remote start problems
Discussion in 'New Member Introductions' started by Poppop, Oct 13, 2018.
  1. Oct 13, 2018 at 6:51 AM
    Poppop
    Poppop [OP] New Member
    I have a 2014 Tundra with the factory remote start. It has been working fine until recently. I did not use it all summer. Now it won't start the truck. The lights flash but the truck does not even turn over. Any ideas?
    YardBird and Prostar 190 like this.
  2. Oct 14, 2018 at 4:27 AM
    Not sure about your problem but Welcome from Ohio!
  3. Oct 14, 2018 at 8:38 AM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    MotoTundra likes this.
  4. Oct 14, 2018 at 6:07 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Sorry I can't help you on the remote start. Best of luck. Welcome from PA.
  5. Jan 22, 2021 at 5:43 AM
    cdavi060
    cdavi060 New Member
    Virginia Beach, VA
    2017 Super White Tundra Platinum CM
    285/70r18 NITTO RG | Method NV 18x9 | Bilstein 6112 @2.5" w/CB shims, SPC UCA, 5100 & CB +3 Shackles | Entune 3.0 Swap | 2018+ Platinum grille + Pro LED Headlights
    Hello, I am experiencing he same issue. When attempting to remote start, everything seems fine, lights flash, accessory turns on inside the truck, but the truck does not crank over. Any ideas?
  6. Jan 22, 2021 at 12:59 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  7. Jan 22, 2021 at 9:11 PM
  8. Feb 2, 2023 at 4:56 AM
    pd107
    pd107 New Member
    South Carolina
    2010 tundra black
    Check for error codes (check engine light) I have a 2014 MKS had the same problem turns out the remote start will not work if there is an error code present
  9. Feb 2, 2023 at 6:44 AM
    cdavi060
    cdavi060 New Member
    Virginia Beach, VA
  10. Feb 2, 2023 at 6:50 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Reviving a few OLD intro threads today! OP last seen November 2018.
    cdavi060 likes this.
  11. Feb 2, 2023 at 7:00 AM
    cdavi060
    cdavi060 New Member
    Virginia Beach, VA
    My thought was if others come here to search for the same issue, the resources are here. Have a good one!
