Rear Led Blinker Problem
Discussion in '2.5 Gen Tundras (2014-2021)' started by chetgoudy, Dec 16, 2016.
  1. Dec 16, 2016 at 1:30 PM
    chetgoudy
    chetgoudy [OP] New Member
    Hey all, new member here. I have a '17 and had an aluminum flat bed made for it. The lights on the back are the oval style led. The voltage draw is so low (I believe) that the blinker blinks twice as fast thinking the bulb must be out. Is there a way that I can make it blink normal again? I cant stand the fast blinking.
    Thanks
    Chet
  2. Dec 16, 2016 at 1:40 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    You can add resistors in parallel with the bulbs to fool the flasher into thinking you have regular bulbs. Not sure about '17. but I do know there are LED flasher relays for 2nd Gen Tundras (which would be a better solution)
    NewImprovedRon likes this.
  3. Dec 16, 2016 at 1:58 PM
    chetgoudy
    Any guess as to the size of resistor needed?
  4. Dec 16, 2016 at 2:32 PM
    Like to see that aluminum flat bed... curious!!!
    Motor71 and Y0TA PR0 like this.
  5. Dec 16, 2016 at 5:44 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    NewImprovedRon and Tophergt99 like this.
  6. Dec 16, 2016 at 10:50 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
  7. Dec 17, 2016 at 4:34 AM
    Tophergt99
    Tophergt99 Back in black
    Weston, Wisconsin
    2015 SR5 Black TRD Crewmax
    In progress....
    Get the vleds ones, easy to install and comes with a plug system to leave it on the truck if you need to do taillight work. Also don't need to drill.
  8. Dec 17, 2016 at 7:06 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    It's early so I may be having a brain fart, but would you want to put them in series with the load to create a larger voltage drop?
  9. Dec 17, 2016 at 8:42 AM
    Ericsopa
    Ericsopa Old man and the sea
    2013 Tundra CrewMax TRD Ltd White OV tuned
    No, you won't get the full voltage to the LEDs if you hook in series.Very dim light, if any.
  10. Dec 17, 2016 at 9:52 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Derp. Not one of my smartest posts. Im going to go back to eating crayons and glue now.
  11. Dec 17, 2016 at 10:49 AM
    Ericsopa
    We all have our moments, brother. I just changed oil and filter on my CM. Left the o-ring off the filter housing. Guess how much oil ended up on the garage floor before I could climb out of the driver's seat to check for leaks. :censored: :crazy: :der: I'm gettin' too old for this shyt. :D
  12. Dec 17, 2016 at 1:22 PM
    Tophergt99
    Weston, Wisconsin
    In progress....
    No I didn't, used gtr leds.
    SouthBoundSteve likes this.
  13. Dec 17, 2016 at 3:28 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    So you casually mention an aluminum flat bed.. and don't provide us with any pictures? That's fucked, man.
    bobeast likes this.
  14. Dec 19, 2016 at 1:50 PM
    chetgoudy
    So this is the first forum type thing I've ever actually posted on, and man I couldn't believe how many new posts there were. I pretty much live under a rock... here are some pictures! Sorry for the delay... You can see where I mounted the backup camera, just above license plate. Those are HID Xtra backup lights mounted to the hitch. Very easy, perfect spot. The bed slide and boxes are from Highway Products. I use this truck for pool work. My older truck had regular boxes mounted on the the factory bed. These new boxes give me twice the room.
    20161219_163804.jpg 20161219_164045.jpg 20161219_164005.jpg 20161219_163934.jpg
  15. Dec 19, 2016 at 1:55 PM
    chetgoudy
    Thanks for the info. Just ordered them on e-bay.
