Removing (aftermarket?) steering wheel trim
Discussion in '2.5 Gen Tundras (2014-2021)' started by drh11, Apr 1, 2026.
  1. Apr 1, 2026 at 8:55 PM
    drh11
    drh11 [OP] New Member
    I recently bought a used 2021 SR5 Crewmax. One thing I do not like is that the two vertical black pieces of trim on the steering wheel are raised and grate across your hand after turning and letting the wheel turn back through your hands. The buttons also aren't flush.
    I'm now realizing that this is probably some aftermarket trim that doesn't fit as well. Are these likely stick-on that I could remove, revealing the original looking factory trim underneath? Or will I need to order new trim pieces? Or does it actually come this way OEM?
    EDIT: attaching a photo
    23Tundy likes this.
  2. Apr 2, 2026 at 1:39 AM
    Tripleconpanna
    2021 TRD PRO CM; 2011 SR5 SC'd DC; 2008 SR5 CM
  3. Apr 2, 2026 at 4:07 AM
    Retired...finally
  4. Apr 2, 2026 at 4:47 AM
    JerryH
    JerryH Tundra Teach
    SOMD
    2020 Crewmax Limited Cement
    Welcome! I just replaced mine. Had to take the airbag portion of steering wheel off then unscrew old silver trim. I don’t know of any overlays. Where are you located?
  5. Apr 2, 2026 at 5:29 AM
    texasrho83
    texasrho83 Ye Olde Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  6. Apr 2, 2026 at 6:23 AM
    drh11
    Ok fair, I should have included a picture. I updated my original post. It looks like I can see silver plastic underneath? What does the OEM trim look like? I have seen some videos of replacement involving removing the steering wheel pad. Can the OEM trim be ordered separately or do I have to buy those whole button / control units?
    Tripleconpanna likes this.
  7. Apr 2, 2026 at 6:24 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Those are taped on covers. Pull off and use Goof Off and maybe a plastic razor.
  8. Apr 2, 2026 at 6:34 AM
    drh11
    Thanks texasrho83. I'm a little worried what's underneath is damaged / scratched and that's why the overlays were added? Only one way to find out...
  9. Apr 2, 2026 at 6:48 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    If you like the blacked out theme, buy the actual black trim pieces and remove what you currently have. https://yotaxpedition.com/products/steering-wheel-blackout-surround
    Once you have them off (if you want to keep the silver pieces) it'll be easier to separate the overlay with the goof off that @texasrho83 recommended
    For safety be sure to disconnect the neg battery for about 10-15min since you'll be dealing with the airbag.
  10. Apr 2, 2026 at 7:17 AM
    JerryH
    JerryH Tundra Teach
    SOMD
    Yank em off. See what you got to work with
    Tripleconpanna and Corndog123 like this.
  11. Apr 2, 2026 at 7:27 AM
    Corndog123
    Corndog123 Knife creator.
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Welcome from TN!! I replaced my OEM steering wheel with an aftermarket one from Amazon. I love the new wheel but I didn't replace the inserts with black ones.
    Those black ones look good!
  12. Apr 2, 2026 at 7:39 AM
    lerbud1
    lerbud1 New Member
    Larry
    Waco, TX
    2021 Tundra SR5
  13. Apr 2, 2026 at 7:43 AM
    lerbud1
    lerbud1 New Member
    Larry
    Waco, TX
    2021 Tundra SR5
  14. Apr 2, 2026 at 8:13 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    A little heat to soften the double sided tape, slowly peel off.. should be ok underneath..
    drh11[OP] and Tripleconpanna like this.
  15. Apr 2, 2026 at 5:10 PM
    drh11
    Ok thanks everybody. That was pretty easy. Didn't even need the goo gone, the adhesive strips mostly just pulled right off. The right side was a little scuffed underneath but no big deal. I do kinda like the all black so I might swap them out, but I'm definitely glad the stick on pieces are gone!
  16. Apr 7, 2026 at 9:57 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    THANK YOU!!!! This has aggravated me a long time. I am darn near blacked out but still the damn steering wheel. I have already ordered these in matte black. Huge thanks!
  17. Apr 11, 2026 at 4:01 PM
    panicman
    Eric
    Before-
    New from Meso-
    After-
  18. Apr 11, 2026 at 5:11 PM
    TacomaTRD4x402
    Southern California
    Looks good :thumbsup:
  19. Apr 11, 2026 at 6:02 PM
    drh11
    Nice @panicman ... but why is the left side of your steering wheel swollen??
  20. Apr 11, 2026 at 7:40 PM
    BrandonL812
    Brandon
    camera angle.
  21. Apr 11, 2026 at 8:10 PM
    panicman
    Eric
    It was partially deflated :)
    No, I used wide angle and it distorted the edges of the image!
    BrandonL812 likes this.
