Rattle/ticking at low idle
Discussion in '2nd Gen Tundras (2007-2013)' started by Atlas09, Apr 13, 2019.
  1. Apr 13, 2019 at 8:05 PM
    Atlas09
    Atlas09 [OP] New Member
    Louisville KY
    2011 Crewmax
    When at low idle I've got a rattle. It seems to be coming from under the valve cover on the driver's side.https://youtu.be/w68zSuEQMds
    Please help. My best guess is it's an oil pressure issue but I'm just guessing. In will increase in frequency as rpms go up until they get above 1500ish and the it will go away. Comes back as rpms drop. It's less frequent as the engine heats up. Truck has about 168k.
  2. Apr 14, 2019 at 9:25 AM
    Atlas09
    Louisville KY
    2011 Crewmax
  3. Apr 14, 2019 at 9:57 AM
    15whtrd
    15whtrd Mr. Blonde
    Maybe timing chain tensioner.
  4. Apr 14, 2019 at 10:56 AM
    timsp8
    NY
    Probably the VVT. It’s normal. There are threads on here about it.
  5. Apr 14, 2019 at 11:00 AM
    Atlas09
    Louisville KY
    2011 Crewmax
    15whtrd[QUOTED] likes this.
  6. Apr 14, 2019 at 1:28 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    If the noise is from a bad chain tensioner...
    "...There are 4 tensioners there, the one that I’ve always seen fail is the primary chain tensioner on the driver side. You can confirm that is the one by removing the oil filler tube and looking inside to see if the plunger on the tensioner is flopping back and forth..." @ViktorG
    ViktorG is the foreman of a Toyota dealer service shop. Post #2 in this thread: https://www.tundratalk.net/forums/t...8-5-7-timing-chain-tensioner-replacement.html
    baraynavab and Atlas09[OP] like this.
  7. Jan 16, 2020 at 3:54 PM
    212sparky
    212sparky New Member
    2011 pyrite Tundra
    Were you able to resolve the issue? Mine is making the same noise and trying to get my game plan together to fix it.
    Rocko9999 likes this.
  8. Mar 20, 2021 at 8:07 AM
    Jscrocca
    Jscrocca New Member
    2007 4wd tundra
    6 inch lift. Dual exhaust. Air intake. Tuned.
    I'm having the same exact noise coming from my truck now. Is it a chain tensioner?
  9. Mar 20, 2021 at 9:42 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    I had that noise in my truck. I did a Seafoam oil treatment and drove about 100 miles on the Seafoam, then drained the oil and added fresh oil an Liquid Moly Cera Tec. The noise had already gone away with the Seafoam getting in there and doing whatever it does, and the Cera Tec is well reputed for quieting down a noisy motor.
    Myhobbes25 likes this.
  10. Mar 20, 2021 at 12:36 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Most likely. But there are two noises in that video above. The quieter one is normal valvetrain noise on vvti or dohc engines. The louder slappy noise is one that is most likely the tensioner not working correctly.
  11. Oct 25, 2022 at 12:42 PM
    Adimattio
    Adimattio New Member
    Alexander
    2010 rock warrior
    Icon 6” coilovers, 35” general grabbers, rhino rack
    Did anyone solve this?
  12. Jan 29, 2024 at 1:38 PM
    dangeloc
    dangeloc New Member
    Any update on what causes this noise ?
  13. Jan 29, 2024 at 1:41 PM
    Adimattio
    Alexander
    2010 rock warrior
    Sorry I didn’t update the thread. mine was the heat shields and I had an exhaust hanger that had worn out
  14. Jan 29, 2024 at 3:44 PM
    dangeloc
    dangeloc New Member
    Yeah mine sounds like it’s coming exactly from the top of the motor. By the oil fill port.
