Recent audio upgrade...
Discussion in 'Audio & Video' started by JJ_TNDRA20, Oct 7, 2020.
  1. Oct 7, 2020 at 11:17 PM
    JJ_TNDRA20
    JJ_TNDRA20 [OP] JJ
    SOCAL
    2020 TUNDRA TRD PRO SW
    *Wheels/Suspension -ReadyLIFT Plus 2 -ReadyLIFT skid plate adapter -Method MR701 18 x 8 + 25 -BFG KO2 305/70/18 *Exterior -BakFlip MX4 hard cover -Rigid Industries foglight caps *Audio -2 AudioMobile 10 in subs -Sealed dual 10 enclosure -Helix Class D 1 channel amp -Helix 4 channel amp -5 channel Line Out Converter -BLAM audio 6.5s/6x9s/tweeters
    New here...1st post...
    OEM JBL premium system was absolute trash, glad I made the upgrade to this....
    Heres a short rundown on the parts and specs...pics at the end, not too much can be seen since they are POST-INSTALL pics...sorry, no RTA results!!!
    AMP 1: HELIX M ONE CLASS D
    @ 4 OHMS 1 X 240 / 480W
    @ 2 OHMS 1 X 410 / 820W
    @ 1 OHM 1 X 600 / 1200W
    MAX POWER PER CHANNEL UP TO 720W RMS @ 1 OHM
    BASS CONTROL FOR VOLUME ADJUSTMENT
    AMP 2: HELIX M FOUR CLASS D
    @ 4 OHMS 4 X 100 / 200W
    @ 2 OHMS 4 X 100 / 200W
    MAX POWER PER CHANNEL UP TO 135W RMS @ 2 OHMS
    ACTIVE LINE OUT CONVERTER: WAVTECH LINK 6
    6-CHANNEL LINE OUT CONVERTER
    SUMMING
    VARIABLE GAIN ADJUSTMENTS W/CLIP LEDS
    2/4/6-CHANNEL INPUT SELECT
    2/3 WAY SUMMING WITH RETAINED CHANEL 5/6 LEVEL CONTROL
    FRONT SPEAKERS: BLAM 690RS RELAX
    MAX POWER 150W
    NOMINAL POWER 75W
    IMPEDENCE 2 OHMS
    MAGNET – FERRITE
    FREQUENCY RESPONSE 60HZ – 20KHZ
    TWEETERS: RT20 RELAX
    MAX POWER 100W
    NOMINAL POWER 10W
    IMPEDANCE 3 OHMS
    SENSITIVITY 90DB
    MAGNET – NEODYMIUM
    FREQUENCY RESPONSE 2.5KHZ – 25KHZ
    REAR SPEAKERS: BLAM 165RC
    MAX POWER 150w
    NOMINAL POWER 75W
    IMPEDANCE 2 OHMS
    FREQUENCY RESPONSE 60HZ – 8KHZ
    MAGNET – FERRITE
    SUBWOOFERS: (2) 10 AUDIOMOBILE GTS2010
    400W RMS
    FREQUENCY RANGE 20HZ – 300 HZ
    SENSITIVITY 79.8DB/SPL @ 1.0W
    CONE: CLS MATERIAL
    150MM 5.9 INCH MAGNET
  2. Oct 8, 2020 at 4:16 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Nice setup. Are you going to leave the factory HU in?
  3. Oct 9, 2020 at 12:13 PM
    JJ_TNDRA20
    JJ_TNDRA20 [OP] JJ
    SOCAL
    yes...its gonna stay!
  4. Oct 9, 2020 at 12:43 PM
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
    That's some legit gear! I think James posted something about Helix a few months ago on FB - he said it was great stuff!
  5. Oct 9, 2020 at 1:13 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    How come you didn't go with the helix dsp?
    619Tundra, kxed and robabeatle like this.
  6. Oct 9, 2020 at 9:57 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from SoCal.
  7. Oct 10, 2020 at 3:44 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    You have a Ferrari system and you’re fueling it with 85 octane from the mom & pop gas station in the middle of the dessert.
  8. Oct 10, 2020 at 6:48 PM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Nice install
  9. Oct 20, 2020 at 7:05 PM
    JJ_TNDRA20
    JJ_TNDRA20 [OP] JJ
    SOCAL
    its 86 octane and from the "side" of the dessert...
  10. Oct 21, 2020 at 7:18 PM
    20SilverTundra
    20SilverTundra New Member
    Edinburg, TX
    2020 Silver Tundra TSS 4x4
    Nice system
  11. Nov 11, 2020 at 5:48 PM
    Bronco Ken
    Bronco Ken New Member
    Ken
    MGM 1794
    Nice setup! did you lose any functions? Those that have a 2020 JBL and used the DSR1 have reported losing Google Maps & Waze voice?
  12. Nov 12, 2020 at 7:40 PM
    JJ_TNDRA20
    JJ_TNDRA20 [OP] JJ
    SOCAL
    No loss of any functions...I am looking to upgrade later to a HELIX DSP...wasnt too knowledgeable when I chose the LOC option...
  13. Nov 13, 2020 at 7:55 PM
    Beau
    Beau De gustibus non est disputandum
    Beau
    2008 Sequoia with a 2022 style
    Sweet setup. Also, I private messaged you.
  14. Nov 14, 2020 at 5:50 PM
    texastundra77
    texastundra77 New Member
    Anthony
    2016 Tundra SR5
    what was the mounting depth of your sub box? and is the sub box custom?
