Proper way to install leds?
Discussion in 'Lighting' started by Blue4x2, Jan 2, 2020.
  1. Jan 2, 2020 at 4:34 PM
    Blue4x2
    Blue4x2 [OP] New Member
    2007 SR5 Double Cab
    AMP power steps Corsa catback exhaust BHLM Toytec Boss Aluma series Leveling kit 295/60 Falken WildPeak AT3 20” XD Monsters II w/ 0 offset
    Over the holiday sales I picked up some vleds for my 3rd brake light (2 white and 1 red) and white reverses for the taillights and v6 triton for the turns in the taillights. I also picked up some spyder led taillights 51C57F23-C1F5-463B-BDCE-4CB76104BBF9.jpg
    my question is should I have the negative terminal of the battery disconnected and then install everything and reconnect it? Or should I disconnect and reconnect it after I install each individual led? Seems tedious but I’m not trying to blow and fuses! Thanks for y’all’s expertise
  2. Jan 2, 2020 at 4:52 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    from my perspective it’s been people using metal screwdrivers to pop out the bulbs that experience the problems with blowing fuses. I did mine with all lights on so I knew they were in correct position, used plastic trim tool to pop out, 12 min job...
    Tresalto Auto Trim Removal Tool for Car Dash Radio Audio Installer Pry Tool 4Pcs https://www.amazon.com/dp/B01EXZKHWI/ref=cm_sw_r_cp_apip_69xvVAVrsziaQ
    Blue4x2[OP] likes this.
  3. Jan 2, 2020 at 4:54 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    My vote....
    Remove the negative, install a light, dry fit attach negative battery terminal, test light and repeat for each one.
    9 out of every 10 threads in the lighting section regarding issues, could be avoided by doing this
    Worked for my interior lights and took about an extra 5min on the entire job, maybe.
    Don't chance it...."disconnect and reconnect it after I install each individual led"
    Mattyc and Blue4x2[OP] like this.
  4. Jan 2, 2020 at 5:11 PM
    Blue4x2
    2007 SR5 Double Cab
    Thanks guys! Tomorrow I’ll be sure to disconnect and reconnect the battery after each bulb and use a plastic panel popper instead of a screwdriver
  5. Jan 2, 2020 at 5:55 PM
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    I did the same method. Very easy and takes an extra 5 minutes. Zero issues since the install (3 days and counting).
  6. Jan 2, 2020 at 6:28 PM
    Have your key fob with you when you reconnect the battery. Your alarm may go off......mine does. When I did my battery change I just unplugged the connectors for the horns.
    BravoDeltaRomeo likes this.
