Pro grill with limited insert and pro headlights
Discussion in 'Lighting' started by Berettafan, Apr 7, 2017.
  1. Apr 7, 2017 at 2:29 PM
    Berettafan
    Berettafan [OP] New Member
    2017 CM
    Have a pro grill in order for my MGM cm limited. Thinking about swapping just the surround and keeping the brushed silver grill insert. Also have pro headlights.
    Anyone try this? Is it same as plat with pro lights?
  2. Apr 7, 2017 at 4:52 PM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Pretty sure thats exactly what it is.....plat w pro lights
  3. Apr 7, 2017 at 4:55 PM
    CTX84
    CTX84 New Member
    So ur putting pro headlights on a platinum? You'll loss your LED DRL unless you open them and mod them urself. But the grills will swap inserts no problem.
    FireAC likes this.
  4. Apr 7, 2017 at 4:55 PM
    joem1cha3l
    Albany, NY
    Here's mine w Spyder Headlights...
  5. Apr 7, 2017 at 4:57 PM
    joem1cha3l
    Albany, NY
    No. OP has a limited.
  6. Apr 7, 2017 at 5:04 PM
    CTX84
    CTX84 New Member
    My fault.
  7. Apr 7, 2017 at 5:30 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    rockjockey likes this.
  8. Apr 7, 2017 at 6:20 PM
    rockjockey
    rockjockey Per ardua ad astra!
    Spring, TX
    2016 White Tundra TSS
    Like the Gadsden license plate!
    Cat3ILS likes this.
  9. Apr 7, 2017 at 6:46 PM
    FireAC
    FireAC New Member
    NB, Canada
    2016 Platinum Magnetic Grey Metallic
    I'm thinking of Pro headlights for my Platinum for the dark look...but hate to lose the LED drl...not sure what to do...
    You say the inserts come out no problem? I can't seem to find any specific info on this...other than it can be tricky. I'm either putting a Pro grille insert...or I actually might just plastidip the platinum grille insert...but if like to take it out to do it...
  10. Apr 7, 2017 at 7:10 PM
    CTX84
    CTX84 New Member
    If you do have the LED DRL and you want to keep it then either just a BHLM or retrofit with the BHLM. Either way your gunna have to open up those lights to do it. I'm scared to do mine but I have a feeling I will sometime soon.
    FireAC likes this.
  11. Apr 11, 2017 at 11:52 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    I put in a platinum grill. I'll do headlights eventually.
    Cat3ILS likes this.
  12. Apr 12, 2017 at 4:12 AM
    FireAC
    FireAC New Member
    NB, Canada
    I like doing some things myself...just don't think I wanna take the chance on my brand new headlights. Been getting some info from lew about retrofits... might be the easy way out for me...
  13. Apr 12, 2017 at 7:26 PM
    HUTCHJ
    HUTCHJ I can ride my bike with no handlebars
    J
    Close?
    Cat3ILS likes this.
  14. Apr 12, 2017 at 7:38 PM
    Berettafan
    2017 CM
    Very close thanks!
