Remove decal applied by previous owner
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dank1296, May 11, 2019.
  1. May 11, 2019 at 2:09 PM
    Dank1296
    Dank1296 [OP] New Member
    JC
    2015 Grey Tundra SR5
    Nerf Bars
    Hey Guys, just purchased my 2nd Tundra finally got the 4 wheel drive i wanted. Its a 2015 with only 34000 miles and previous owner kept it spotless well maintained. Only problem he applied a 4x4 sticker on tailgate i dont care for. Its peeling a little already. Want to get it off without leaving residual marks of any kind. Any suggestions or fluids to remove.
  2. May 11, 2019 at 2:10 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Just remove it and use some goo gone to get the residue. More than likely the adhesive used on that is far from being as good as the oem stickers. And I’ve never had problems using goo gone on even oem.
    Buildn, Midnite72, B737 and 1 other person like this.
  3. May 11, 2019 at 2:13 PM
    Ditto ^
    Danman34 likes this.
  4. May 11, 2019 at 2:50 PM
    If that sticker is too hard to remove, use goo gone as mentioned but soak a clean rag with it and apply it over the whole sticker. Don't skimp. Use a lot on the rag. Hold over the sticker for quite some time. Maybe 4 or 5 minutes. Then wait a half hour. Should peal right off. I've removed literally thousands of stubborn calibration stickers over the last 39 years.
    Midnite72 and Padj like this.
  5. May 11, 2019 at 5:58 PM
    Dank1296
    JC
    Nerf Bars
    Sounds like a plan with the goo gone route Thanks.
    Black Wolf likes this.
  6. May 11, 2019 at 6:07 PM
    Navy Jumper
    Navy Jumper Airborne Paratrooper
    2023 TRD PRO
    Heat gun or blow dryer should work, and let you peel it right off.
  7. May 11, 2019 at 6:26 PM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    This, with a little goo gone to clean up any remaining residue.
  8. May 11, 2019 at 7:05 PM
    Well that does look interesting.
  9. May 11, 2019 at 7:08 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
  10. May 11, 2019 at 7:08 PM
    Unless it's been on for quite some time. Works fine on recent stickers and decals but old stickers can be a pain, even using goo gone on old stickers on glass can required a razor blade for example.
  11. May 11, 2019 at 7:28 PM
    Novajess1972
    Novajess1972 New Member
    Jesse
    2019 MGM TSS OFF ROAD
    Ready Lift 4in/20x10 Fuel Triton/35x12.50 BFG KM3
    Removed my TSS OFF ROAD stickers today with no heat. There was absolutely no residue. Seems as though heating it creates the residue. I’d try without heat.
  12. May 11, 2019 at 7:38 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Wait for a hot sunshiny day and it’ll peel right off, followed up by a little wax in the place and it’ll be good to go.
  13. May 11, 2019 at 8:23 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    I usually use a little heat followed by 91% isopropyl alcohol with a microfiber towel. Do not use a scraper. Works very well, might take a couple of rubs with the alcohol.
    @Notachickmagnet might know more.
  14. May 11, 2019 at 8:28 PM
    Stevenmartinez83
    Stevenmartinez83 New Member
    Steven
    2001 Tundra TRD Off Road 4x4
    Bone Stock
    I used to work at a Ford dealership and we use to take the stickers off the trade in cars with just a razor blade and extreme care. Then I used Goo Gone for the residue. Seems crazy but I used to do it several times a week and never damaged any paint. Soaking the stickers with Goo Gone is always hit or miss especially if they are vinyl and old
  15. May 11, 2019 at 8:52 PM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    Heat gun and peel. Eraser wheel if needed. Wash, clay bar, polish (to remove ghosting), wax. Done.
  16. May 11, 2019 at 9:02 PM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    Eraser wheel is magic. I highly recommend. It’ll save you a ton of time and aggravation. Not to mention sore hands and thumbs.
    Inquiringone likes this.
  17. May 11, 2019 at 10:46 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Ditto, .bump
  18. May 11, 2019 at 11:13 PM
    jtdunc
    jtdunc New Member
    2014 Tundra Double Cab - Magnetic Gray
    Use Goo for cars though at your local parts store. Clearcoat and paint safe. Just did the same before dropping a Snugtop canopy on there.
  19. May 12, 2019 at 3:13 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
  20. May 12, 2019 at 4:28 AM
    Liquid unlucky
    Liquid unlucky New Member
    North east Texas
    2019 Toyota Tundra
    None....yet few decals and a five star dragon Ball. Lift 4.5" in two years is the plan
    https://www.amazon.com/Ehdis-Sticker-Remover-Plastic-Scratched/dp/B01HTEM6DS
    I used these for years when I was doing auto body work. They work well and hardly ever dig into the paint but be warned they will dig into your skin if you slip.
  21. May 12, 2019 at 7:06 AM
    Dank1296
    JC
    Nerf Bars
    Been raining here in Georgia last couple days Sunny tomorrow gonna try peel and goo gone tomorrow will post pic of finished work. Thanks for all of advice
