Removing front "spat" (mud flaps)?
Discussion in '3rd Gen Tundras (2014+)' started by 39 Chev, Jan 11, 2019.
  1. Jan 11, 2019 at 7:53 PM
    39 Chev
    39 Chev [OP] New Member
    2019 Cement Limited
    Quick question guys...
    I put some 275/60r20's on my truck and it's rubbing a little
    when in reverse and wheels turned.
    From reading here, the first thing I'm going to do is remove the front "spat" in front of the tire. To remove them, is it just removing the 2 bolts (took a quick look today and that's what I saw) and they come right off? Do you replace the bolts after you remove them or leave everything off?
    I will probably have to "massage" the front fender liner in the rear a little too, but looks like all you need to do is heat gun and push them back a little.
    Thanks!
  2. Jan 11, 2019 at 8:58 PM
    ARamirez73
    ARamirez73 RÖCKIN' N RÖLLIN' WITH MY TÜNDRA CRÜE
    The Lone Star State, RGV, TEXAS
    2014 CM TSS 4WD SR5 5.7 MGM
    Rough Country 6" lift / 35x12.50R20 Cooper Discoverer ST Maxx/ 20x9 +20 Fuel wheels "Mavericks" (Came with) / S&B CAI/ 2-10" Rockford Fosgates R2/ Massive Audio Nano N2 amp (Came with)/ KatSkins seat covers (Came with)/ Weathertechs window vent visors and floor mats/ 1A-AUTO.com aftermarket tow mirrors/ Undercover tonneau bed cover/ Viper alarm 3305V/ Flowmaster Super 40 Dual in-out/ 40" led light bar/ TRD Pro grille/Rough Country 30" LED light bar/TRD rear sway bar/ Ranch Hand legend grille gaurd/ Nfab nurf bars/ 2019 PRO headlights
    You talking about that mud flap in the front? If so, ther is a small metal bar behind the front wheel well cover that the 2 screws screw into that hold that flap, that bar will be on the other side
    39 Chev [OP] likes this.
  3. Jan 11, 2019 at 9:14 PM
    39 Chev
    2019 Cement Limited
    Yah, that flap. Pull the 2 bolts, flap comes off and then replace the 2 bolts?
    (I watched a Youtube video and an engineer from Toyota called them spats...that's why I used that term).
    ARamirez73 likes this.
  4. Jan 11, 2019 at 9:20 PM
    ARamirez73
    Believe 8mm bolts, but ther is a metal C channel bar behind the wheel well, that'll fall loose
  5. Jan 11, 2019 at 9:24 PM
    gosolo
    gosolo “The .com stands for communist”, Dale Gribble
    Ray
    NW Oregon
    2"CB shackles, bushings and 1 shim, lockerdown console vault, rear folding seat back mod, snugtop shell with opening side windows, 46g fuel tank, SDHQ sliders and hidden winch, Decked Drawers, Icon leaf spring packs and got rid of the interior chrome
    That is accurate. They are actually not mud flaps but they are engineered for improvement of air flow around the wheels to improve mileage.
  6. Jan 11, 2019 at 9:26 PM
    39 Chev
    2019 Cement Limited
    Thanks guys...
