RCI front skid plate--Aluminium or Steel ?
Discussion in 'General Tundra Discussion' started by TheBeast, Oct 17, 2017.
RCI skid plate
  1. powdercoated steel
    91 vote(s)
    58.0%
  2. Aluminium
    66 vote(s)
    42.0%
  1. Oct 17, 2017 at 5:24 PM
    TheBeast [OP] The Beach
    :) and why ?
  2. Oct 17, 2017 at 5:26 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Metal if your going to use it. Metal is stronger.
    Alum if it’s a street truck because it’s lighter. Better mpg.
  3. Oct 17, 2017 at 5:27 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Aluminium dents and bends easier than steel. I ran into a huge boulder that was used to stop vehicles from entering a trail. Not a dent or scratch in my steel skid plate.
    dcsleeper408 likes this.
  4. Oct 17, 2017 at 5:27 PM
    Basically these two ^^^
    jfrd30, aperezsh and trayday like this.
  5. Oct 17, 2017 at 5:32 PM
    cheaper too... will it work with aftermarket bumper ?
  6. Oct 17, 2017 at 5:37 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    The skid on my bumper is aluminum. It's has scratches from hitting crap and looks seared from my old cable rubbing against it from a bad angle and situation. My steel skid plate is infront of my diff that was part of the BDS lift kit. I guess it'll work depending on what skid you go for.
  7. Oct 17, 2017 at 5:38 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    I second guessed myself buying the steel plates for weight savings but after seeing the huge gouges on there, I’m kinda glad I did. Can’t imagine the aluminum taking that kind of abuse.
    Inquiringone, 831Tun, g6t9ed and 4 others like this.
  8. Oct 17, 2017 at 5:42 PM
    and is it easier for oil changes now that there is a small door for access ?
  9. Oct 17, 2017 at 5:50 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    What's the weight difference between the 2?
  10. Oct 17, 2017 at 5:52 PM
  11. Oct 17, 2017 at 5:53 PM
    PRODUCT SPECIFICATIONS
    Material: 10ga Steel, or 1/4” 5052 Aluminum Alloy
    Weight: 10ga Steel- 35lbs.; Aluminum- 26 lbs.
    Finish: Steel-heavy duty black powder coat finish; Aluminum-bare aluminum
  12. Oct 17, 2017 at 5:53 PM
    T-Rex266[QUOTED] likes this.
  13. Oct 17, 2017 at 5:54 PM
    smslavin
    smslavin Behind a lens...
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    steel is real
    nlaroy, geno0506 and Sunnier like this.
  14. Oct 17, 2017 at 5:55 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Both of them has the oil change door
  15. Oct 17, 2017 at 5:57 PM
    Did you hear it was white Tundra and came in? Switch sides. It’s ok
    15whtrd and smslavin[QUOTED] like this.
  16. Oct 17, 2017 at 6:00 PM
    gosolo
    Ray
    NW Oregon
    Aluminum won’t rust.
    Both will do well.
  17. Oct 17, 2017 at 6:02 PM
    smslavin
    Hudson Valley
    Some stuff
  18. Oct 17, 2017 at 6:02 PM
    :boink:
  19. Oct 17, 2017 at 6:02 PM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Steel is where it's at for off roading! But then again aluminum is soooo good looking
    We offer the whole lineup here at Toytec!
    Shoot me a pm anytime with any questions
    T-Rex266 likes this.
  20. Oct 17, 2017 at 6:02 PM
    SoCalDave
    SoCalDave New Member
    Dave
    2016 DC 4x4
    ^^This
  21. Oct 17, 2017 at 6:05 PM
    smslavin
    Hudson Valley
    Some stuff
    Sunnier likes this.
  22. Oct 17, 2017 at 6:08 PM
  23. Oct 17, 2017 at 6:11 PM
    smslavin
    Hudson Valley
    Some stuff
  24. Oct 17, 2017 at 7:49 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Just waiting for Black Friday deals :pccoffee:
  25. Oct 18, 2017 at 1:03 PM
    rodm1
    rodm1 New Member
    By weight Aluminum is stronger then steel since the Aluminum plate is lighter you will have to assume the Aluminum plate is equal at most in strength.
    Sunnier likes this.
  26. Oct 18, 2017 at 6:15 PM
    more votes please :)
  27. Oct 22, 2017 at 3:39 PM
    steel ahead :)
  28. Oct 27, 2017 at 12:22 PM
    RCI steel front engine skid has been ordered...:spy::spy:
  29. Oct 27, 2017 at 12:41 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    changed my vote to aluminum. :rolleyes:
  30. Oct 27, 2017 at 12:42 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Aluminum is metal too
    Sunnier and Eclipsed & Floating like this.
