypharmacist New Member
    2013 Tundra DC TSS
    I've used the 3M product on several cars, always looked much better. I think they went to a kit with a packet of clear coat, before it was rubbing compound.
  8. Aug 21, 2018 at 1:22 PM
    If you have a polisher this stuff works great!
    I know it's not called headlight restore but has worked great for me every time better than the stuff made to restore them.
    Pudge likes this.
  9. Aug 21, 2018 at 1:27 PM
    I've used the 3M headlight restoration kit for my T100, I like it, does the job, haven't had to use yet on the Tundra
  10. Aug 21, 2018 at 1:38 PM
    Professional Hand Model
    Hand Protectors
    Bought the 3M kit years ago (sanding pad for drill with varying grit paper and multiple liquid compounds) for $30. It worked ok and lasted a year then the yellow dullness came back again. Did the process again with a lesser result than first time. Too much work for the diminishing return.
    Ended up buying 2 new lens for $50 and they are holding up very well for 5 years now. The newer crystal clear acrylics are a better formula/longevity than the older stuff. New lens took less time than that 3M method!
  11. Aug 21, 2018 at 2:04 PM
    Noel
    Noel New Member
    Noel
    Professional Hand Model - where did you get the lens? $50 for the pair?
  12. Aug 21, 2018 at 2:14 PM
    Hand Protectors
    5 years ago and believe it was Rockauto? Even came with bulbs! No way you’d get that deal today. Just the lens are at best $89, but there is a better selection in terms of the darkness variations not available 5 years ago.
  13. Aug 23, 2018 at 9:04 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    You could wet sand and polish them. Then apply a clear lacquer over the lens. Likely will work better and last longer than restore kits.
  14. Aug 24, 2018 at 3:56 AM
    Hand Protectors
    This is what I did on my fog lamps.
    Pudge[QUOTED] likes this.
  15. Aug 24, 2018 at 6:47 AM
    bvia
    bvia New Member
    None
    This is what's in the Sylvania system's box. Polish then liquid primer then wipe-on, self-leveling, UV resistant clear coat.
    B
