Recommend a tire
Discussion in 'Wheels & Tires' started by akhero, Aug 2, 2019.
  1. Aug 2, 2019 at 10:58 PM
    akhero
    akhero [OP] New Member
    2005 Toyota Tundra
    I have a 2005 tundra DC Need new tires currently have BF Goodrich KO2 285/75R16
    Only use the truck for work and pleasure no offroading. Looking for tires that would help with the gas milage
    was thinking to downsize to 265/75R16 to something like this Cooper Discoverer AT3 4S
    What do you guys think would the 265 be too small?
  2. Aug 3, 2019 at 3:21 AM
    OR18TRD
    OR18TRD Pândâ Crëw
    Pândâ
    PDX
    2018 Panda Crewmax
    Suspension: front- Bilsein 6112 set at 1.9”; Rear- bilstein 5160 with maxtrac 1” shackel. Wheels: Method MR308 roost wheels 18x9” +18 offset. Tires: 275/70/18 Goodyear wrangler DuraTrac’s Removed front mudflaps and moved front wheel well liner forward. Bakflip MX4 Tonneau cover Line-x premium bed liner aFe CAI Rear differential breather moved behind taillight Debadged Windows tinted 20% ESP locking long box rear seat storage OEM all weather mats 6 3/4” antenna Coverking leather rear seat cover
    Is your truck stock or have a lift? Current pictures?
    I’m sure it would look ok with 265/75/16 it’s only 1” shorter and a little narrower. You’ll probably notice it more at first but you get use to seeing it set up a certain way after a while.
    The increased MPG would be nice.
    Casper421 and Twinky like this.
  3. Aug 3, 2019 at 3:41 AM
    Twinky
    07 double cab work horse
    Custom speed dent. Saving up for matching driver side speed dent.
    I agree with the above.
    Doing a quick search at discount tires for your current size, there's a lot of options.
    I'm guessing regular truck tires for highway driving is your preference?
  4. Aug 3, 2019 at 4:36 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Michelin Defender LTX or A/T 2.
    I've got 265/70 on mine with a lift and it looks fine.
    I put a set of Defenders on the wife's Durango last fall and they are very good in all types of weather and they're wearing very well.
    tuna813, Dag3, Pudge and 2 others like this.
  5. Aug 3, 2019 at 6:42 AM
    Professional Hand Model
    Professional Hand Model Fred Brookes
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    Based on your mandate of work/pleasure with no off roading, I’d recommend the Michelin 285/75/r16 Defender LTX of which size I’ve been using for about 15 years in the Michelin family.
    Quiet, good all season, good in snow/sand/tow/haul and they handle nicely. Tread life is pretty long, as well.
    Keep in mind this size does slightly rub the inside frame if you turn real hard into parking spaces, etc. of which you can avoid by compensation. Its a heavier/larger tire and your MPG may drop a bit.
    tuna813, WNY PAT and remington351 like this.
  6. Aug 3, 2019 at 12:55 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    Improving mpg with tire size is very complex and rarely effective in practice. The theory goes that a taller tire will revolve fewer times to travel the same linear distance due to it's increased circumference vs a shorter tire, thus giving the effect of lowering your rear gear ratio. Instead of 3.08 gears spinning a 265 tire, you transmute those 3.08 gears into 2.73's using a 285 tire. The math says yes, better mpg, but physics in the real world says, eh, maybe.
    The taller tire will be usually be heavier, require more energy to start it rolling from rest (think of pushing a giant 6 foot tall farm tractor tire in a parking lot vs your truck tire. It's taller sure, and once rolling has more inertia, but how hard do you have to grunt to start it rolling vs pushing your 265 with one hand? That extra grunt is extra energy in the form of gasoline.), perhaps have more ground resistance depending on sidewall ratio and tire footprint, type of tire, tread design and rubber compound also influence mpg's.
    Tire flex at the moment of interface with the road eats a lot of energy as well. Remember the tire transforms from a round tube to essentially a square box when it is squeezed between the pavement and the rim. That why inflating your tires to max air pressure does yield some mpg gains. The max air pressure tire flexes less, not to mention a max air pressure tire usually has a smaller contact patch. But at the cost if wearing the center tread our earlier, thus needed to buy tires more frequently, thus offsetting the incremental mpg gain from max inflation.
    So TL/DR, tires within a couple of sizes 265-285 have negligible impact on mpg, and actually, tire brand, design, and rubber composition probably have a greater impact on mpg in the positive direction. It's easy to f-up your mpg's with 33x12 mudders as many here will attest to. But mpg improvements, not so much.
    10TundraSR5 likes this.
  7. Aug 3, 2019 at 1:33 PM
    akhero
    2005 Toyota Tundra
    Wow thx for all the great reply!
    Truck is stock height king coilovers in the front!
  8. Aug 4, 2019 at 5:00 PM
    Cacoleman2014
    Cacoleman2014 New Member
    I like the falken wild peak AT3's,
    marbleville and Skey44 like this.
  9. Aug 4, 2019 at 5:38 PM
    akhero
    2005 Toyota Tundra
    I looked at that too! I like the Cooper discoverer at3 or the AT3 4s I really dont need an agressive tire i rather save gas!
  10. Aug 4, 2019 at 6:51 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    I've had a number of sets of Cooper AT3 tires on various vehicles. It is a good all around, reasonably priced tire. About 35k miles was the average tread life.
  11. Aug 4, 2019 at 7:03 PM
    Vince
    Vince New Member
    2011 White DBL cab 5.7
    K&N intake
    10 ply at3 cooper will last you a long time
  12. Aug 4, 2019 at 7:09 PM
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited
    Can’t say enough good things about my Michelin Defender LTX M/S. They’re quiet, smooth, look great and wear like steel. It’s all the tire I need for snow, ice, rain and a little bit of off road. 70K mile tread life as well. Consumer Reports estimated tread life at 85,000 miles in their tests which is really impressive IMO and makes it worth the few extra bucks you’ll spend up front.
    tuna813 and Pudge like this.
  13. Aug 4, 2019 at 7:15 PM
    tacomawv
    tacomawv New Member
    Richard
    I have the wildpeaks and like them. I will get a set for my jeep this fall. I am going to get cooper at3 4s on my wife's car soon. My biggest concern is snow. Not sure if you get snow. Those are my picks. Gas mileage will suck in all of my cars. (tundra, Jeep, GX 460)
  14. Aug 4, 2019 at 8:34 PM
    Pudge
    Pudge Sap Wizard
    CT
    2015 Blue Ribbon Platinum
    TRD PRO grille, OCD consol organizers, DIY wireless phone charger, 33" Michelin Defender LTX MS, Bak revolver X2 tonneau, weathertech liners, 20% tints. DIY pop n lock, 2018 LED headlights, morimoto fogs, TRD shift knob
    Another vote for Michelin defenders. Best tire I have every had. Great tread wear, they lastforever, traction is well above average in all conditions, gas mileage is as good as the stock tires even though I went from 32s to 33s. Definitely worth the extra money when buying. They don't look aggressive but outperform pretty much any AT tire. These sound like exactly what you need
    tuna813 likes this.
  15. Aug 5, 2019 at 8:55 AM
    tacomawv
    tacomawv New Member
    Richard
    My wife's gx 460 had the Michelin defenders stock. I think they are the ltx. M/s. They have been good tires. She has 55000 miles on them. They have some wear left in them.
  16. Aug 5, 2019 at 9:05 AM
    Fiesta346
    Fiesta346 New Member
    southwestern PA
    2013 Rock Warrior cremax
    firestone mt 2.
  17. Aug 16, 2019 at 12:41 AM
    marbleville
    marbleville Agent Provocateur
    Yep, last name too.
    Mare Sirenum, Mars
    2002 Thunder Gray Metalic TRD.
    LED interior lights, air freshener, refilled washer fluid.
    I had been running the Cooper Discoverer AT3 tires for the past 4 years on my '02 and I can not recall a worse tire for slipping and fishtailing. The slightest incline from a stopped position and she would spin. The slightest dew on the road in the morning and she would spin and fishtail. It rains nearly every day from Sept. to June, and she was constantly sliding around, even with four large bags of sand in the bed.
    I bailed on them recently, acquiring a full set of Falken Wildpeak A/T3W all terrain 265/70R16 after reading many favorable reviews, and I couldn't be happier with the ride and handling. The Tundra is now glued to the road and I have experienced zero slipping in the rain, and with the sand bags removed. She is quiet and the ride is smoother, like I said, I couldn't be happier. Cost wise, I had Discount Tires meet Amazon's low price, plus I received a veteran's rebate of $50 that I wasn't expecting. I highly recommend both the tire and the installer. Oh, and the tire is also snow capable, and wears the industry's emblem signifying it.
    Cacoleman2014 likes this.
  18. Aug 16, 2019 at 3:53 AM
    Cacoleman2014
    I have a set on my 06 and I love them.
    marbleville likes this.
  19. Aug 16, 2019 at 4:08 AM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    I’m running the MasterCraft Courser HSXTour which is made by Cooper the 18 inch I had was very quiet comfortable and ran well in the snow and on wet roads. I’ve had the 20 inch for about a month - maybe 600 miles and these are comfortable as well. Haven’t run them in the rain B1E2FD73-2C0C-498A-8E87-BF7D149361AE.jpg
    Pudge likes this.
  20. Aug 20, 2019 at 6:28 PM
    MGM
    MGM New Member
    I’ll be trying Falken most likely when my time comes. Still rocking stock Michelin’s. Honestly those have performed well. Rain, snow and off-road.
  21. Aug 20, 2019 at 9:10 PM
    marbleville
    Yep, last name too.
    Mare Sirenum, Mars
    I weighted my selection criteria heavily towards an all terrain tire that was the best tire available for wet roads, based on reviews and testimonies of owners. My next criteria was icy roads, followed by snow. The Falken Wildpeak A/T3W, in my research, came in first in all three categories. It has also proven to be no slouch on dry roads and in rocky terrain, though I will admit there are others quite capable in these areas as well, some that may even beat the Falken. But in my estimation, no tire performs as well overall as it does. When you add in a decent 55,000 mile warranty and low price, it is clearly a tire to consider as the front runner, IMHO.
    A great do everything well tire on decent stock rims, though no match for Cacoleman2014's beautiful rims. I'll be working on that one...
