Refinishing sliders/steps with bedliner
Discussion in '2.5 Gen Tundras (2014-2021)' started by krap22, Mar 23, 2022.
  1. Mar 23, 2022 at 6:03 AM
    krap22
    krap22 [OP] New Member
    Polk City, Iowa
    2017 SR5 TRD off road
    I just bought my new (to me) tundra 2 weeks ago. It came with the n-fab podium steps on it. The coating is flaking off. I checked with my local line-X place and they quoted me $425 to finish them (premium line-x because it will be exposed to the sun). I'm assuming a lot of that would be labor to prep them before putting line-x on them. The sad part is i can get a new pair of steps from n-fab for $500 already coated. From my research it doesn't sound like they have good luck with their coating staying on.
    I've looked and i can get a kit from Amazon for $150 (Raptor Truck Bed Liner) I have no problems spraying these myself, but i just want to make sure that what ever i put on it is going to last.
    What have you had put on your sliders/steps and how is it holding up? I'm just looking for options on what to do.
  2. Mar 23, 2022 at 6:47 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Actual use of sliders means they’ll get scraped, dented, and jacked up. I use several cans of Rustoleum every spring to recoat mine along with the rest of the armor - although I probably should start doing it in the fall. Cheap and easy.
    Luckydog and pvn.beluga like this.
  3. Mar 23, 2022 at 6:49 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    I have to re-coat a few spots of my WKOR sliders. Going to have to use a wire wheel, sand it down, and then if I want to get fancy with it, then I'll add primer then rustoleum.
    Cruzer likes this.
  4. Mar 23, 2022 at 6:58 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    I used Raptor liner on many parts of my truck including the sliders. The flat areas exposed to the sun definitely will fade over time.
  5. Mar 23, 2022 at 7:00 AM
    krap22
    Polk City, Iowa
    As much as i would like to off-road more, it's unlikely that they get scraped/dented much from me hitting them. They would more than likely get hit with rocks from the road.
    Other than fading, is it holding up pretty good?
  6. Mar 23, 2022 at 9:04 AM
    oh_really
    oh_really New Member
    NoVa
    2019 Tundra CrewMax Limited Cement
    I used the bedliner stuff from Harbor Freight (forgot the brand) on mine. Did about 3-4 coats with a foam roller. Came out perfect. My step rails were from Amazon and only $200ish. The rubber pad glued to the top was coming off so I stripped them off, sanded down the THIN "powdercoat" and rolled on the bedliner stuff. Still looks new 6 months later. I think the stuff at Harbor Freight is about $50.
  7. Mar 23, 2022 at 12:08 PM
    BlueRibbon4x4
    Geno
    Absolutely. My bumpers were done three years ago. They’re great. I love the stuff. Honestly the fading isn’t that bad. But on my old steps I sprayed, the fading was more prominent on the actual step area where everyone placed their feet.
  8. Mar 23, 2022 at 12:10 PM
    krap22
    Polk City, Iowa
    That's good news. I think that is the route I'm going to go. I'll start with the steps and then do the bumpers.
  9. Mar 23, 2022 at 1:46 PM
    BlueRibbon4x4
    Geno
    You won’t be disappointed. I used plastidip over the chrome, then primer and Raptor liner. The plastidip prevents the liner from chipping off the chrome.
  10. Mar 23, 2022 at 1:49 PM
    krap22
    Polk City, Iowa
    That is interesting that you put plastidip down first. does it stick better to the chrome than the primer or liner?
  11. Mar 24, 2022 at 7:24 PM
    BlueRibbon4x4
    Geno
    Yes. The liner won’t stick to the chrome for long. People will say to just scuff up the chrome and then use primer. But that won’t last. The plastidip is like a pliable spray that will adhere to the chrome. The liner will stick to it then.
