Recirculation Always On At Startup
Discussion in '2nd Gen Tundras (2007-2013)' started by Lickskillet, Aug 28, 2021.
  1. Aug 28, 2021 at 2:15 AM
    Lickskillet
    Lickskillet [OP] New Member
    Is this normal at startup? I rarely use this and don't want it on unless starting. I have tried not having it set to "LO" and it still comes on automatically. I know turning system off prior to key off works but I shouldn't have to do that.
    2010 Crewmax Limited
  2. Aug 28, 2021 at 2:18 AM
    Lickskillet
    This....
  3. Aug 28, 2021 at 5:15 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Mine does the same thing if I have the temp setting set to LO
  4. Aug 28, 2021 at 5:21 AM
    FrenchToasty
    FrenchToasty The Desert rat, 6 lug enthusiast
    Mo
    The SoAz
    None
    Anytime max AC is selected it will be in recirculate. Move it to the next click from max and it should pull fresh air. Fan speeds have nothing to do with how or when it will be in recirc
    07 Tundie likes this.
  5. Aug 28, 2021 at 5:30 AM
    Lickskillet
    That's the ticket... my bad. Thank you
  6. Aug 28, 2021 at 7:28 AM
    CreekDweller
    CreekDweller Not so new ...
    2020 MGM 1794 TRD Off-Road
    IIRC from the owner's manual, 'recirculate' is the default position regardless of the temperature setting because it reduces fuel consumption due to not having to cool hot air from the outside.
    FrenchToasty likes this.
  7. Aug 28, 2021 at 7:55 AM
    Lickskillet
    I never said anything about fan setting
