Rear suspension without losing bed space
Discussion in 'Long Travel Suspension' started by SpeshulED, Aug 29, 2022.
  1. Aug 29, 2022 at 6:31 PM
    SpeshulED
    SpeshulED [OP] New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    With my front just bout finished up, what your recommendations with upgrading the rear without having to cut into my bed and adding a bed cage?
    I need to keep the cargo area of my bed for work purposes.
    I know Camburg has a rear shock relocation mount but I’ve heard more bad things than good about that setup. Also no one makes red shock hoops like they do for Tacomas and 4Runners.
  2. Aug 29, 2022 at 9:01 PM
    Vizsla
    Vizsla ☠️☠️☠️
    Not sure if they offer it anymore, don’t see it listed on the website. I run the Total Chaos under bed SUA kit, but changed/modified a little bit. Sacrifices some travel compared to the Camburg and other kits, but it’s about quality of travel - motion ratio etc., works really well. Used 3.0 bypasses instead of 2.5, and had a 3” leaf spring conversion kit made the way I wanted after being disappointed by the existing 2.25 spring options. Rear frame is fully boxed/crossmembers tubed, rear sucks without, and the bed smacks cab if it actually gets used.
    3” spring conversion, everything is 4130 with bolt on hangers, all spring fasteners and u-bolts upsized to 5/8”.
    79970FFB-B10E-409C-8141-91692538974E.jpg C93865ED-A645-4700-9135-CA8F6078D031.jpg
    Boxed and tubed frame.
  3. Aug 29, 2022 at 9:22 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
  4. Aug 29, 2022 at 9:37 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  5. Aug 30, 2022 at 10:28 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    As mentioned above I would confirm if total chaos still does the kit. I believe they do it's just not listed anymore. Vizsla setup would be the option I would do if I didn't go the route I did. Retains the bed and is simple. The leaver setup is a little more involved but not to say any of this isn't lol.
    KevinK, Vizsla and SpeshulED[OP] like this.
  6. Aug 30, 2022 at 10:37 AM
    empenaflor
    empenaflor New Member
    2014 TUNDRA 4X4 LTD - Black
    I'm curious as to what bad things you've heard about that setup. I recently had it installed on my truck. Haven't experienced bad anything so far.
  7. Aug 30, 2022 at 11:08 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Only issue I've heard is the mounts not holding well and breaking.
    831Tun likes this.
  8. Sep 1, 2022 at 1:08 PM
    SpeshulED
    As what @reywcms mentioned, I’ve heard that the top mounts break, but I’m wondering if there’s a way to make them stronger with additional metal and welding?
    I’ve also read that the way it’s designed, the way that the suspension cycles isn’t the best. I could be wrong, I’m no suspension expert, especially in design.
    would it be possible to post or send me some photos of your rear suspension setup?
    reywcms likes this.
  9. Sep 1, 2022 at 8:46 PM
    Vizsla
    Vizsla ☠️☠️☠️
    Know 2 people with the Camburg kit. One broke the mount(hard use), the other has been fine(truck is one of the pics on Camburg website), but hasn’t been used hard. Suspect adding limit straps will help… It isn’t ideal for shock tuning, trying to get 15” travel out of a 12” shock has limits, but have seen them work very well when tuned properly. MCM also has something similar to Camburg that works really well, doesn’t have mount failures, but uses ADS shocks if that matters. I got to see 2 of the LSK cantilever kits, nope, but that’s my opinion.
  10. Sep 3, 2022 at 2:36 AM
    SpeshulED
    you could be right about using limiting straps. I haven’t seen anyone running straps with the camburg setup.
    may I ask why the camburg setup is not ideal for shock tuning?
  11. Sep 4, 2022 at 2:04 PM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    I love your rear end.
    I said what I said.
    Peeeheeuuu, joonbug, reywcms and 2 others like this.
  12. Sep 6, 2022 at 7:10 PM
    liltrok
    liltrok New Member
    Anaheim, CA
    2nd Gen DC RW
    wdym by "nope"
  13. Sep 18, 2022 at 7:48 PM
    whitemikemac
    whitemikemac New Member
    2019 limited tundra LT
    Total chaos long travel Ss built bumper Bed cage with dual spares Baja designs lp9’s Deaver rear with stock kings and bumps
    im really liking this.
    my front is full Total Choas L/T but running deavers, stock kings and bump kit. Works well together
  14. Nov 7, 2022 at 6:51 AM
    nb_nielsen
    nb_nielsen New Member
    2012 Tundra double cab
    I run the MCMfab LT kit on the front and the MCMfab shock relocation on the rear of my truck. I bought it like that and actually have Matt rebuilding the shocks as we speak. They were wore out from miles from the previous owner and were not maintained so I'm excited to see what the rear will actually do being rebuilt and bumps added in the rear as well. I am running ADS 3.0 bypasses in the rear
    SpeshulED[OP] and reywcms like this.
  15. Nov 7, 2022 at 11:14 AM
    SpeshulED
    would you mind posting some photos of your rear shock relocation kit? Their site doesn’t show much. What’s length of your rear bypasses?
    nb_nielsen[QUOTED] likes this.
  16. Nov 7, 2022 at 11:21 AM
    nb_nielsen
    The pics are from when I bought the truck so bare with me, it wasn't loved very much by the previous owner.
    They rears are 3.0x12 ads triple bypasses. They are getting rebuilt and new shock shafts as they were pitted when I bought them. I'm actually looking at selling the set up because I want to go with a bedcage and 3.0x16's. I do t daily drive this at the moment because it's torn into pieces
    Peeeheeuuu and reywcms like this.
  17. Nov 7, 2022 at 11:25 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Join the dark side lol
  18. Nov 7, 2022 at 11:35 AM
    nb_nielsen
    I want to, just going to need to sell this current set up to fund the new set up! Hoping I can find someone who wants it!
  19. Nov 7, 2022 at 11:36 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Should sell quick!
  20. Nov 7, 2022 at 11:47 AM
    nb_nielsen
    You think I could sell it on here? I'd hate to see how much it would be to ship. Matt at Mcm is rebuilding my front coilovers and the rear bypasses so I know they will be done right
  21. Nov 7, 2022 at 11:51 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Yea, I dont see why not.
  22. Nov 7, 2022 at 11:53 AM
    nb_nielsen
    Then I would go full send. I have rear bumps and front bypasses to add this winter. Getting all the fiberglass and the hood painted to match the cab as well.
    SpeshulED[OP] likes this.
  23. Nov 9, 2022 at 8:07 PM
    KevinK
    Tundras to Sedona
    you can definitely sell the take off ADS on here. who's truck did you buy? Was it someone in NV? Almost looks northern or eastern, but I don't know many trucks in those directions that got ADS/MCM.
  24. Nov 11, 2022 at 7:17 PM
    nb_nielsen
    It use to be in North Dakota, old owners name was Chris Blom, a really stand up guy! Me and him still talk! Yeah I would love to sell the set up and go to a bedcage and 3.0x16's. I'd like to have a buyer lined up before I pull the trigger but I might not be that lucky!
