Question: Superbumps
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by NjPro, Nov 28, 2018.
  1. Nov 28, 2018 at 5:48 AM
    NjPro
    NjPro [OP] New Member
    Tom
    Nj
    2017 Trd Pro Tundra cement
    Magnuson supercharger, Sprint booster, CB TRD PRO kit, 295/70/10 terra grapple G2, Black TRD shift knob, Rhino shackle hitch, Lund Tri-fold bed cover, 1.25 Spidertrax wheel spacers. TRD rear sway bar. Bud Built cross member. Arb Diff breather. Grab handle installed. 2012 DC SR5 TRD Supercharged, Gone but not forgotten.
    I have a 17 Pro with a 1” CB shim, and want to get a set of Wheeelers Superbumps.
    The CB TRD pro kit came with bumpstop spacers to protect the suspension. I need to know what spacers I should get, I can get either the (1/4" Spacer Pair) or these (3/8" Spacer Pair)
    Or do I need both of them ?
    Any help would be appreciated.
  2. Nov 28, 2018 at 5:49 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Why can't you just use the CB spacers with the new bump stops?
    But if you want to get the wheeler spacers just measure and see what the CB ones are and get the ones that measure the same from wheelers.
    NjPro[QUOTED][OP] likes this.
  3. Nov 28, 2018 at 5:54 AM
    NjPro
    Tom
    Nj
    I’m thinking they may be to aggressive/long in addition to the length of the superbumps. I really don’t know to be honest.
  4. Nov 28, 2018 at 7:12 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Superbumps compress to factory bump height, they just engage sooner.
  5. Nov 28, 2018 at 7:44 AM
    NjPro
    Tom
    Nj
    Yep, thanks.
  6. Dec 15, 2018 at 11:43 AM
    NjPro
    Tom
    Nj
    I installed the superbumps, and ran into a minor issue. When removing passengers side the bolt broke inside the bumpstop housing. I used the same angle and tq as I used on the other side but it still snapped. I used a drill bit and a screw extraction bit to get it out. So, a 10/15 minute project took 2 hours. Fair warning be carful.
    Watt maker likes this.
  7. Dec 16, 2018 at 7:28 AM
    NjPro
    Tom
    Nj
    This is a great mod, worth the money no doubt. Really smooths out the front end.
  8. Dec 16, 2018 at 7:58 AM
    15whtrd
    15whtrd Mr. Blonde
    For anybody that is removing and reinstalling bump stops here is a little tip. Spray some lubricant from the top side and let it soak on the threads are before removal. I gave mine a blast the day before. Mine came right out.
    NjPro[OP] likes this.
  9. Dec 16, 2018 at 5:06 PM
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    What do these this things do?
  10. Dec 16, 2018 at 5:08 PM
    15whtrd
    15whtrd Mr. Blonde
    It’s a softer bump stop. More progressive than just a solid abrupt stop when your suspension is fully compressed.
