Red or Yellow?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mwray8909, Jan 22, 2019.
Red line or yellow line
Poll closed Jul 21, 2019.
  1. Red
    11.1%
  2. Yellow
    88.9%
  1. Jan 22, 2019 at 2:07 PM
    Mwray8909
    Mwray8909 [OP] New Member
    Chino Valley
    18 TRD offroad cement CM
    I'm in the process of working on a High clearance, tube style bumper that will maintain the stock Hitch (if desired) and all sensors.
    I'm looking to get some input on where to actually make the cut.
    I want to hear why also.
    Mountun Goat and saybng like this.
  2. Jan 22, 2019 at 2:10 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Subd..
    Mwray8909[OP] likes this.
  3. Jan 22, 2019 at 2:13 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Here’s a pic of Zac’s truck. @Spolar
    TXMiamiFan, SoCal619, 831Tun and 2 others like this.
  4. Jan 22, 2019 at 2:14 PM
    Mwray8909
    Chino Valley
    Looks like he went closer to the yellow line
    SoCal619 likes this.
  5. Jan 22, 2019 at 2:17 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yeah, I would think you'd have to. The bumper can only go so high, need to give the tailgate some space to open.
    831Tun and Mountun Goat like this.
  6. Jan 22, 2019 at 2:18 PM
    Mwray8909
    Chino Valley
    Yeah I've been under a few time too look at tailgate mounting and and any other hardware to consider. Neither option would interfere with the Tailgate.
  7. Jan 22, 2019 at 2:24 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    The bend in the fender at the red line, if you make your cut below it, will give the cut edge some rigidity and strength.
    An unhemmed cut edge on sheet metal moves and waves, looking like crap.
  8. Jan 22, 2019 at 2:59 PM
    Mwray8909
    Chino Valley
    That makes sense. I may have to consider a bracket to secure the body of I do the red line.
    gosolo[QUOTED] likes this.
  9. Jan 23, 2019 at 7:00 AM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Exactly. Went as high as I could go
    SoCal619, joonbug[QUOTED] and 831Tun like this.
  10. Jan 23, 2019 at 7:45 AM
    Sunnier
    Sunny
    San Diego, CA
    @boardude and @Porschetech29 both have high bumpers for good departure angle. Look at their trucks for good ideas on where to cut. It depends on how you attach the bumper to the frame. I think yellow is more realistic.
    Marty McFly likes this.
  11. Jan 23, 2019 at 7:56 AM
    Marty McFly
    Morty McBoonJug
  12. Jan 23, 2019 at 9:49 AM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    I vote yellow
  13. Jan 23, 2019 at 9:49 AM
    Mwray8909
    Chino Valley
    That helps a ton!
    Porschetech29[QUOTED] likes this.
  14. Jan 23, 2019 at 11:00 AM
    Porschetech29
    Francis
  15. Jan 23, 2019 at 11:05 AM
    n2deep
    n2deep Pavement Princess
    Are you removing the stock hitch?
    Whatever you do you need to keep the stock hitch or duplicate it higher to tie the frame together with something beefy. You can't just assume the bumper will be strong enough. You need a big piece of steel specifically welded across the back between the frame. Otherwise you will eventually have the issue I am having where the bed is tearing apart.
  16. Jan 23, 2019 at 11:10 AM
    Mwray8909
    Chino Valley
    My bumper will have to include a hitch. I actually plan to add support to the frame anyway. I know most folks do need or use the hitch. We will be duplicating it higher by about 3 inches but tucking it in closer by an Inch as well.
  17. Jan 23, 2019 at 11:14 AM
    n2deep
    I integrated my hitch into my bumper also but its not strong enough to keep the bed flex under control. I need to add a 4in square steel tube to brace across the back of the frame. Also adding a bed cage/RTT rack tied into the frame and boxing the frame.
    The design of the stock hitch works like a sway bar to control the flex of the rear frame. Without it the frame flexes too much and has started ripping my bed apart. My tailgate doesn't fit correctly and the floor is pulling away from the bolts that hold it to the frame.
