Remove a couple rear leafs and add air bag???
Discussion in 'General Tundra Discussion' started by tnc110, Jun 13, 2020.
  1. Jun 13, 2020 at 5:12 AM
    tnc110
    tnc110 [OP] New Member
    2016 extra with 8' bed
    Going to put a 6" lift and 37s on soon. I can't stand a truck that sits lower in the rear. I want to run airbags so when I have a sled or motorcycle in the bed it doesn't look ridiculous. I put airbags on my 2500 ram and even with just the 5 psi minimum in the bags it rides rough... Worse than factory. I'm thinking about pulling one or 2 leafs out of the packs of this tundra to give it a softer ride when I install airbags. I'll set the air pressure accordinglyt tolto I also thought it would be nice to dump the air and drop the rear when loading the sled, bike or whatever.
    Anyone every do this? Any drawbacks or anything I'm not thinking about?
  2. Jun 13, 2020 at 6:19 AM
    timsp8
    NY
    I’ve read tundra leafs are pretty weak to begin with. If you remove some then it’s even weaker, even with airbags. I wouldn’t think it would be a good idea.
    I have the stocks leafs and airbags and it doesn’t seem rough to me.
    Rex Kramer likes this.
  3. Jun 13, 2020 at 6:31 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    No way would I be removing any leafs, asking for problems.
    Tundyfundy, Trooper2 and TechWrench like this.
  4. Jun 13, 2020 at 7:42 AM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    2018 White Tundra Limited DC 4x4 TRD
    BFG KO2s, TRD Rear Sway Bar, Firestone RideRite Air Bags, B&W Gooseneck Hitch, Trail Ridge Extendable Towing Mirrors
    2018 with airbags and mine rides high in the back with the minimum air pressure but I don't notice it being rougher.
  5. Jun 13, 2020 at 8:34 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Adding air bags to my CrewMax took the rear end sag away.
    Rides nice and level now. 6" ProComp. 37's
    I run about 10psi w/46gl of fuel on board.
  6. Jun 13, 2020 at 8:50 PM
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    That just sounds crazy to remove OEM rear leafs. I know you want to have a good ride but could be better with just adding the airbags or getting a better leaf package.
    Tundyfundy likes this.
