Pucks vs shocks
Discussion in 'Suspension' started by Outdoorfanatic, Feb 3, 2022.
  1. Feb 3, 2022 at 9:40 AM
    Outdoorfanatic
    Outdoorfanatic [OP] New Member
    2019 crew Max TRD
    Looking to level my tundra 2.5 inches in the front. I have read about the good and bad, ie tears in CV boots etc. Questions are is it better to go with the Bilstein shocks versus the strut spacers and is it necessary to do the diff drop at 2.5 inches. Some kits come with the drop hardware and some dont. Appreciate the assistance.
  2. Feb 3, 2022 at 10:57 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    5100s are better than the spacer lifts in all regards. Read guide to different lifts in the suspension forum here. Lots of review of different setup in that forum too, 5100s, 6112, 8100s, OME, Dobinsons, Eichbach Pro truck 2.0 and Toytec lifts. Lots of good lifted coilover options that will be an improvement over stock and not cost several thousands of dollars.
    You should not need diff drop for 2-2.5 lift up front.
  3. Feb 3, 2022 at 11:17 AM
    Outdoorfanatic
    2019 crew Max TRD
    I appreciate it Frank..yes almost too many threads to read through..I will check that out!
  4. Feb 3, 2022 at 12:02 PM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Look more into a proper lift. That way, if you buy spacers, you will already know what to order to replace them.
  5. Feb 3, 2022 at 12:15 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    its a thorough topic but is worth the read and its also a circumstance of you get what you pay for. spacer lifts on $50,000 vehicle makes me cringe :annoyed:
