Re-gearing
Discussion in 'Performance and Tuning' started by Warhawk, Oct 13, 2019.
  1. Oct 13, 2019 at 11:41 PM
    Warhawk
    Warhawk [OP] New Member
    Hot Springs, Arkansas
    Nissan Titan
    I had been researching Tacomas and I see a LOT of guys regearing the Tacos with 4.88 and even 5.29 gears. This ain’t cheap at all, but the bigger the tire the more you need to regear.
    I don’t see anyone here talking about regearing a Tundra. I’m sure it’s been done, but it seems like with all the 35 and 37 inch tire setups, and even bigger, I would think I’d see some talk of regearing?
  2. Oct 14, 2019 at 12:24 AM
    LML 3500HD
    Do a search. I came up with three pages of threads.
    You’re correct though, not as common due to the power delivery. Up to a 35” tire, depending on use, it may not be necessary.
  3. Oct 14, 2019 at 12:33 AM
    Warhawk
    Nissan Titan
    I need to figure out the search engine here, I found nothing.
  4. Oct 14, 2019 at 12:51 AM
    LML 3500HD
    Try 4:88 gears.
    You can also use the google search function as well.
  5. Oct 14, 2019 at 12:53 AM
    LML 3500HD
  6. Oct 14, 2019 at 6:51 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I searched “gearing” and checked the box for title only and saw lots of recent threads.
    I wouldn’t try searching “regearing” or “re-gearing” because if a thread is posted by someone from their phone the chances of auto correct changing “regearing” to “re gearing” or such is high.
