Project "1 Tondra" by: C4Fab
Discussion in '1st Gen Builds (2000-2006)' started by C4 Fabrication, Feb 4, 2015.
  1. Feb 4, 2015 at 6:52 PM
    C4 Fabrication
    C4 Fabrication [OP] Owner/Operator of C4 Fabrication
    Caleb
    Piedmont SD
    Hey everyone, wanted to get a build thread started for my friend/customers rig. The truck started as a 2000 4x4 access cab limited model with 4.7 V8. My buddy picked it up at an auction in North Dakota for 700 bucks. It was rolled over twice before the auction but that didn't stop my buddy from driving it off the lot and putting at least another 1000 miles on it before we started tearing it down for this build!
    The purpose/goals for this build are to have a very capable rig that can handle hardcore rock crawling and also some high speed desert type driving. This truck will be fully custom built from front to back by C4 Fabrication.
    Specs:
    Axles- Dana 60 high pinion front, GM 14 bolt rear. Most likely will end up with 5:38 gears and Detroit lockers.
    Suspension- Dual triangulated 4 link front and rear with 2.5x16 fox remote resi coilovers.
    Drivetrain- stock 4.7 v8, stock auto trans, Atlas 4.3:1 T-case
    We are trying to maintain a complete cab and still have some comforts like A/C and heat, but the frame has been chopped in front of the engine mounts up front and everything behind the cab will be chopped off and be custom built.
    This will not be a consistent build that I will be able to post progress on weekly. We are doing the build in sections as the owner has funds to do so.
    Here is how it looked the day I drove it into the shop!
    rons23 and Bob like this.
  2. Feb 4, 2015 at 6:54 PM
    C4 Fabrication
    Caleb
    Piedmont SD
    First thing was to remove all the IFS
  3. Feb 4, 2015 at 7:10 PM
    C4 Fabrication
    Caleb
    Piedmont SD
    Then did some test fitting of the High Pinion Dana 60. With the axle positioned where we wanted it (about 8" forward of stock) I immediately realized that we were going to have to create some more room for suspension up travel. The original oil pan on the tundra has a low hanging area at the very front of the pan that had to go. So after doing some research with my Toyota mechanic buddy, we realized that the oil pan on the lexus 4.7 v8 is much different than the one that comes on the tundra 4.7. My buddy happened to have a Lexus 4.7 laying in his sisters storage shed that he offered to sell us the oil pan setup off of. I swapped the new pan setup onto the tundra and that gained us about 3" more room for uptravel. I also wanted to raise the engine to gain us even more room, so I built new engine mounts using poly bushings. The new mounts lifted the engine another 2", gaining us a total of 5" more room for suspension and axle uptravel compared to the stock setup. Unfortunately the pics comparing the tundra pan to the lexus pan got lost, but I do have a couple shots of what the pan looks like now.
    2014-06-26 12.00.43.jpg 2014-06-26 12.00.55.jpg IMG_3042.jpg FSCN0854.jpg DSCN0853.jpg
    chphilo likes this.
  4. Feb 4, 2015 at 7:14 PM
    C4 Fabrication
    Caleb
    Piedmont SD
    Atlas T-case and adaptor bolted in place and a few shots of the new engine mounts.
    chphilo likes this.
  5. Feb 4, 2015 at 7:20 PM
    C4 Fabrication
    Caleb
    Piedmont SD
    Some 4 link moch up with temporary brackets to test clearances and fitment.
    DSCN0768.jpg DSCN0770.jpg DSCN0772.jpg DSCN0781.jpg DSCN0798.jpg DSCN0809.jpg DSCN0803.jpg
    dcsleeper408 and chphilo like this.
  6. Feb 4, 2015 at 7:24 PM
    C4 Fabrication
    Caleb
    Piedmont SD
    how its sitting right now. We are currently waiting to get the double ended full hydro steering ram from PSC and the heavy duty diff cover from Barnes 4wd so I can get them mounted to the axle and figure out how to build the axle trussing with all the permanent link mounts. Once that is done I can move on to building the new front framerails and all the tube bracing.
    chphilo likes this.
  7. Feb 5, 2015 at 6:45 AM
    csuviper
    Broomfield, CO
    2012 Rock Warrior 5.7L 4X4
    That thing is going to be a beast when you are done. Good writeup. Looking forward to keeping up with the build.
    tat2ude39 likes this.
  8. Feb 5, 2015 at 6:48 AM
    C4 Fabrication
    Caleb
    Piedmont SD
    Thank you! Its been a pretty fun build so far. It will be nice to get back to work on the front end when the hydro ram shows up.
  9. Feb 5, 2015 at 7:14 AM
    FunkinTundra
    FunkinTundra New Member
    Cody
    2012 Tundra 5.7 CM
    OME614 full suspension\ Ekstrom design 3" shackles and poly bushing kit\ 295/70r18 Toyo MTs/ +20 offset Fuel Anzas\ 8" BAmuffler....etc...
    SUB'D!! This looks awesome:D
  10. Feb 5, 2015 at 7:42 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Looking great. That's some serious skill.
  11. Feb 5, 2015 at 10:43 AM
    C4 Fabrication
    Caleb
    Piedmont SD
    Thanks everyone!
  12. Feb 11, 2015 at 3:03 PM
    C4 Fabrication
    Caleb
    Piedmont SD
    A bit more progress for everyone. Got the Trail Gear 2.5"x10" full hydro steering ram from Twisted Customs and the HD diff cover from Barnes 4wd the other day. Bolted the cover on so I could set the ram in its general area to see how its going to fit. With the axle sitting at full bump, there are some oil filter clearance issues that I will have to figure out how to take care of. Once I figure out how to relocate the oil filter, then I can move on to building the axle truss with the ram mount.DSCN0886.jpg DSCN0887.jpg
  13. Feb 11, 2015 at 3:09 PM
    C4 Fabrication
    Caleb
    Piedmont SD
    I had to move the rig out of the shop for a bit to make room for another project. Set it down on the tires and let the shocks bottom out to hold up the truck. The truck sits level at stock height when its at full bump with 38" tires on it! I was surprised the front sits down that far.
  14. Feb 11, 2015 at 6:47 PM
    C4 Fabrication
    Caleb
    Piedmont SD
    No comments huh? This forum must not get much traffic!
  15. Feb 11, 2015 at 7:23 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    O it does! Very bad ass build! Lookin very good so far! Can't wait to see it all the way up!!
  16. Feb 12, 2015 at 6:18 PM
    csuviper
    Broomfield, CO
    Can I take that off your hands? I would love a truck like that.
  17. Feb 14, 2015 at 8:04 AM
    C4 Fabrication
    Caleb
    Piedmont SD
    Thanks, its going to be a long process, but it will get finished someday! haha
    You would have to talk to the owner about that, but I have a feeling he would say no! ;) There is already at least 8000 bucks in parts and labor into this rig and it looks like ive hardly done anything!
  18. Feb 16, 2015 at 8:39 AM
    Boerseun
    Boerseun New Member
    Ferdie
    Sarasota Florida
    2018 White TRD Sport CrewMax
    Awesome built. Great skills!
  19. Feb 16, 2015 at 4:00 PM
    C4 Fabrication
    Caleb
    Piedmont SD
    Thanks dood!
  20. Feb 20, 2015 at 2:22 PM
    Mike Tread lightly.
    south carolina
  21. Mar 15, 2015 at 4:21 PM
    Virgils12
    Where's the updates!!!!???
  22. Apr 16, 2015 at 5:38 AM
    LGTundra
    LGTundra New Member
    2015 1794 Edition: SuperCharger, 3-1 Toytec, 20'' Fuel Wheels, 33" Trail Grapplers, Bushwackers, A.R.E. Z-Model Cap
    Like to see that beast in action!
  23. Apr 16, 2015 at 6:39 AM
    atrinh15
    atrinh15 New Member
    08 Tundra CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    This is awesome Sub'd
  24. Apr 12, 2016 at 10:37 AM
    Prise
    Prise New Member
    Andrew
    2001 Jade Mica access cab
    Gx470 wheels and 1.25" spidertraxx wheel spacers
    What ever happened with this beast, I hope your buddy didn't run out of money....
  25. Apr 12, 2016 at 10:37 AM
    Sean266
    Sean266 Mr. Clean Staff Member
    OP hasnt been on Tundras.com since 02/24/15.
  26. Apr 12, 2016 at 10:42 AM
    Prise
    Prise New Member
    Andrew
    Sad day, this had a lot of potential and was giving me bad ideas :D
  27. Apr 12, 2016 at 8:10 PM
    ColoradoTJ A Man that Stares at Goats
    2016 GMC 3500 Summit White
    Husky products, 28% tint on windows.
    I thought it was a hell of a build. My guess, the owner of the 1st gen ran out of money. Some people go into a build thinking that 10K will get them far. I have a couple fab shop owner buddies that have had to start charging storage fees due to people running out of money and the vehicle has become a shop queen.
    Here is the website for the C4 Fab, they do some killer work...if anyone is interested.
    http://www.c4fabrication.com
    I also sent them a message inquiring about the build.
  28. Apr 12, 2016 at 9:55 PM
    Sefferston
    Sefferston #35sandlongtravel
    Seth
    ERMERGERD TOYOTA
    I wants.
    Sent from your mother's asshole
  29. Apr 21, 2016 at 9:21 AM
    dcsleeper408
    dcsleeper408 15' Tundra Pro
    mark
    San Jose CA
    2015 TRD PRO
    Dope build!
    Sub'd
  30. Apr 21, 2016 at 9:53 AM
    csuviper
    Broomfield, CO
    Yea this build had some major potential. Very expensive!!!!
    dcsleeper408 likes this.
