Quick diode dynamics fog install question
Discussion in 'General Tundra Discussion' started by Robster80, Sep 4, 2022.
  1. Sep 4, 2022 at 2:49 PM
    Robster80
    Robster80 [OP] New Member
    I dunno if my kit was suposed to come with a small allen wrench or if i lost it but is there plenty of room to get in there and screw and adjust things with my allen wrench here? Ive had these lights awhile and was thinking maybe it came with a shorter allen wrench but i could be wrong. Just curious before i take everything off and get started.
  2. Sep 6, 2022 at 6:01 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    I don’t think the lights come with an Allen wrench. I adjusted mine about 3/4 of the way down and adjusted the cutoff when I zip tied them down. But I know @memario1214 will be able to answer your question for sure. Hopefully this helps @Robster80 .
    memario1214 likes this.
  3. Sep 6, 2022 at 7:42 AM
    Robster80
    ive got em in and zip tied but havent tightened the bolts yet as im still adjusting. Does yours have a bit of a gap in the bezel since theyd be slightly pulled back in order to angle them down?
  4. Sep 6, 2022 at 9:16 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    These lights do not come with an allen wrench in the box. The kind that you have right there is IMO the best version to get in there as it is usable in some of the tightest areas. You've already done the initial install by the sounds of it so you're off to a good start!
    Yes. There will be a small gap between the OEM bezel and the angled face of the SS3s. What I recommend doing is when you do your aiming push the light forward as much as possible, and then just slowly work it back in that cutout slide until you can get the lights at the proper aiming height and then tighten down. Don't forget to wear gloves with your hand that is holding the SS3! Not sure if you have sport or pro there, but the pros and maxes get quite toasty!
    1lowlife likes this.
  5. Sep 7, 2022 at 3:50 AM
    TwistedTad
    Tad
    Canyon Lake, CA
    I do have a small gap at the bottom of the bezel @Robster80 . Let us know how it turned out.
