Replacement OEM headlight bulb recommendation
Discussion in 'Lighting' started by Randy1794, Jan 14, 2018.
  1. Jan 14, 2018 at 11:04 PM
    Randy1794
    Randy1794 [OP] New Member
    Randy
    Wentzville, MO
    2014 Tundra 1794
    Guys and gals,
    Got a couple questions for you. I am looking to replace my headlight bulbs in my 2014 for something a little brighter, any bulbs in particular you recommend. My DRL look fine, almost LED like, but my headlights have a yellowish tint. I thought I read somewhere that the worse things someone could do is put LED bulbs in the stock housings, so I am looking for a brighter halogen bulb.
    While I am at it, I may replace my fog light bulbs also. They currently seem ok, but with the recent very thick fog here in Northern California I am looking for a possible improvement.
    Thanks,
    Randy
  2. Jan 14, 2018 at 11:08 PM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    PIAA Extreme White Plus, H4 bulbs
    Ericsopa likes this.
  3. Jan 15, 2018 at 3:10 AM
    Sylvania puts out ZXE Gold which I'm looking into..right now I have Ultras pretty bright for me I have in fogs as well
    OBXTundra and SouthBoundSteve like this.
  4. Jan 15, 2018 at 4:09 AM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
  5. Jan 15, 2018 at 9:26 AM
    iHacker
    iHacker SW TRD PRO
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Bob, MrWrench and Randy1794[OP] like this.
  6. Jan 15, 2018 at 9:29 AM
    PermaFrostTRD
    Northern NY
    limited wannabe, suspension and tire improvements
    These are what I’m running. Can vouch for output and minimal/no glare (I’ve driven past my truck from head on to verify).
  7. Jan 16, 2018 at 4:20 AM
    MrWrench
    MrWrench New Member
    2017 White Tundra limited
    Spray on bed liner, Bak mx4
    I just ordered these yesterday for my truck. I've been wanting too do a LED upgrade but I was hesitant to spend that much money right now. Hopefully these are an improvement over the stock halogen lights
    PermaFrostTRD[QUOTED] likes this.
  8. Jan 16, 2018 at 7:51 AM
    PermaFrostTRD
    Northern NY
    You will be very happy with the result.
  9. Jan 16, 2018 at 8:06 AM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
  10. Jan 16, 2018 at 9:33 AM
    MrWrench
    MrWrench New Member
    Do they connect to the original harness?
  11. Jan 16, 2018 at 3:58 PM
    PermaFrostTRD
    Northern NY
    There’s another piece (I’m not sure what it is - resistor or something that gets mounted) but every thing connects to original harness.
  12. Jan 16, 2018 at 4:19 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    ZXE here
    AJGallo41 likes this.
  13. Jan 17, 2018 at 3:14 PM
    easleycrawler
    Travis
    How much brighter are these extreme white bulbs, compared to stock bulbs? I know the led bulbs are alot brighter. Just wanting to know about the normal bulbs, in extreme white.
  14. Jan 18, 2018 at 6:11 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    Not sure if I still had stock bulbs, the truck is a 2010 and I'm the 2nd owner. But I will say that the ZXE's our considerably brighter and the color temperature is much higher than whatever was in there. I don't have anything scientific and I didn't do before and after shots. I just know that my old bulbs were yellowish/white and I wasn't impressed with the output.
    I'm not convinced the LED technology is there just yet for a straight replacement bulb swap, I think the housing and projector have a lot more to do with the success of an LED than the actual bulb.
    I think I got the ZXE's on Amazon with a coupon code and paid $45 for the pair. I've had good luck with silverstar ultras on previous vehicles and figured these would be a good step up. I was getting 3+ years on the ultras, hopefully these will be the same or better. I have a set of ultras in my Toyota Matrix right now that are going on 5 years. When those finally kick the bucket ZXE's will be going in there place.
  15. Jan 18, 2018 at 10:22 AM
    Ccrames
    Ccrames 2014 SSM CM 5.7
    Nor Cal
    Bilstein 5100s, Method Standard 18x9 +18 offset, 285/65R18 Toyo A/T2 Xtreme, trailer brake controller, bed liner, camper shell. All were on the truck at time of purchase.
    I have the GTR Lighting Led kit for the tundra, bought it from headlightrevolution.com, and the beams are focused, have a pretty clean line where they stop on low beams, and I haven't been flashed by anyone else yet. Also since we have the autoadjusters you can easily tilt them a little farther downward if you like. Well worth the cost and they are direct plug and play type bulbs with a load resistor between them and the factory harness.
    tundraj and YTThao530 like this.
  16. Jan 18, 2018 at 9:12 PM
    MrWrench
    MrWrench New Member
    Where did you mount the LED driver that came with the kit?
  17. Jan 19, 2018 at 1:23 AM
    PermaFrostTRD
    Northern NY
    I didn’t take any pics of my install, but I followed this to a T.
    http://www.tundratalk.net/forums/tu...dlight-bulb-review.html#/topics/603282?page=1
    He has very detailed instructions and great photos. There’s a metal bracket behind the light assembly, where he mounted his. So I put mine there too. I used double sided 3m tape and zip ties.
  18. Jan 19, 2018 at 1:43 AM
    tundraj
    tundraj New Member
    Mine are on their way. Looking forward to it.
  19. Jan 19, 2018 at 4:25 AM
    chphilo
    chphilo Tundra addict
    Western PA
    One mod always seems to lead to another. I didn't have any complaint about the stock bulbs, but after installing LED strips, they looked too yellow. I went with Philips Crystal Vision (halogen). They are not perfectly white, but white enough to not to bother me. I installed them back in 2016 thinking that once these blow, I will get a set of LED bulb. But they are still working fine.
    Here is stock light (in comparison to the LED light. See how yellow they look.
    Here is a picture with Crystal Vision.
  20. Jan 28, 2018 at 10:21 PM
    mtnbiker1978
    mtnbiker1978 New Member
    OR
    2017 Inferno Tundra SR5 TRD Off-road Crewmax
    Do the ZXE's just replace the halogen bulbs? Nothing else needed?
  21. Jan 29, 2018 at 3:50 AM
    Direct replacement
  22. Jan 29, 2018 at 3:51 AM
    Sylvania ZXE blue or gold?
  23. Jan 29, 2018 at 4:32 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
