Replace bumper sensor cap
Discussion in '2nd Gen Tundras (2007-2013)' started by Tomcat, Sep 22, 2017.
  1. Sep 22, 2017 at 12:16 PM
    Tomcat
    Tomcat [OP] Ever see a motorcycle outside a shrinks office?
    2010 SR5 4X4 5.7 20" wheels Metallic Gray
    Bakflip
    I replaced my sensor cap on the front bumper today. It was damaged when purchased the vehicle and finally fell out.
    2. Here is the new cap I ordered off line from Ali Express. It took two and a half months to get here. Only about $5.00 for four of them if I remember correctly.
    3,4. To replace the sensor cap you have to remove the inner fender liner and I ended up removing the foglight as well after taking it loose and putting it back once. Remove the clips with a screwdriver and 2 ten millimeter bolts. This will give you access or you could remove the whole piece to make it easier.
    5. This is the position the sensor cap needs to be installed to keep the sensor upright on the other side. It pops right in.
    6. I was trying to work the sensor out. Couldn't accomplish this without removing foglight.
    7. Bolt removed that holds foglight in then foglight pops out, be sure to twist out the bulb first. Push the sensor in the cap from the backside and put everything back together.
    8. Oh YEAH. Much better.
    0922171351.jpg 0922171352.jpg 0922171354.jpg 0922171356.jpg 0922171408.jpg 0922171413a.jpg 0922171417.jpg
  2. Sep 22, 2017 at 2:42 PM
    Tomcat
    Bakflip
    It really wasn't too difficult. Any questions let me know.
  3. Jun 29, 2021 at 6:07 AM
    tundrapower
    tundrapower New Member
    Tucson, Arizona
    2007 Tundra Crewmax Limited
    Firestone airbags, Sequoia luggage rack
    I know this is an old thread, but do you remember the part number for the sensor retainer?
  4. Jun 29, 2021 at 9:19 AM
    dels67malibu
    dels67malibu New Member
    This is the part number I used: 89348-33080
    Bought them here:
    https://www.ebay.com/itm/254984529475
  5. Jun 29, 2021 at 9:22 AM
    dels67malibu
    The two rear center ones are a different part number: 89348-33030
    kingrosk likes this.
  6. Jun 29, 2021 at 11:51 AM
    tundrapower
    Tucson, Arizona
    Great thanks.
