Rear bumper alignment
Discussion in '3rd Gen Tundras (2014+)' started by OR18TRD, Dec 7, 2018.
  1. Dec 7, 2018 at 12:28 AM
    OR18TRD
    OR18TRD [OP] Pândâ Crëw
    Pândâ
    PDX
    2018 Panda Crewmax
    Suspension: front- Bilsein 6112 set at 1.9”; Rear- bilstein 5160 with maxtrac 1” shackel. Wheels: Method MR308 roost wheels 18x9” +18 offset. Tires: 275/70/18 Goodyear wrangler DuraTrac’s Removed front mudflaps and moved front wheel well liner forward. Bakflip MX4 Tonneau cover Line-x premium bed liner aFe CAI Rear differential breather moved behind taillight Debadged Windows tinted 20% ESP locking long box rear seat storage OEM all weather mats 6 3/4” antenna Coverking leather rear seat cover
    I searched multiple times over the last couple days for this post. I found a few for the front and some talk about the back being off after the recall bracket was replaced.
    I found a guy on YouTube talking about the distance between the tailgate and the bumper. Mine looks ok there. Maybe 1/4” low on the drivers side. “Normal” for these Tundras.
    I’ve got a big discrepancy on the sides between the body and the bumper. 85AABF24-63D9-4508-8E6D-AC5DEB3E02B0.jpg My thumb is tight in there.
    12D9D539-6E88-439A-BD99-2322702C0442.jpgBumper is not past the line
    2A0A4D90-C46F-4FB6-9686-C0BCBF309A98.jpg Two fingers spread in drivers side
    555C11FB-0A90-497F-9D4B-2DF382E02A27.jpg The bumper comes out into the line.
    Does anyone else have this much gap between the body and bumper? Should I see if Toyota will fix it? Live and leave it?
    Bothers me enough to ask but not enough to fix it myself.
    :sadviolin:
  2. Dec 7, 2018 at 12:51 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I did. Took it to The Dealer and they got it close but not perfect. They said if I want it perfect the whole bed has to be removed? Lol I sad F that and took the bumper apart my self and it’s pretty Much spot on now.
    OR18TRD [OP] likes this.
  3. Dec 7, 2018 at 2:08 AM
    War Machine
    War Machine Premium Elite Member | Detailing Pro
    Houston, Texas
    2017 Black Crewmax SR5 Blaaaack
    I’m not even gonna look. The last thing I need is to have something like that driving me nuts.
  4. Dec 7, 2018 at 2:20 AM
    OR18TRD
    Pândâ
    PDX
    2018 Panda Crewmax
    I know. :sorry:
  5. Dec 7, 2018 at 4:07 AM
    xtyfighterx
    Ty
    North Idaho
    I never noticed mine till I showed my truck off to a family member when I first bought it. And It was the first thing out of his mouth. “your bumper is crooked”.
    15Yota likes this.
  6. Dec 7, 2018 at 5:07 AM
    15whtrd
    15whtrd Mr. Blonde
    TRD Pro suspension, +2 Coachbuilder shackles, 2015 TRD Pro headlights, 20% ceramic tinted windows, charcoal filter delete, aFe drop in pro s dry air filter, TRD airflow accelerator, TRD oil fill cap, TRD 18 psi radiator cap, BDX Bullydog tuner, Weathertech floor mats front and rear, rear seat fold down mod, Tyger soft tonneau cover, Linex with uv protection, TRD swaybar, TRD center caps, TRD Pro grille insert, aluminum oil filter canister, Real truck tailgate seal, Pop-n-lock tailgate lock actuator, rear diff breather relocate.
    I loosened my whole bed and moved it where I wanted it first, then loosened my bumper and got it about where I wanted. I had to leave the bolts in the bumper slightly snug so it would stay put, when I got it to the right spot. It’s almost as if the bumper is slightly torqued from the factory. I had to stand on one side and then push up on the other as I tightened. It was a dance!
    NewImprovedRon likes this.
  7. Dec 7, 2018 at 5:27 AM
    Bigdog
    Bigdog New Member
    2014 sr5 tundra 4x4
    7 inch pro comp lift 37 12.5 nitro ridge grapplers 639 k&n cai hyperforce interceptor tuner
    Ya I got that gap too to me know big deal I'll be replacing in the spring with smittybuilt m1a numbers frt an rear an 12000lbs winch
  8. Dec 7, 2018 at 8:26 AM
    panicman
    panicman New Member
    Eric
    2018 SR5 TRDoffroad MGM
    Guys, I had to pull off my drivers side rear bumper end and knock a dent out of it (wife backed into it!!!!’ :eek:) and the construction is such that you can adjust the alignment of the ends with some precision. You do have to lift the plastic bumper cap to get to the top bolts, but it is an easy afternoon job. Once you loosen the 8-9 bolts, you can articulate the bumper end to get the gaps uniform side to side.
    Should you have to? No- you’d think QC would catch it at assembly. But it can be done without ending up in a Yaris for 2 days while the dealership has your truck.
  9. Dec 7, 2018 at 5:42 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, 1” rear lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack.
    My recall replacement experience was the same. I knew it was off. Pouring rain. I drove next to a new tundra in the lot and said F—-! Level and aligned but both end caps away from the body and back. I was pissed but figured I would do it myself at some point. Same tech would probably done the work and I would have wasted another 4 hours. Now I have to remember to notice it. It’s easier to wash.
    I don’t even trust those guys to change my oil.
    Too many attempts by dealerships over the years-at least locally- to talk me out of my wallet, have made me skeptical. Whenever I bring my truck to a dealer, i feel like I am taking my favorite lady out to an expensive dinner at a 7/11. Weirdly unrelated, but somehow pertinent. Want to find the good surgeon. Ask the O.R. nurses.
  10. Dec 24, 2018 at 11:03 AM
    arkhomer
    arkhomer New Member
    Tyler
    2017 CM 4x4
    My front and rear are both off. Unreal. The rear is 1/4" on passenger side and 1" on driver. It's so close on rear passenger that it is rubbing paint. Think toyota will do anything about it at 40k miles?
  11. Dec 24, 2018 at 11:17 AM
    arkhomer
    arkhomer New Member
    Tyler
    2017 CM 4x4
    Double posted drivers side rear. Here is passenger rear
  12. Dec 24, 2018 at 11:20 AM
    arkhomer
    arkhomer New Member
    Tyler
    2017 CM 4x4
    Front difference. One is 3/4" and other 1"
    619Tundra likes this.
  13. Jan 10, 2019 at 10:54 AM
    OR18TRD
    Pândâ
    PDX
    2018 Panda Crewmax
    Update:
    Took my Truck to the dealer for a possible cam shaft seal leak and while I was there mentioned the rear bumper. They looked at it and said “yeah we can see it’s off. We will see what we can do to fix it for you”
    It’s currently at the shop. I’m hoping it’s better when I go get it. I don’t need perfect but that was to much for my OCD.
    :fingerscrossed:
