Rack and pinion replacement
Discussion in 'General Tundra Discussion' started by maynardjoe19, Apr 25, 2019.
  1. Apr 25, 2019 at 9:48 AM
    maynardjoe19
    maynardjoe19 [OP] New Member
    11 tundra crew max
    3 inch leveling kit
    Any thoughts or experience on replacing a rack and pinion on 11 tundra? I was told motor has to be removed, and or the diff has to be removed
  2. May 7, 2019 at 12:13 PM
    Mooseknuckles
    Mooseknuckles New Member
    Randy
    So, i'm going to have to replace the bushings on mine soon. I have a friend who is a Toyota mechanic. According to him, it can be removed through the driver side wheel well without having to remove the motor. He has a thick Philippine accent but I'm pretty sure that's what he said.:fingerscrossed:
  3. May 7, 2019 at 12:16 PM
    maynardjoe19
    11 tundra crew max
    3 inch leveling kit
    Thank you, I had to remove my diff from the vehicle to replace it
  4. May 14, 2019 at 3:29 PM
    Mooseknuckles
    Randy
    Correction, I meant to say passenger side wheel well
  5. May 14, 2019 at 3:31 PM
    timsp8
    NY
    Mine was replaced by Toyota. They said the book called for removing the motor but they didn’t. Not sure how he got it out. Charged about $3k. My insurance paid for it.
  6. May 14, 2019 at 4:00 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
  7. May 16, 2019 at 9:27 AM
    Mooseknuckles
    Randy
    Okay Papasmurf, so I missed this in your write up. :smack: It took me three times looking over the link to find my answer. Boy do i feel like a mooseknuckle. :facepalm:
    Like i sad before my mechanic friend has a thick Philippine accent. must have gotten lost in the translation. As soon as I collect all my tools from around the yard ill break out my cutting tourch and get that thing out of the way. Thnx again :welder:
  8. May 16, 2019 at 9:31 AM
    G10dra
    G10dra Not a New Member
    @ssmokedz just join this forum, I've tagged him here let's see what Yoda Master has to suggest :)
  9. May 16, 2019 at 9:48 AM
    Mooseknuckles
    Randy
    So before i pull the gearbox from the rack body. I have big hands so its a very tight fit to get in there. Ive got the two bolts off and ready to remove it. is it necessary to turn it as i pull out or should it come straight out? feels somthing is holding it up.
  10. May 18, 2019 at 10:07 AM
    ssmokedz
    ssmokedz Toyota Master Diagnostic Technician
    Shelton CT
    2019 Super White Tundra TRD PRO
    yes you can get it out without removing the motor. I just lower the diff (not remove it entirely) and you can fanagle it out. You will throw some tools and say some not so nice words tho. That's one of those jobs I never like to see hit my lift.
