Rear Lift Advice
Discussion in 'Suspension' started by COelkhunter84, Mar 21, 2020.
  1. Mar 21, 2020 at 5:49 AM
    COelkhunter84
    COelkhunter84 [OP] New Member
    I have a 2019 CM TRD
    I put 2.5” bilstein 6112s on the front (one DS shim) from BOSS. I have Toytec rear shocks (1”-3”) and BOSS rear shackles (1”-1.5”) it is currently set at 1”. Truck was perfect!
    I bought a topper recently so my rear now sits a hair lower, pretty much leveled (haven’t officially measured). I want to add another inch in the back so when I’m loaded down I’m level instead of sitting rear low.
    what’s the best route for this with my current setup?
    leave the shackles at 1” and do an add-a-leaf?
    Thanks!
  2. Apr 2, 2020 at 5:34 AM
    COelkhunter84
    Anyone??
    Measured it out - rear sits 1/4"-1/2" higher than front. Definitely want to go up a full inch.
  3. Apr 2, 2020 at 6:07 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    I’d start with what you have. Bump your shackles up to the long setting. Add a leaf is not well reviewed around here. Coachbuilder +3 will get you .75” over your current position....
  4. Apr 2, 2020 at 6:07 AM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    Add a 1” block under leaf. Most other ways are going to net more lift or you’ll be replacing your shackle with something else. I have a 1” toytec block, works great.
  5. Apr 2, 2020 at 6:55 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    The simplest way especially if your doing it yourself would be to go this route.
    edit : Use a jack under the hitch and leave the wheels on the ground..
