Remove spare tire and add a battery bank for my goal zero unit?!
Discussion in '1st Gen Tundras (2000-2006)' started by mmccoy, Jul 16, 2019.
  1. Jul 16, 2019 at 5:31 PM
    mmccoy
    mmccoy [OP] New Member
    Mark
    06 Tundra DC TRD4x4
    I am thinking about chaining more batteries to my Yeti 400 unit so I can run longer without the truck on. I need space in the truck bed for other gear and can't afford to have batteries taking up the real estate. I'm thinking of removing the spare tire and build a platform for the batteries and a skid plate to cover them. I plan to relocate the spare on a new bumper with a tiregate anyway.
    Has anybody done something similar to their first gen? If so, please post pictures and/or advice.
    Thanks!
  2. Jul 17, 2019 at 4:22 AM
    Professional Hand Model
    Hand Protectors
    Try utilizing that space under the bed between the side wells just in front of the rear wheels. Personally, the spare tire is best located in the factory position for proper balance of the truck so I’d keep it there. Just some ideas.
  3. Jul 17, 2019 at 4:59 AM
    bmf4069
    bmf4069 Yup, that's car parts in a dishwasher
    TX
    02 AC sr5 4wd v8
    Yeah, if you need the need for overland gear, keeping weight towards the center may be best. Kinda how diesel guys put the fuel separators.
    mmccoy[OP] likes this.
  4. Jul 17, 2019 at 5:02 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Following along..
  5. Jul 17, 2019 at 6:52 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Could probably be done but my 2 cents. You'll need to build a very secure platform, you'll need to securely mount the batteries so the don't contact the underside of the bed, it'll be a real bitch to lift it, secure it in place, and attached the cables.
    I think 4 6V batteries lined up at the front of the bed would be a better setup. Make an 8" x 12" box to go over top of them and you're set to go. Easier to mount, easier to maintain, and you don't really lose a lot of space.
  6. Jul 17, 2019 at 7:00 AM
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
  7. Jul 17, 2019 at 1:29 PM
    mmccoy
    Mark
    06 Tundra DC TRD4x4
    This is a great idea. Thanks for the input!
  8. Jul 17, 2019 at 1:39 PM
    mmccoy
    Mark
    06 Tundra DC TRD4x4
    I'll need to keep all the chainable batteries at 12V (to be compatible with the Yeti 400 - i believe). I currently have a single 100ah 12v battery chained, I was initially planning to add at least 2 more, depending on power needs.
    I like to go out on backpacking excursions while overlanding (leaving the truck in one spot without turning on for 2 - 3 days). I think I'll need at least 3 100Ah batteris plus the internall 33Ah in the Yeti 400 to do this.
  9. Jul 17, 2019 at 2:26 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    You can wire the 4 (or 2) 6v to 12 pretty easily. The advantage is the 6v are more tolerant to being deep cycled on a regular basis than 12v batteries.
    If you did 4 GC2 batteries you'd end up with 400+AH of capacity.
    http://www.everything-about-rving.c...es-to-my-12-volt-rv-house-battery-system.html
    bmf4069 likes this.
