Regarding OD/off and towing
Discussion in '1st Gen Tundras (2000-2006)' started by Madcapwoodwright, Aug 10, 2020.
  1. Aug 10, 2020 at 10:04 AM
    Madcapwoodwright
    Madcapwoodwright [OP] New Member
    Denver Colorado
    1st Gen 2000 Toyota Tundra SR5 Access Cab 4x4
    I am prepping to tow a 5x8 utility trailer with a rooftop tent attached. Other camping gear in the bed.
    Correct, transmission saving protocol is tow with OD off, correct?
  2. Aug 10, 2020 at 10:29 AM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    I think the consensus is (and what I do), keep the O/D off on hills, or any time you’re really pulling, but if you’re just cruising down the highway on flat land it’s okay to keep the O/D on to keep the rpm down and improve your mileage.
    spininin likes this.
  3. Aug 10, 2020 at 10:57 AM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    I believe on the early 4spd. automatics there was an issue with the overdrive gear being prone to breakage when towing. The later ‘05-‘06 automatics fixed the problem. Not 100% sure though... :notsure:
  4. Aug 10, 2020 at 10:59 AM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    I tow in OD on flat land, but you have to listen to the truck. If it starts hunting for gears, take it down a gear.
    If it feels like it's bogging down, take it down a gear.
    BravoDeltaRomeo likes this.
  5. Aug 10, 2020 at 11:41 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    It was the 00-02 trucks, they don't like to talk about it. Something to do with a weaker (intergalactic) planetary gear, I never looked into it much because 03-04 didn't have that issue.
    Now I'm off to find that song :taco:
    bassman417, N84434, bmf4069 and 2 others like this.
  6. Aug 10, 2020 at 11:58 AM
    Professional Hand Model
    Hand Protectors
    I have the 2002 and have towed/hauled mucho over the years since it was new. I usually keep the OD on when towing flat terrain and no hills. I do not use the Cruise Control with OD as it likes toggle in and out when towing.
    Where I find its best to tow with OD off is in hills and/or strong head winds where force is pushing back. These conditions cause the toggle effect when in OD, also. Basically, when you feel the truck toggling in and out of OD then drop out of OD.
    Still have the same transmission with 171k miles. I’ve had the fluids serviced somewhat regularly over the years so maybe this has helped.
    Jake92 and Darkness[QUOTED] like this.
  7. Aug 10, 2020 at 1:42 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I knew PHM would jump in :D
    So hard to find a J P Hewitt gif.
    I have a feeling that the weaker planetary gear wasn't in every truck. It was a known issue long ago but doesn't seem to come up lately. Or, maybe when they do fail these days people just think its a 20 year old transmission and it did its job.
    My buddy had an 02 Sequoia that he towed with often and it never failed either, but he kept OD off while towing.
  8. Aug 10, 2020 at 1:49 PM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 Tundra twice and both towed pretty much too.
    I keep it in OD uness in the mountains and can pretty much tell if I need to kick it down by feel.
    Not a single gear or really any other issue ever.
  9. Aug 10, 2020 at 2:18 PM
    Hand Protectors
    Yep. Same here. We’ll never know if those gears that exploded in the past were from someone leaving the OD ‘on’ while the gears are toggling in and out for 20 minutes. Goofy person for 20 minutes going, ‘Whats that?’, and then... Boom! Splat! Ugh!
  10. Aug 10, 2020 at 2:20 PM
    Hand Protectors
    Kinda like the little ‘suspension and shock’ landmine campaign I’ve had going for about a year now. I lay a landmine and 3 seconds later ‘someone’ steps in it. Like clockwork. :D
    Darkness[QUOTED] likes this.
  11. Aug 10, 2020 at 6:40 PM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Auto tranny, yes, you are correct. Manual not so much, OD okay as long as it's not bogging...it'll tell you when to downshift out of OD...so pay attention mate. No auto drive/napping while towing.
  12. Aug 11, 2020 at 3:20 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    The thing to remember is that you want the torque converter locked as much as possible. When it's unlocked it's slipping which is inefficient and is generating lots of heat.
    What many people don't know is that if the tranmission automatically executes a downshift from OD to Drive, the torque converter unlocks. If the driver manually executes a downshift from OD to Drive (by pressing the OD off button) the torque converter stays locked.
    So when you're cruising along on a flat road in OD, then you come to a hill, take it out of OD yourself... don't wait for the transmission to automatically do it.
  13. Aug 11, 2020 at 4:56 AM
    Hand Protectors
    There it is! A great explanation.
    ktundra and Tundra2 like this.
  14. Aug 11, 2020 at 10:57 AM
    Madcapwoodwright
    Denver Colorado
    Excellent!
    I'm pleased I remembered this tidbit. We are up in the high country right now, (hense the delayed response)and truck as performed well. Even with OD off.
    Very pleased.
    Thanks to all!
  15. Aug 11, 2020 at 11:02 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    N84434 and Darkness[QUOTED] like this.
  16. Sep 18, 2020 at 5:20 AM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Theoretically 1st gen Tacoma's should have the same problem as they have the a340's aswell
  17. Sep 18, 2020 at 5:57 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I towed with my 2002 when I first bought it, and I always turned the OD off unless I was on a long flat stretch of road. I sill turn the OD off in hill country, so the transmission isn't shifting itself in and out of OD.
  18. Sep 18, 2020 at 8:07 AM
    ktundra
    ktundra rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    @Darkness Love this song
  19. Sep 18, 2020 at 8:22 AM
    Pucks18
    How do you know it shifts out of od? U feel like mine never really does. I know what it feels like when the torque converter locks up but not od
  20. Sep 18, 2020 at 8:47 AM
    Rex Kramer
    Georgia
    If the OD is left on the transmission with automatically shift in and out of OD as the strain on the engine increases or decreases, turning the OD off prevents up-shifting into OD.
  21. Sep 18, 2020 at 10:54 AM
    tvpierce
    Maine
    Are you sure? The TC lock is much more subtle than the shift to OD. The shift to OD feels just like the shift to any other gear.
    Darkness and Pucks18[QUOTED] like this.
  22. Sep 18, 2020 at 7:29 PM
    Pucks18
    I must be confusing overdrive lockup with torque converter lockup
  23. Sep 18, 2020 at 10:05 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Can not resist doing the robot when I hear that song
    bmf4069 and ktundra[QUOTED] like this.
  24. Sep 19, 2020 at 6:21 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yes, random jerky movements are required when that song comes on.
