Programming 2018 TPMS
Discussion in 'Wheels & Tires' started by mojojo, Apr 19, 2019.
  1. Apr 19, 2019 at 9:26 AM
    mojojo
    mojojo [OP] New Member
    2018 Cement SR5 CM
    I've tried searching and found a lot of discussion on which sensor to use for 2018 trucks, but not quite what I'm looking for on programming them. I've seen various posts on the TechStream software on ebay being capable of this, but also seen threads on issues due to the field within the ebay TechStream software being limited to the number of digits that can be inputted.
    I'm purchasing a new set of wheels and tires, and will leave my stock wheels/tires/sensors as-is.
    I'm going to purchase 4 new Toyota TPMS. I am purchasing (4) 42607-0C091 along with install kits. These will be installed in Method alloy wheels.
    I went by a local tire shop today to check on tires, and after interacting with them, it does not sound like their tool will be compatible with the 2018 TPMS. *Their handheld tool is able to read the sensor ID, but not able to program new sensors.
    Is there any confirmed way to program the 2018 TPMS that does not require a visit to the dealer?
    5/5/19 Update:
    I followed this thread:
    https://www.ft86club.com/forums/showthread.php?t=73034
    and installed the drivers for the MVCI cable onto a Windows 7 64 bit laptop. Once I was able to use the Firmware update tool to confirm that Windows recognized the MVCI cable (the firmware application responded that the tool was connected, and there were no hardware conflicts in Device Manager), I continued on to Techstream installation.
    I tried several iterations of Techstream and found a mismatch of features/model years/etc... that would not get me all the way through the TPMS utility. As of 5/5/19 I was able to program 3/4 sensors (42607-0C091) using Techstream v. 12.02.024. One sensor is no longer outputting any signal and will be replaced. I suspect the tire installer damaged this sensor upon installation.
    DZ_ likes this.
  2. Apr 20, 2019 at 9:26 PM
    1bad10tacoma
    1bad10tacoma New Member
    Mark
    2019 Tundra
    I too would like an answer for this. Doing the same with a 2019
    mojojo[OP] likes this.
  3. Apr 22, 2019 at 2:35 PM
    schaderaide
    schaderaide New Member
    Ryan
    Orange County, CA
    Ive received 2 different answers on this.
    1) The 2017 software does not work for 2018. Most shops are 1-2 years behind because they arent swapping tires out for new models. Goto the dealer.
    2) There is an issue with the software for Toyota and (fill in the blank of other manufacturer), and they wont even attempt to reset the TPMS. Goto the dealer.
  4. Apr 22, 2019 at 4:01 PM
    mojojo
    2018 Cement SR5 CM
    So I stopped by discount tire today.
    They were able to read the IDs on my current sensors, so I'm hoping they can reprogram.
    I'll keep this updated as I find out...
    schaderaide likes this.
  5. Apr 23, 2019 at 8:07 AM
    schaderaide
    Ryan
    Orange County, CA
    They were able to read mine but unable to reprogram. Good luck!
  6. Apr 23, 2019 at 8:22 AM
    mojojo
    2018 Cement SR5 CM
    Dang.
    Do you recall what the issue was to reprogram?
  7. Apr 23, 2019 at 8:32 AM
    schaderaide
    Ryan
    Orange County, CA
    They had the 2017 software version which could read the sensors but couldnt reprogram a 2018.
    Another shop I went to had the 2018 software but it always failed for Toyotas and I think he said Lexus
  8. Apr 23, 2019 at 9:01 AM
    bfd300
    bfd300 New Member
    I swapped out my Steele’s for trd rims, bought new sensors and tech stream off eBay. I programmed tpm’s with no problem.
  9. Apr 23, 2019 at 9:04 AM
    schaderaide
    Ryan
    Orange County, CA
    What year?
  10. Apr 23, 2019 at 9:58 AM
    bfd300
    bfd300 New Member
    2019. 18 n up use a 7 digit code on the tpms. 17 n older use an 8 digit code.
  11. Apr 23, 2019 at 4:09 PM
    mojojo
    2018 Cement SR5 CM
    Will you link to the techstream you purchased?
  12. Apr 23, 2019 at 4:36 PM
    bfd300
    bfd300 New Member
  13. Apr 26, 2019 at 5:32 PM
    mojojo
    2018 Cement SR5 CM
    So I had a long day at the tire shop today getting new wheels/tpms/tires mounted.
    The shop confirmed that they were unable to program new sensors due to the 2018+.
    However, I noticed that I was getting accurate read outs from all four sensors in the gauge cluster both times I started the vehicle and allowed it to idle for a few minutes... weird. Hopefully this just needs to be programmed.
    I'm going to order the cable posted by @bfd300 and report back with findings.
    Thanks all for the help.
  14. Apr 26, 2019 at 5:38 PM
    bfd300
    bfd300 New Member
    Make sure you write down the codes for all 4 sensors before you mount the tires. You will need to enter the codes manually in the tech stream software.
  15. Apr 26, 2019 at 5:40 PM
    mojojo
    2018 Cement SR5 CM
    I snapped a picture of each sensor before they were installed. :)
    bfd300[QUOTED] likes this.
  16. May 4, 2019 at 11:31 PM
    mojojo
    2018 Cement SR5 CM
    So ive spent the last few hours getting techstream up and running...
    I was able to clear dtcs on the tpms but it's not intuitive how to reprogram new sensors.
    Where is the menu located to reprogram the new sensors? I watched a Youtube video and noticed the narrator selected a "Utility" link from the TPMS page in Techstream. Techstream 13.00.022 does not provide me with the same link.
  17. May 5, 2019 at 6:38 AM
    bfd300
    bfd300 New Member
  18. May 5, 2019 at 11:52 AM
    mojojo
    2018 Cement SR5 CM
    That worked. However, it looks like I've got one broken sensor, which is not surprising to me. I'll be ordering a new sensor and returning to the tire shop that mounted tires.
    Thank you for your help.
  19. May 11, 2019 at 12:19 PM
    mojojo
    2018 Cement SR5 CM
    Well... The saga continues for me.
    The software quoted above DOES work to successfully program sensors for 2018.
    Turns out one of the installers installed a bad aftermarket sensor in my wheel, and not the new Toyota sensor I supplied. The shop is reimbursing me for my fifth sensor.
    In the process of swapping sensors, they did not rebalance the wheel, so at 65 mph I had quite a bit of seat vibration. I returned to the shop for them to rebalance the wheel and they severely scratched the wheel... So the shop will have to buy me a new wheel.
    Now I'm back at the shop because the valve is leaking from the wheel...
  20. Aug 13, 2019 at 5:40 AM
    Danny
    Danny New Member
    2018 Tundra Crewmax SR5
    Will an 8 digit code sensor work on a 2018? Just bought some used rims with tpms but they were pre 2018
  21. Aug 13, 2019 at 6:10 AM
    mojojo
    2018 Cement SR5 CM
    No.
  22. Aug 13, 2019 at 9:34 AM
    Danny
    Danny New Member
    Do you know why?
  23. Aug 13, 2019 at 9:42 AM
    mojojo
    2018 Cement SR5 CM
    They're not interchangeable.
    The 2018+ register actual pressure. I'm not certain that <2017 have that capability.
  24. Aug 13, 2019 at 9:52 AM
    bigdogk9
    bigdogk9 New Member
    Ed
    2018 Toyota Tundra 1794 Edition
    Sounds like you need a new shop to go too. Just some info the autel mx sensors bolt in work in 2018 models.
  25. Aug 13, 2019 at 9:38 PM
    Danny
    Danny New Member
    Do they have to be registered
  26. Aug 14, 2019 at 10:38 AM
    bigdogk9
    bigdogk9 New Member
    Ed
    Any sensor will need to be registered to tpms module no matter what brand you go with new or used
  27. Aug 30, 2019 at 12:44 PM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    Where did you go for all this work Kmart? Damn that shop sucks
  28. Sep 1, 2019 at 7:48 AM
    mojojo
    2018 Cement SR5 CM
    Mavis Discount Tire
    Needless to say, I was not impressed and will not be returning.
    cmiller219[QUOTED] likes this.
