Rear Sway Bar Removal
Discussion in 'General Tundra Discussion' started by SlimJim316, Oct 19, 2019.
  1. Oct 19, 2019 at 12:06 PM
    SlimJim316
    SlimJim316 [OP] New Member
    Hey all, this is my first post so I hope this is in the right place!
    I am pretty new to making modifications to my vehicle but this seemed like a great place to start! I just removed my rear sway bar. Unfortunately, it was installed on the truck when I purchased it. I do not have the stock bolts to replace where the sway bar was bolted onto the frame rail. I am struggling to identify what bolt to purchase for the frame rail. From scouring the web I have found that a 10x1.25 might be the right size and pitch. However, I am uncertain as to what length of the bolt I need to get. Any help is greatly appreciated.
    Thanks!
    Slim Jim
  2. Oct 19, 2019 at 12:21 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Pop the other bolt out and measure it.
  3. Oct 19, 2019 at 12:23 PM
    SlimJim316
    Great advice.
    Never really thought of that. I just assumed that they would be different bolt sizes! Thanks for the help!!
    Slim Jim
  4. Oct 19, 2019 at 12:24 PM
    19TurdPro
    2019 Tundra TRD Pro
    Use the rear sway bar one just to hold it up so it doesn't fall.
    SlimJim316[OP] likes this.
  5. Oct 19, 2019 at 12:24 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Here's a picture of the factory bolt with a tape for perspective. I don't have the actual spec on the factory bolt. The bolt you removed, if it's the one that came with the Toyota kit, is a M14 X 1.5 X 120 (22mm). If that can help guide you.
    YardBird and SlimJim316[OP] like this.
  6. Oct 19, 2019 at 12:26 PM
    SlimJim316
    That is what I have in place currently. I will measure the other bolt soon.
    YardBird likes this.
  7. Oct 19, 2019 at 12:27 PM
    SlimJim316
    That is what I needed right there! you guys are awesome. Thanks for the responses
