Recommend Lift Size
Discussion in 'Suspension' started by JBRabbit, Dec 2, 2018.
  1. Dec 2, 2018 at 1:31 PM
    JBRabbit
    JBRabbit [OP] New Member
    Jo
    Denver
    2000 Tundra SR5 Exra Cab 4WD
    I have a stock 2000 Tundra with approximately 70,000 on it. I am wanting to beef it up and am looking for recommendations on lifts, wheels and tires to start. What size lift should I go with? And is there a certain order I should go with for this work (i.e., lift then wheels/tires or wheels/tires then lift).
    I am completely new to all of this. But I am excited to see what I can have. Thanks for any help and ideas!
  2. Dec 2, 2018 at 2:56 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Depends on how much you want to spend. The higher you go the more you need like UCA’s, dif drop and etc. Up to 3” your go with just the lift plus up to 285/65/20 tires with only an inch cut off the well panel behind the fog lights. I was able to keep my mud flaps with my 3” lift.
    Common sense approach is lift then tires, otherwise you now have small tires on a lifted truck.
    JBRabbit[OP] likes this.
  3. Dec 2, 2018 at 3:01 PM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
