Put on Kings 2.5 want a little higher - Suggestions
Discussion in '2.5 Gen Tundras (2014-2021)' started by BrownieT, May 9, 2019.
  1. May 9, 2019 at 5:03 PM
    BrownieT
    BrownieT [OP] New Member
    2018 Tundra TRD 4x4
    2018 double cab red/4x4
    I installed a set of King 2.5 shocks with resi on all four corners. I really enjoy how it drives and handles on and off road and it looks level. However I think it needs to go just a bit higher 1.5-2.5 inches. Any suggestions on how to achieve this?
    CaptSpaulding likes this.
  2. May 9, 2019 at 5:25 PM
    Jrfor0
    Jrfor0 New Member
    James
    Might be worth contacting King directly to see what options are available using your current setup. Replacing the shackles in back would achieve the lift you are looking for in the back with minimal work to the shocks. Not sure what the options would be for the coil overs though.
  3. May 10, 2019 at 12:03 PM
    Novajess1972
    Novajess1972 New Member
    Jesse
    2019 MGM TSS OFF ROAD
    Ready Lift 4in/20x10 Fuel Triton/35x12.50 BFG KM3
    Maybe they offer a spacer hat to add an inch or so?
  4. May 11, 2019 at 6:11 AM
    VigorousTundra
    VigorousTundra New Member
    Cody
    MGM limited tundra 4x4
    Kings coilover shocks Coach builder shackles and shims
    Highly recommend coach builder shackles either +1, +2, or +3 for rear and coilover front shims for 1 inch lift up front. I have this same setup including total chaos upper control arm and rides awesome! David from ekstrom design is a ton of help!
    Inquiringone likes this.
  5. May 11, 2019 at 6:14 AM
    Midway
    Midway New Member
    What size tires are you running?
  6. May 11, 2019 at 6:16 AM
    roypark
    roypark Semi-pro High Fiver
    Roy
    Orange County
    2016 Tundra
    A little of this and a little of that. Its pretty run of the mill.
    Looks like you have some room to add preload to those coilovers.
  7. May 16, 2019 at 4:32 PM
    BrownieT
    2018 Tundra TRD 4x4
    Haven’t got wheels or tires yet. Still stock. Was debating dropping to 17 wheel and fit bigger tire not sure.
  8. May 16, 2019 at 4:41 PM
    BrownieT
    2018 Tundra TRD 4x4
    Vigorous Tundra would be awesome to see a pick or your truck if possible!? That was what setup I was thinking, that front require a the drop kit ?
  9. May 16, 2019 at 4:44 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    Better check caliper clearance if you go 17's. I'm pretty sure it is doable, but dependent on the offset #'s. I ended up going to 18's from the stock 20's.
  10. May 16, 2019 at 5:09 PM
    BROGAN
    BROGAN FNG
    Logan
    East TX
    2015 TRD Pro CM Inferno Fast
    Just ceck out build thread in sig
    Seems like blasphemy suggesting that around here. But thats what Id go with.
    Watt maker likes this.
  11. May 16, 2019 at 5:31 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    Do you want to raise the front, back, or both another 1.5 - 2 inches? For the front, I believe that Kings come preset to about 2.5 inches of lift. Did you adjust these higher? you can add preload to get about 3 inches of lift but this can affect ride quality. Most kings come with 600# springs. You can switch to 700# springs and get the 3 inches of lift with less preload.
    For the rear you can use shackles or an add-a-leaf to lift the back a bit.
  12. May 16, 2019 at 6:37 PM
    oldschoolpl510
    oldschoolpl510 New Member
    Will jacking up the preload or stiffer springs mess up the ride too much?
  13. May 16, 2019 at 7:08 PM
    Dilsky
    Dilsky Toyota Brand *****
    Shawn
    Edmonton, Alberta
    2014 Platinum Tundra Crewmax Black
    King Front Coil-overs Coachbuilder shims Toytec Rear shackles - Stock Rear Baja Designs Sport Fog Lights Rough Country 30" Lightbar 18" Method Roost Wheels (Bronze) 285/70/R18 Nitto Exo Grapplers Diamondback HD Cover
    I wanted the same thing and added a coachbuilder shims up front for an extra 0.5 inch and toytech shackles in the back for an extra inch back there.
  14. May 16, 2019 at 7:15 PM
    Dilsky
    Shawn
    Edmonton, Alberta
    Couple more photos
  15. May 16, 2019 at 7:19 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    If I was you I'd consult @Coachbuilder1. He's got a lot of great ideas.
  16. May 16, 2019 at 7:27 PM
    BrownieT
    2018 Tundra TRD 4x4
    Looks awesome thanks for the pics
  17. May 17, 2019 at 11:19 AM
    VigorousTundra
    Cody
    Yes the front have a drop kit. Coach builder +3 shackles with front coilover shims for 1 inch lift on top of the kings factory preset (which is 2 inches I believe)
    Newm likes this.
  18. May 17, 2019 at 11:20 AM
    VigorousTundra
    Cody
    Have bigger tires also, Michelin defender 275/65. Wheels are coming soon!
