Rattle Behind Dash or Engine Bay
Discussion in '2.5 Gen Tundras (2014-2021)' started by Genuine Cooling Systems, Jul 6, 2020.
  1. Jul 6, 2020 at 6:45 PM
    Genuine Cooling Systems [OP] New Member Vendor
    I have a rattle behind my dash or engine bay that I get after bumps that is driving me crazy. It sounds like a chain rattling like the one on the spare tire. Anyone know what this could be or experice it before.
  2. Jul 7, 2020 at 6:44 AM
    Hoff
    Hoff New Member
    2021 TRD OFF ROAD CREWMAX
    I have the same thing rattling crackling sound coming from passenger side in dash area. Kinda annoying.
  3. Jul 7, 2020 at 6:48 AM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    One poster on here showed a loose bolt right behind the glove box door at the top of the glove box opening. The bolt is loose and the washer rattles. It may be worth a shot.
  4. Jul 7, 2020 at 6:55 PM
    SuperWhite20
    Robert
    Georgetown TX
    San Antonio boys wanted to get home early that Friday night!
  5. Jul 7, 2020 at 7:49 PM
    Darren509
    Darren509 New Member
    Darren
    Dayton NV
    2016 White Tundra TRD
    Wiggle your fuse box thats on the passenger side engine bay. If thats it use a large zip tie on the bracket that holds it
  6. Jul 7, 2020 at 8:55 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I had no idea there was a fuse box on the passenger side.
  7. Jul 7, 2020 at 9:10 PM
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    2020 Tundra TRD Pro Double Cab Army Green
    Driver side grab handle Door sill protectors Falken WildPeak 295/70 R18 X-Pel clear front paint protection 20% front window tint Go Rhino RB20 side steps - Bedliner finish Lock'er Down 1/2 console safe Toyota bed cargo divider Toyota auto tail gate lock
    I had a rattle in my '18 TRD SR5. An intermittent med. frequency metallic "clink". Worse with small road cracks at low speed and washboard gravel at 20-35 mph. My problem turned out to be located high on the passenger side fire wall in the engine bay. There is a loom of wires that caused a rattle inside the bracket. Some foam insulation and rattle is gone.
  8. Jul 18, 2020 at 9:08 AM
    Mine is more so a squeak than a rattle.
  9. Jul 18, 2020 at 9:12 AM
    Upgrayedd
    Upgrayedd Toyotaholic
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    I have the same thing. Will need to investigate it further.
  10. Jul 18, 2020 at 1:40 PM
    You got the squeak or the rattle?
  11. Jul 18, 2020 at 1:50 PM
    Upgrayedd
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    It’s more of a rattle than a squeak. But it tends to be fairly high frequency sometimes.
  12. Jul 18, 2020 at 1:58 PM
    I'll see if I can record mine one day. Mine is just a faint squeak over small bumps.
  13. Jul 18, 2020 at 1:59 PM
    Upgrayedd
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    Mines more of a steady noise that comes and goes.
