Recharge AC IN A CAN
Discussion in 'General Tundra Discussion' started by FISHLIPWASHINTON, Jun 16, 2017.
  1. Jun 16, 2017 at 6:21 AM
    FISHLIPWASHINTON
    FISHLIPWASHINTON [OP] New Member
    2007 CM
    2007 CM 4X4 ALPINE EQ BACKUP LIGHTS LED JL 1000/1MONO BLOCK. 2 10IN JL 450/4 MIDS & HIGHS FOX COILOVERS & BILSTEIN REARS DEZ'S SABM MAGNAFLOW 7031 PROCOMP 35x12.50x18 AMG Battery BUSHWACKER PAINTED FENDER FLARES
    2007 cm tundra need to recharge
    No leaks never been serviced since new
    What best brand plug and play
  2. Jun 16, 2017 at 6:33 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    If there are no leaks, why does it need a recharge?
  3. Jun 16, 2017 at 6:35 AM
    No cold air at all? Have you had a dye test done? Compressor going out? Or other parts going out... I've tried A/C PRO from any auto store on my T100 it did make a bit of a difference
    GNTundra likes this.
  4. Jun 16, 2017 at 6:39 AM
    FISHLIPWASHINTON
    2007 CM
    No leaks just not as cold as you think it should be big ass truck and age of truck
  5. Jun 16, 2017 at 6:43 AM
    Those cans run bout 35+ bucks try it out hopefully it works good luck
  6. Jun 16, 2017 at 6:52 AM
    Primo
    Primo White Tundra
    Primo
    San Antonio, Texas
    2016 SR Double Cab
    Level kit and TRD Pro Grill Installed.
    My AC went out at 190,000. I went to the dealer and they said that I needed a new compressor as they did not find any leaks. 1,100 bucks ?
    I took it to Pep Boys since my nephew works there, he checked everything, tested the system with dye and found no leaks. Said compressor was working properly. He recharged the system and it has been working properly ever since. Paid 79.00 dollars. I wonder why the hell the dealer wanted me to pay for a new AC System ? Jeez !!!
    GNTundra and Y0TA PR0 like this.
  7. Jun 16, 2017 at 6:56 AM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    Wtf! Some dealer eh?!
  8. Jun 16, 2017 at 7:26 AM
    tomsinamerica
    Tom
    Wilmington, NC
    my point being, if it is not as cold as it should be, and it needs a recharge, the freon doesn't wear out - it must be going somewhere?
    Tundraplatinum likes this.
  9. Jun 16, 2017 at 7:34 AM
    Primo
    Primo White Tundra
    Primo
    San Antonio, Texas
    2016 SR Double Cab
    System was recharged with added Freon. Going on 10 years with the truck, I can't complain. Freon is under pressure. Every now and then, FREO will escape little by little through connections, valves, etc., when the truck is in motion. Eventually it will get to the point that it wont be as cold as before. That's the ONLY explanation I can have after 9 years of continuous use, in the Texas heat.
    T-Rex266 and 15whtrd like this.
  10. Jun 16, 2017 at 7:54 AM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    I've found that over the years some cars do leak it out and it's not enough for the dye to catch it those little O rings get brittle ove the years. I've had really good luck w A/C pro in a can recharger just get the one with seal conditioner it re-swells the rings for 45-50 bucks you will be good To go
    GNTundra and 15whtrd like this.
  11. Jun 16, 2017 at 6:22 PM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    if its low on refrigerant then there is definitely a leak, refrigerant doesn't get old or used up. you would need gauges to figure out if its low or not. if you just add a can of refrigerant you could overcharge the system which would cause it not to cool properly also. Toyota a/c compressor clutch relays go bad quite often something to look at.
    tomsinamerica likes this.
  12. Jun 16, 2017 at 8:25 PM
    FISHLIPWASHINTON
    2007 CM
    I dont think im low... need a gauge to see if i am low
  13. Jun 17, 2017 at 4:58 AM
    tomsinamerica
    Tom
    Wilmington, NC
    Where are you? If you're near me in NC, I have guages... If you're not low, charging it will do more harm than good.
  14. Jun 17, 2017 at 6:51 AM
    FISHLIPWASHINTON
    2007 CM
    Im in California
    What gauges do i buy to check if low
  15. Jun 17, 2017 at 7:10 AM
    tomsinamerica
    Tom
    Wilmington, NC
    For low use, that's some sets on Amazon for $35 or so...
    I've never used them, I've no idea what they're like but for simple hooking up to read pressure, I would think they should be ok.
    Or search local Craigslist for a set of yellow jacket guages... Just make sure they're for r-134a...
  16. Jun 19, 2017 at 8:22 AM
    FISHLIPWASHINTON
    2007 CM
    Had AC tested no leaks and no recharge needed thanks for all responses
  17. Jul 21, 2022 at 2:13 PM
    watermans
    watermans New Member
    Jeremy
    2013 Toyota Tundra
    Lift kit, off road suspension, wheel well flare-outs,
    Mine was doing the same thing, yet it was $19.99 for a new cabin air filter. Sometimes it is simpler that you think.
  18. Jul 25, 2022 at 7:55 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    I recharged my old Chevy from a can I got at Walmart, got me cold air again and the AC was still blowing cold three years later when I sold it.
  19. Jul 25, 2022 at 8:01 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Might be worth checking the relay for the system. My old ranger would take FOREVER to get cold all of a sudden so I thought the freon was low, the compressor was bad and all that, turned out to be a relay, 12 bucks and it was blowing ice cubes again.
  20. Jul 25, 2022 at 8:50 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    *there is an acceptable rate of loss for refrigerant over the years. Now we're talking a long time and small amounts but
    Nice. Now that was one slow leak!
    Bammer[QUOTED] likes this.
