Replacing inner tie rod part options
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jimes, Aug 7, 2022.
  1. Aug 7, 2022 at 8:07 AM
    Jimes
    Jimes [OP] New Member
    Bay Area, California
    2015 toyota tundra trd pro
    So I need to change out my inner tie rods on my 2015 pro and I’ve seen several choices out there to choose from. OEM $226(toyotapartsdeal.com), same part number and part supposedly on eBay for $117(genuinepartsglobe on eBay). Not sure if it’s a knock off or the real deal. Then there’s all kinds of cheap shit I see online for 2 sets of inner and outer rod ends for under $100. Like TRQ sells a set of two inner tie rods for $50. There’s moog as well for like $42 a piece. What have you used and how is it holding up? Felt like my stock inner tie rods didn’t last long. When I replaced my outers for coachbuilders outers the inners were loose that they just flip flopped around. That was at like 30k. Didn’t know much about them at the time and know now that them being that loose is a bad thing. Also noticed the original part number was replaced by another inner tie rod part number. Used to be 45503-0C020 and is now 45503-0C030. Wonder if they changed it cause the OG ones didn’t last long. Any input on what you used on your truck would be appreciated. Thanks.
  2. Aug 7, 2022 at 8:12 AM
    Jimes
    I usually use OEM parts if I can’t upgrade them with better parts. But since nobody makes stronger inner tie rods I’m thinking about going OEM, but since mine didn’t last that long, not sure if it’s worth it and to just use cheap shit and replace it more often or risk paying the higher price and it still goes out quick. I do my own alignments at home so not worried about doing them more often. I assume going on washboards, rocks and ruts and trails at a decent speed doesn’t help them out either which is what I use my truck for.
  3. Aug 7, 2022 at 8:57 AM
    Vizsla
    Vizsla ☠️☠️☠️
    Do your tie rods hit the coilover when turned at/near full lock? If so could be some accelerated wear on the inners. I assumed that maybe inners are not designed to see the side load that occurs on contact. Inners - push pull, outers - side load is the push pull if that makes any sense.
  4. Aug 7, 2022 at 9:11 AM
    Jimes
    No contact on anything. Just know they are super loose. Just like on my GX I fixed yesterday.
  5. Aug 7, 2022 at 9:23 AM
    Jimes
  6. Aug 7, 2022 at 9:24 AM
    Jimes
    That’s how my tundras inner tie rods are. It’s time. Ha ha ha
    831Tun and Vizsla like this.
  7. Aug 7, 2022 at 10:01 AM
    Vizsla
    Vizsla ☠️☠️☠️
    :rofl: I replaced mine at 25k miles, they were the same as yours, but had coilover contact. I always use oem for steering parts, but have no real justification for it due to no experience with aftermarket parts.
    831Tun and Jimes[QUOTED][OP] like this.
  8. Aug 7, 2022 at 10:15 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  9. Aug 7, 2022 at 10:30 AM
    Jimes
    I’m doing ok. Still a little depressed about having to put my male dog down on my birthday last month at 8 years old because of CSD(copper storage disorder). Other than that and bending my steering knuckle on my GX460 at mount Patterson, I’m doing ok. How are have you been? Good I hope and funny you mention that brand. I just saw that this morning. Didn’t know if it was a legit brand. Definitely cheaper option. Was waiting to see if anyone had experience with them. Also, I found them on eBay. Not sure if there’s a more legit retailer. I’m a little weary about eBay. Not really sure how long inner tie rods are supposed to last. Especially when you wheel your truck.
    gkupcak likes this.
  10. Aug 7, 2022 at 10:36 AM
    Retroboy1989
    Northern Utah
    2012 DC 4x4 5.7 SR5 TRD OR Barcelona
    Snug top 20" TRD Sport wheels 275/60R20 Tires Additional Trans Cooler
    Staying tuned.
  11. Aug 7, 2022 at 10:38 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Doing well, thanks Jimes. Sorry to hear about your dog, that's really sad. I agree about ebay. I'm sure you can find a different vendor.
  12. Aug 7, 2022 at 10:43 AM
    SouthWestGA
    SouthWestGA New Member
    I replaced my wife’s 08 sequoia with Moog inner and outer tie rod ends without issue
    the sequoia and tundra part numbers were the same as what I used
    Jimes[OP] likes this.
  13. Aug 7, 2022 at 10:53 AM
    Jimes
    Thanks. I still have my female dog Leela, but it’s definitely not the same household anymore. I’ll look around to see if I find it somewhere else online, but I may just get the new OEM part and see how long it lasts.
    831Tun[QUOTED] likes this.
  14. Aug 7, 2022 at 11:03 AM
    Jimes
    I wonder how long they will last vs OEM? Also, are they starting to rust? Sometimes when I buy cheaper parts painted in black they rust faster for some reason. I live a mile away from the ocean. The thing about inner tie rods is unless you are unbolting your outer rod end you don’t really know how loose it is unless it gets so bad that you can physically move it while all attached. I feel like it’s a part I overlooked for years when checking out all the parts on my suspension before a long trip.
    831Tun and Retroboy1989 like this.
  15. Aug 7, 2022 at 1:41 PM
    SouthWestGA
    No they aren’t rusting. Mine weren’t black
    Jimes[QUOTED][OP] likes this.
  16. Aug 13, 2022 at 8:40 PM
    Retroboy1989
    Northern Utah
