Rear differential fluid
Discussion in '3rd Gen Tundras (2022+)' started by Toyota1234, Feb 10, 2022.
  1. Feb 10, 2022 at 10:03 AM
    Toyota1234
    Toyota1234 [OP] New Member
    Jack
    2022, army green limited, off road, DC
    I want to top off my brand new leaking rear differential. The manual says to use Toyota genuine differential gear oil LT 75W-85 GL or equivalent. Is it safe to say any 75W-85 will be good to go? I assume Toyota would be using synthetic..
    it appears the oil is a couple inches below full as of now. Still trying to pinpoint the leak.. but it’s being sprayed all over the bottom of the truck. Or flung from the drive shaft.. pulled that air vent and it’s functioning fine.
    Tundra805 likes this.
  2. Feb 10, 2022 at 10:07 AM
    mass-hole
    mass-hole New Member
    JLS in WA likes this.
  3. Feb 10, 2022 at 10:20 AM
    Breathing Borla
    Northern Illinois
    why even mess with it at all, its a new truck, take it to the dealer and let them mess with all that, plus get it documented
  4. Feb 10, 2022 at 10:21 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    ^^ This
  5. Feb 10, 2022 at 10:39 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    yeah I would take this today to the dealer, there is no excuse for this.
    damnfingers likes this.
  6. Feb 10, 2022 at 10:41 AM
    Toyota1234
    Jack
  7. Feb 10, 2022 at 10:43 AM
    Toyota1234
    Jack
    I need to make a 250 mile drive tomorrow and I’m testing to see how much it’s leaking now. If I can bring it in after this drive that would be great. Is don’t plan on fixing anything myself. I just don’t want to run low on fluid. And I don’t mind having some for the next change anyway.
  8. Feb 10, 2022 at 10:43 AM
    MadMaxCanon
    it wont solve anything, it looks like that leak is coming from the main diff seal, it will keep leaking.
  9. Feb 10, 2022 at 10:49 AM
    Toyota1234
    Jack
  10. Feb 10, 2022 at 10:50 AM
    Breathing Borla
    Northern Illinois
    I wouldn't do that man, if it grenades your in a world of shit.
    get a rental if you have to
    Cpl_Punishment likes this.
  11. Feb 10, 2022 at 10:59 AM
    Toyota1234
    Jack
    ya after a few mile drive the main seal is leaking pretty good. To the dealership it is..
  12. Feb 10, 2022 at 11:08 AM
    mass-hole
    How would they know what he used? And how does he get it to the dealer if the diff is empty. Just bring it and when the diff eats itself cause there is no fluid he just parks it on the side of the road and waits for a tow?
  13. Feb 10, 2022 at 11:10 AM
    mass-hole
    Correct, its fine if its LS fluid. Like M1 diff fluid comes with it by default.
    I would just top it off if its really leaking that bad. They are gunna have to drain and fill it I believe to swap the seal anyways I believe.
    calitundrajc likes this.
  14. Feb 10, 2022 at 11:28 AM
    Toyota1234
    Jack
    I’ll see about buying some from the dealer when I pick it back up. Nowhere around here has the correct diff fluid anyway.
  15. Feb 10, 2022 at 3:02 PM
    Breathing Borla
    Northern Illinois
    I was referring to driving it while leaking badly and it grenades and your stuck fucking around on the side of the road and do who knows what damage to other things.
    I was not talking about adding whatever fluids.
  16. Feb 10, 2022 at 3:18 PM
    Toyota1234
    Jack
    Well that would suck.
  17. Feb 10, 2022 at 3:26 PM
    Breathing Borla
    Northern Illinois
    ya man, when I saw how bad yours was leaking and you had to drive 250 miles, I was thinking fuck, this dudes will be on teh side of the road with metal shavings all over the place, lol.
    I hope you get it fixed, I wonder what the deal is, sloppy build at the factory? or more defective parts
  18. Feb 10, 2022 at 4:55 PM
    raylo
    raylo not so new member
    Frederick, MD
    Sure you can top it off with that stuff. But no way I'd drive it 250 miles leaking like that. First trip should be to the dealer. Get a loaner or rental for your trip.
  19. Feb 10, 2022 at 7:54 PM
    Toyota1234
    Jack
    Ya but to be fair that was the oil that had built up after leaking for probably at least a weak. After cleaning it up and taking it for a test drive it was clear I would be empty by the time I got back lol. I’m guessing a defective part but idk yet. The guy who designed the limited tundras is flying up to look at it along with a couple other trucks all with cosmetic issues.
    Mattedfred likes this.
  20. Feb 10, 2022 at 7:57 PM
    Toyota1234
    Jack
    I’ll have to make do with my Tacoma.
