Rear Differential Leaking on my 3rd gen 2018 Tundra same as my 2017 Tacoma
Discussion in '3rd Gen Tundras (2014+)' started by OR18TRD, Jun 28, 2019.
Year/leak/no leak
  1. 2007-2013 leak
    0 vote(s)
    0.0%
  2. 2007-2013 no leak
    8 vote(s)
    8.9%
  3. 2014/15 leak
    4 vote(s)
    4.4%
  4. 2014/15 no leak
    8 vote(s)
    8.9%
  5. 2016/17 leak
    12 vote(s)
    13.3%
  6. 2016/17 no leak
    11 vote(s)
    12.2%
  7. 2018 leak
    27 vote(s)
    30.0%
  8. 2018 no leak
    7 vote(s)
    7.8%
  9. 2019 leak
    3 vote(s)
    3.3%
  10. 2019 no leak
    9 vote(s)
    10.0%
  11. Leaked and was fixed
    2 vote(s)
    2.2%
  12. Leaking was not fixed told to keep an eye on it.
    6 vote(s)
    6.7%
  13. Leaked and was retorqued
    1 vote(s)
    1.1%
  14. Miles when leak started 0-2500
    1 vote(s)
    1.1%
  15. 2501-5000
    1 vote(s)
    1.1%
  16. 5001-7500
    4 vote(s)
    4.4%
  17. 7501-10000
    6 vote(s)
    6.7%
  18. 10000-15000
    8 vote(s)
    8.9%
  19. 15000+
    8 vote(s)
    8.9%
  20. 2020 leak
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Sep 9, 2019 at 1:39 AM
    #481
    OR18TRD
    OR18TRD [OP] Pândâ Crëw
    Pândâ
    PDX
    2018 Panda Crewmax
    Suspension: front- Bilsein 6112 set at 1.9”; Rear- bilstein 5160 with maxtrac 1” shackel. Wheels: Method MR308 roost wheels 18x9” +18 offset. Tires: 275/70/18 Goodyear wrangler DuraTrac’s Removed front mudflaps and moved front wheel well liner forward. Bakflip MX4 Tonneau cover Line-x premium bed liner aFe CAI Rear differential breather moved behind taillight Debadged Windows tinted 20% ESP locking long box rear seat storage OEM all weather mats 6 3/4” antenna Coverking leather rear seat cover
    I wonder what happened in 2018?
    Seems like it started in 2016/17 same time the Tacoma rear diff got recalled. Bad gaskets being manufactured for Toyota? Robot not set to torque properly? Sabotage :eek:
    It’s going to be interesting to see how many 2019’s leak as they get more miles on them and how many 2020’s. Seems like most notice it between 10-15k miles.
    Thank you to everyone that has participated. :thumbsup:
  2. Sep 9, 2019 at 3:37 AM
    #482
    Moon Puppy
    Moon Puppy New Member
    Bob
    South Carolina
    2018 Tundra SR5
    Can you add 2020 year model to the poll?
    ryanwgregg and OR18TRD [OP] like this.
  3. Sep 9, 2019 at 3:53 PM
    #483
    OR18TRD
    Pândâ
    PDX
    2018 Panda Crewmax
    It will only let me add 2020 leak. It taps out at 20 options.
    I guess we don’t really need to know if none of them leak just ones that do :notsure:
    ryanwgregg likes this.
  4. Sep 9, 2019 at 3:56 PM
    #484
    OR18TRD
    Pândâ
    PDX
    2018 Panda Crewmax
    I can’t edit the poll questions or remove any that are already there. Hopefully no one with the 2020 has any issues. :thumbsup:
  5. Sep 9, 2019 at 6:20 PM
    #485
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    Checked mine yesterday and it looks just like this. 2018 with 14,000 miles.
    OR18TRD [OP] likes this.
  6. Sep 10, 2019 at 4:08 AM
    #486
    Dano8855
    Dano8855 New Member
    2018 Tundra Limited
    That's the same story for me...2018 and about the same mileage. The dealership replaced the gasket on my rear diff. Good luck with the repair.
  7. Sep 10, 2019 at 12:46 PM
    #487
    phabej
    phabej New Member
    2018 White Tundra SR5 Sport CM 4x4
    you are one of the lucky few! I guess your dealership isn't one of them jack-a$$ places.
  8. Sep 10, 2019 at 12:50 PM
    #488
    DvilleMafia
    DFW
    2018 Tundra SR5 4x4
    I’m going on Friday. Will see how they react.
    OR18TRD [OP] and phabej like this.
  9. Sep 10, 2019 at 5:03 PM
    #489
    Nighthawk
    Nighthawk New Member
    Frederick Md.
    2018 Tundra Limited crewmax
    linex bed Truxedo Pro F-15 Tonneau,Weathertech mats
    Mine is one of the leaking diff. also, so what is the real problem gasket, RTV and or venting. mine does not drip on driveway or ground??
    has anyone had a repair that totally fixed the leak?
  10. Sep 11, 2019 at 4:29 AM
    #490
    Dano8855
    Dano8855 New Member
    2018 Tundra Limited
    I went into the dealership with pictures and spoke with the service rep. I told it was under warranty and that he needed to order a new gasket and then we scheduled the appointment a few days later when the parts came in. In a way, I 'prepped the battlefield'. I dropped the truck off a couple days later for the repair and talked my way into a free loaner.
  11. Sep 11, 2019 at 7:41 AM
    #491
    mcroyo
    mcroyo New Member
    COS
    2017 MGM SR5 Crewmax
    Have an appointment this morning and currently waiting at the dealer, see how it goes.
  12. Sep 11, 2019 at 9:00 AM
    #492
    mcroyo
    mcroyo New Member
    COS
    Appointment is done and they're going to replace the gasket, might even be done today so we'll see...
    Dano8855 and OR18TRD [OP] like this.
  13. Sep 11, 2019 at 9:05 AM
    #493
    15whtrd
    15whtrd Mr. Blonde
    TRD Pro suspension, +2 Coachbuilder shackles, 2015 TRD Pro headlights, 20% ceramic tinted windows, charcoal filter delete, aFe drop in pro s dry air filter, TRD airflow accelerator, TRD oil fill cap, TRD 18 psi radiator cap, BDX Bullydog tuner, Weathertech floor mats front and rear, rear seat fold down mod, Tyger soft tonneau cover, Linex with uv protection, TRD swaybar, TRD center caps, TRD Pro grille insert, aluminum oil filter canister, Real truck tailgate seal, Pop-n-lock tailgate lock actuator, rear diff breather relocate.
    A glob of grease on the U joint isn’t bad. They are designed to be greased to the point where grease oozes out of the caps. The glob probably means someone didn’t wipe it up after the service. I get a small amount of sling because it is a hard area to clean after packing them with grease.
  14. Sep 11, 2019 at 1:23 PM
    #494
    Punkinhead
    Punkinhead New Member
    First it's OK for a differential to gush fluid and now it's OK for u-joints to leak grease. This Toyota fanboy apologist stuff is going too far. I just got back from a 1200 mile trip towing a side-by-side in humid 90 degree heat and noticed water dripping from up front near one of the a-arms at every stop. I suppose that's OK too?
  15. Sep 11, 2019 at 1:47 PM
    #495
    AZBoatHauler
    AZBoatHauler New Member
    2017 CM TRD 4x4
    I can't figure out if this is sarcasm... Are you really concerned about some water dripping from the engine compartment on a hot humid day?
    15whtrd likes this.
  16. Sep 11, 2019 at 1:47 PM
    #496
    timsp8
    timsp8 Member
    NY
    2018 Tundra Limited Crewmax
    If it was from your AC, then yes that’s Ok too.
  17. Sep 11, 2019 at 1:52 PM
    #497
    markg
    markg New Member
    NC
    2018 Tundra CM 1794 Edition
    Grab Bar, Running Boards,
    yep, I'm almost sure it is A/C condensation.
    All cars running the a/c in 90o heat will do that.
    15whtrd likes this.
  18. Sep 11, 2019 at 2:23 PM
    #498
    Punkinhead
    This thing's leaking from every orifice. For God's sake, it's a Toyota, not a sorority girl doing the walk of shame home on a Saturday morning!
    hagrid likes this.
  19. Sep 11, 2019 at 5:18 PM
    #499
    markg
    markg New Member
    NC
    Sell it.
    15whtrd likes this.
  20. Sep 11, 2019 at 5:43 PM
    #500
    Punkinhead
    I can't sell it in good conscience knowing how the differentials are failing.
  21. Sep 11, 2019 at 6:03 PM
    #501
    Boots
    Boots New Member
    Houston Tx
    2018 black tundra
    Procomp 6in lift w 35's 30in grill light bar Bac bed cover Taco tunes sq1 sound system Tinted windows Custom Masonic grill.
    I will look under mine when I get it back next week
  22. Sep 12, 2019 at 5:56 PM
    #502
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    Your differential is failing?
  23. Sep 12, 2019 at 6:02 PM
    #503
    OR18TRD
    Pândâ
    PDX
    2018 Panda Crewmax
    Yep
    15whtrd likes this.
  24. Sep 12, 2019 at 6:03 PM
    #504
    OR18TRD
    Pândâ
    PDX
    2018 Panda Crewmax
    :facepalm:
  25. Sep 12, 2019 at 6:03 PM
    #505
    OR18TRD
    Pândâ
    PDX
    2018 Panda Crewmax
  26. Sep 12, 2019 at 6:41 PM
    #506
    15whtrd
    15whtrd Mr. Blonde
    Be mad at Spicer for making their U joint the way it’s designed. When you pack them with grease, you’re supposed to pump it until you see it come out from under the caps. Been this way on all my trucks with serviceable U joints. If you’re not servicing them and they are leaking an ungodly amount, maybe you have a problem. Otherwise it’s just the nature of a serviceable U joint. Nothing apologetic or fanboy about it.
    If you’re running your air conditioner it has a drain for the condensation, that drips out just above the lower A arm.
    I’ve never heard about anybody having a “gush”of fluid from their differential. I’ve heard of some leaking, but no “gush”. Which I agree with you, that shouldn’t be happening, no matter how slight it is. After 5-10 years....maybe.
    Btw. You are on a Toyoya forum. Most of us tend to like our trucks. It’s to be expected that some will make an excuse for issues, or get sarcastic with you. I’m not giving you an excuse, just the facts.
    OR18TRD [OP] and RisingSons like this.
  27. Sep 13, 2019 at 8:35 AM
    #507
    mcroyo
    mcroyo New Member
    COS
    Picked my truck up yesterday so we'll see how the new gasket works.
  28. Sep 13, 2019 at 8:39 AM
    #508
    DvilleMafia
    DFW
    2018 Tundra SR5 4x4
    Well I was told it’s normal if seeping from the inside where the bolts are, abnormal if you see it leaking from the back of the truck. :notsure:
    OR18TRD [OP] and SiberianTundra like this.
  29. Sep 13, 2019 at 8:39 AM
    #509
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels.
    Seems some get it fixed and some do not. Perhaps if folks bring papers of other folks fixing it. Dealers will listen.
    OR18TRD [OP] and TTund16 like this.
  30. Sep 13, 2019 at 8:41 AM
    #510
    SiberianTundra
    Greg
    War Machine
    What dealer told you this? So we can all go to google and give them 1 star rating! :crapstorm:
